Home » Language IDEs » Java Development Tools (JDT) » Eclipse m2e plugin issue for cyclic dependent projects(Eclipse m2e plugin issue for cyclic dependent projects)
Eclipse m2e plugin issue for cyclic dependent projects [message #1827766] |
Fri, 22 May 2020 16:04  |
I have an issue with m2e plugin for cyclic dependent projects.
First of all, I know that circular dependencies are bad , maven also does not permit it, they should be avoided and etc. but our legacy projects were mavenized without project structure change (circular dependencies were continued).
Previously, adding each project to other projects build path and setting circular dependencies build path problem to warning was the workaround solution. That way, I could make changes in one project and see the effect in the other immediately.
Now that projects are mavenized, I want to achieve the same workspace environment by enabling m2e workspace resolution (by checking "Resolve dependencies from workspace projects" option).
In eclipse neon (Version: Neon.3 Release (4.6.3) Build id: 20170314-1500) with m2e version 1.7.0.20160603-1933 this is possible. Corresponding maven dependency is resolved from workspace project although there is cycle in build path.
However, in eclipse 2019-09 R (Version: 2019-09 R (4.13.0) Build id: 20190917-1200 with m2e version 1.13.0.20190716-1624) and later releases, build results in infinite loop. For two cyclic projects MY PROJECT A and MY PROJECT B with maven artifact ids MYPROJECTAARTIFACTID, MYPROJECTBARTIFACTID respectively, below is the m2e log for infinite build from 2019-09 R version (I could not gather logs from neon version).
To repeat, I know that maven itself does not allow cyclic project setup but in general eclipse does allow it even for projects with maven nature.
How can I achieve the same in latest eclipse releases?
2020-05-22 21:19:26,588 [Worker-7: Building Workspace] DEBUG o.e.m.c.i.builder.MavenBuilder - Building project MY PROJECT B
2020-05-22 21:19:26,683 [Worker-7: Building Workspace] DEBUG o.e.a.i.i.DefaultLocalRepositoryProvider - Using manager EnhancedLocalRepositoryManager with priority 10.0 for D:\MAVEN_REPONEW
2020-05-22 21:19:26,697 [Worker-7: Building Workspace] DEBUG o.e.m.c.i.p.r.ProjectRegistryManager - Refreshing: [L/MY PROJECT B/pom.xml]
2020-05-22 21:19:26,709 [Worker-7: Building Workspace] DEBUG o.e.a.i.i.DefaultLocalRepositoryProvider - Using manager EnhancedLocalRepositoryManager with priority 10.0 for D:\MAVEN_REPONEW
2020-05-22 21:19:26,712 [Worker-7: Building Workspace] DEBUG o.e.m.c.internal.embedder.MavenImpl - Reading 1 Maven project(s): [D:\LOCALGITREPOS\CYCLE_2019\MYPROJECTBARTIFACTID\MY PROJECT B\pom.xml]
2020-05-22 21:19:26,764 [Worker-7: Building Workspace] DEBUG o.e.a.i.i.DefaultUpdatePolicyAnalyzer - Skipped remote request for ...
2020-05-22 21:19:26,868 [Worker-7: Building Workspace] DEBUG o.e.m.c.internal.embedder.MavenImpl - Read 1 Maven project(s) in 156 ms
2020-05-22 21:19:27,036 [Worker-7: Building Workspace] DEBUG o.e.m.c.i.m.MavenMarkerManager - Created marker 'GroupId is duplicate of parent groupId' on resource '/MY PROJECT B/pom.xml'.
2020-05-22 21:19:27,043 [Worker-7: Building Workspace] DEBUG o.e.a.i.i.DefaultLocalRepositoryProvider - Using manager EnhancedLocalRepositoryManager with priority 10.0 for D:\MAVEN_REPONEW
2020-05-22 21:19:27,086 [Worker-7: Building Workspace] DEBUG o.e.m.c.i.l.LifecycleMappingFactory - Loading lifecycle mapping for MavenProject: com.my.company:MYPROJECTBARTIFACTID:1.0.1-SNAPSHOT @ D:\LOCALGITREPOS\CYCLE_2019\MYPROJECTBARTIFACTID\MY PROJECT B\pom.xml.
2020-05-22 21:19:27,670 [Worker-7: Building Workspace] DEBUG o.e.a.i.i.c.DefaultDependencyCollector - Dependency collection stats: {ConflictMarker.analyzeTime=637200, ConflictMarker.markTime=709300, ConflictMarker.nodeCount=118, ConflictIdSorter.graphTime=487300, ConflictIdSorter.topsortTime=290200, ConflictIdSorter.conflictIdCount=45, ConflictIdSorter.conflictIdCycleCount=0, ConflictResolver.totalTime=3881500, ConflictResolver.conflictItemCount=72, DefaultDependencyCollector.collectTime=398895400, DefaultDependencyCollector.transformTime=7801200}
2020-05-22 21:19:27,785 [Worker-7: Building Workspace] INFO o.e.m.c.i.l.LifecycleMappingFactory - Using org.eclipse.m2e.jdt.JarLifecycleMapping lifecycle mapping for MavenProject: com.my.company:MYPROJECTBARTIFACTID:1.0.1-SNAPSHOT @ D:\LOCALGITREPOS\CYCLE_2019\MYPROJECTBARTIFACTID\MY PROJECT B\pom.xml.
2020-05-22 21:19:27,785 [Worker-7: Building Workspace] DEBUG o.e.m.c.i.l.LifecycleMappingFactory - Loaded lifecycle mapping in 699 ms for MavenProject: com.my.company:MYPROJECTBARTIFACTID:1.0.1-SNAPSHOT @ D:\LOCALGITREPOS\CYCLE_2019\MYPROJECTBARTIFACTID\MY PROJECT B\pom.xml.
2020-05-22 21:19:27,785 [Worker-7: Building Workspace] DEBUG o.e.m.c.i.l.LifecycleMappingFactory - MY PROJECT B is configured by :
2020-05-22 21:19:27,785 [Worker-7: Building Workspace] DEBUG o.e.m.c.i.l.LifecycleMappingFactory - - org.eclipse.m2e.jdt.javaConfigurator
2020-05-22 21:19:27,785 [Worker-7: Building Workspace] DEBUG o.e.m.c.i.l.LifecycleMappingFactory - - org.maven.ide.eclipse.configuration.wtp.java.unsupportedDependencyTypeConfigurator
2020-05-22 21:19:27,785 [Worker-7: Building Workspace] DEBUG o.e.m.c.i.l.LifecycleMappingFactory - - org.eclipse.m2e.wtp.jpa.configurator.jdt
2020-05-22 21:19:27,785 [Worker-7: Building Workspace] DEBUG o.e.m.c.i.l.LifecycleMappingFactory - - org.maven.ide.eclipse.configuration.wtp.utility.configurator
2020-05-22 21:19:27,785 [Worker-7: Building Workspace] DEBUG o.e.m.c.i.l.LifecycleMappingFactory - - org.maven.ide.eclipse.configuration.wtp.webfragment.configurator
2020-05-22 21:19:27,785 [Worker-7: Building Workspace] DEBUG o.e.m.c.i.l.LifecycleMappingFactory - - org.sonatype.m2e.mavenarchiver.jararchiverconfigurator
2020-05-22 21:19:27,785 [Worker-7: Building Workspace] DEBUG o.e.m.c.i.l.LifecycleMappingFactory - - org.eclipse.m2e.wtp.jaxrs.configurator
2020-05-22 21:19:27,786 [Worker-7: Building Workspace] DEBUG o.e.m.c.i.p.r.DefaultMavenDependencyResolver - Resolving dependencies for P/MY PROJECT B: com.my.company:MYPROJECTBARTIFACTID:1.0.1-SNAPSHOT
2020-05-22 21:19:27,786 [Worker-7: Building Workspace] DEBUG o.e.m.c.internal.embedder.MavenImpl - Reading Maven project: D:\LOCALGITREPOS\CYCLE_2019\MYPROJECTBARTIFACTID\MY PROJECT B\pom.xml
2020-05-22 21:19:27,790 [Worker-7: Building Workspace] DEBUG o.e.a.i.i.DefaultUpdatePolicyAnalyzer - Skipped remote request for com.my.company:... locally cached metadata up-to-date.
2020-05-22 21:19:28,529 [Worker-7: Building Workspace] DEBUG o.e.a.i.i.c.DefaultDependencyCollector - Dependency collection stats: {ConflictMarker.analyzeTime=925200, ConflictMarker.markTime=269600, ConflictMarker.nodeCount=328, ConflictIdSorter.graphTime=1694200, ConflictIdSorter.topsortTime=470600, ConflictIdSorter.conflictIdCount=88, ConflictIdSorter.conflictIdCycleCount=48, ConflictResolver.totalTime=7407900, ConflictResolver.conflictItemCount=309, DefaultDependencyCollector.collectTime=730670400, DefaultDependencyCollector.transformTime=10784800}
2020-05-22 21:19:28,539 [Worker-7: Building Workspace] INFO o.e.m.c.i.p.WorkspaceClassifierResolverManager - Resolving P/MY PROJECT A: com.my.company:MYPROJECTAARTIFACTID:1.0.1-SNAPSHOT with classifier to /MY PROJECT A/target/classes
2020-05-22 21:19:28,598 [Worker-7: Building Workspace] DEBUG o.e.m.c.internal.embedder.MavenImpl - Read Maven project: D:\LOCALGITREPOS\CYCLE_2019\MYPROJECTBARTIFACTID\MY PROJECT B\pom.xml in 812 ms
2020-05-22 21:19:28,598 [Worker-7: Building Workspace] DEBUG o.e.m.c.i.p.r.DefaultMavenDependencyResolver - Resolved dependencies for P/MY PROJECT B: com.my.company:MYPROJECTBARTIFACTID:1.0.1-SNAPSHOT in 812 ms
2020-05-22 21:19:28,600 [Worker-7: Building Workspace] DEBUG o.e.a.i.i.DefaultLocalRepositoryProvider - Using manager EnhancedLocalRepositoryManager with priority 10.0 for D:\MAVEN_REPONEW
2020-05-22 21:19:28,601 [Worker-7: Building Workspace] DEBUG o.e.m.c.i.l.LifecycleMappingFactory - Loading lifecycle mapping for MavenProject: com.my.company:MYPROJECTBARTIFACTID:1.0.1-SNAPSHOT @ D:\LOCALGITREPOS\CYCLE_2019\MYPROJECTBARTIFACTID\MY PROJECT B\pom.xml.
2020-05-22 21:19:28,607 [Worker-1: Decoration Calculation] DEBUG o.e.j.i.storage.file.FileSnapshot - file=C:\Program Files\Git\etc\gitconfig, isRacyClean=false, read=2020-05-22 21:18:57.612000000, lastModified=2020-04-28 20:51:11.602527000, delta=2075266009473000 ns, racy<=2500000000 ns
2020-05-22 21:19:28,607 [Worker-1: Decoration Calculation] DEBUG o.e.j.i.storage.file.FileSnapshot - file=C:\Program Files\Git\etc\gitconfig, is unmodified
2020-05-22 21:19:28,677 [Worker-7: Building Workspace] INFO o.e.m.c.i.l.LifecycleMappingFactory - Using org.eclipse.m2e.jdt.JarLifecycleMapping lifecycle mapping for MavenProject: com.my.company:MYPROJECTBARTIFACTID:1.0.1-SNAPSHOT @ D:\LOCALGITREPOS\CYCLE_2019\MYPROJECTBARTIFACTID\MY PROJECT B\pom.xml.
2020-05-22 21:19:28,678 [Worker-7: Building Workspace] DEBUG o.e.m.c.i.l.LifecycleMappingFactory - Loaded lifecycle mapping in 77 ms for MavenProject: com.my.company:MYPROJECTBARTIFACTID:1.0.1-SNAPSHOT @ D:\LOCALGITREPOS\CYCLE_2019\MYPROJECTBARTIFACTID\MY PROJECT B\pom.xml.
Re: Eclipse m2e plugin issue for cyclic dependent projects [message #1827881 is a reply to message #1827864] |
Tue, 26 May 2020 05:00  |
As Stephan writes, without refactoring, you have just one artificially partitioned large project.
To make progress you might find it helps to (working in an experimental branch)...
- refactor all cyclic elements into a single (acyclic) plugin
- successively identify prefix/postfix packages/classes that have only input/output internal dependencies and factor those as separate plugins
ie if you start with (X,Y,Z) forming a cycle
refactor as XYZ
refactor as Pre1+(XYZ-Pre1)
refactor as Pre1+Pre2+(XYZ-Pre1-Pre2)
refactor as Pre1+Pre2+(XYZ-Pre1-Pre2-Post1)+Post1
Where loops are obstinate, it may be helpful to define interfaces that can be called from anywhere in Pre1, with implementations/call-backs that occur elsewhere.
Ed Willink
Current Time: Sat Jul 26 03:43:30 EDT 2025
Powered by FUDForum. Page generated in 0.05717 seconds
