Home » Eclipse Projects » GEF » Is it possible to export Plug-ins as stand-alone application
Is it possible to export Plug-ins as stand-alone application [message #182471] Wed, 25 May 2005 13:45 Go to next message
Hi, all,
I am develping a graphics editor as plug-in, but since running inside
workbench will confuse users of my application, so I expect it running as
standard application. Is it possible to export plug-ins, say Shapes, as
standard application with property and outline viewer as child windows?
Thanks and Regards,
Vince
Re: Is it possible to export Plug-ins as stand-alone application [message #182481 is a reply to message #182471] Wed, 25 May 2005 15:28 Go to previous messageGo to next message
vince wrote:
> Hi, all,
> Thanks and Regards,
> Vince
I have an RCP-ified version of the shapes example here
https://bugs.eclipse.org/bugs/show_bug.cgi?id=91472
You can look at that as a start if you want to use RCP and GEF.
Re: Is it possible to export Plug-ins as stand-alone application [message #182717 is a reply to message #182481] Thu, 26 May 2005 12:23 Go to previous messageGo to next message
That seems like what I am looking for. Thank you so much!
However, I got "org.eclipse.ui.part.editoractionbarcontributor cannot be
resolved" error message when I tried to run it.
I am using SDK3.1M7+GEF3.1M7.
Here is how what I did: I copied your file to plugin directory, launched
Eclipse, selected the shape.rcp in plugin view, right clicked it and
followed "Import". I added all libraries that is useful in my thought, but
still cannot reslove the problem. Someone has idea?
Thank you!
Vince
"Chris Aniszczyk" <none@us.ibm.com> wrote in message
news:d72jqi$p9s$1@news.eclipse.org...
> vince wrote:
>> Hi, all,
>> Thanks and Regards,
>> Vince
Re: Is it possible to export Plug-ins as stand-alone application [message #182724 is a reply to message #182717] Thu, 26 May 2005 13:47 Go to previous messageGo to next message
> Thank you!
> Vince
>>vince wrote:
>>>Hi, all,
>>>Thanks and Regards,
>>>Vince
If you import the plugin as a project and launch it via the plugin.xml
you should be all good.
If you can post any verbose logs, let me know.
Re: Is it possible to export Plug-ins as stand-alone application [message #182751 is a reply to message #182724] Thu, 26 May 2005 22:13 Go to previous messageGo to next message
news:d7529g$gb6$1@news.eclipse.org...
>> but
>> Thank you!
>> Vince
>>>vince wrote:
>>>>Hi, all,
>>>>as
>>>>Thanks and Regards,
>>>>Vince
Hi, I still cannot run it :(
When you were saying import the plugin as a project, you mean File-->
Import-->External plugin and fragments, right?
I did that, but found plugin.xml was not in the project automatically, so I
added it to the project by hand.
What do you mean to launch it via the plugin.xml? I right click the file and
choose "Run As"-->"Run...", is it right?
However, error message occured as:
!SESSION 2005-05-26
22:10:22.450 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.5.0
Framework arguments: -product
org.eclipse.gef.examples.shapes.rcp.product -pdelaunch
Command-line arguments: -product
org.eclipse.gef.examples.shapes.rcp.product -data
U:\eclipse\runtime-workspace -dev
file:U:/eclipse/workspace/.metadata/.plugins/org.eclipse.pde .core/New_configuration/dev.properties -
pdelaunch -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2005-05-26 22:10:25.950
!MESSAGE Error installing bundle:
reference:file:plugins/org.eclipse.core.commands_3.1.0.jar/
!STACK 0
org.osgi.framework.BundleException: Bundle "org.eclipse.core.commands"
version "3.1.0" has already been installed from:
update@plugins/org.eclipse.core.commands_3.1.0.jar
at
org.eclipse.osgi.framework.internal.core.Framework.createAnd VerifyBundle(Framework.java:558)
at
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(Framework.java:823)
at
org.eclipse.osgi.framework.internal.core.Framework$2.run(Fra mework.java:738)
at
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.java:789)
at
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(Framework.java:733)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.i nstallBundle(BundleContextImpl.java:221)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:946)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:538)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:285)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:330 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:274)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
More error message is in the attachment. Do you have any more suggestions?
Vince
Re: Is it possible to export Plug-ins as stand-alone application [message #182761 is a reply to message #182751] Thu, 26 May 2005 22:25 Go to previous messageGo to next message
When you import the plugin as a project in the workspace, open the
plugin.xml and you should see a "Launch as application" and it will
automatically create a runtime environment for you. You want to launch
it that way first so it properly configures your runtime env.
I'm going to post an updated version which removes the welcome page /
intro plugins to simplify things.
In about a week I should have an article that details how to create an
RCP shapes editor. Just give me sometime :)
~ Chris
Re: Is it possible to export Plug-ins as stand-alone application [message #182770 is a reply to message #182761] Thu, 26 May 2005 22:42 Go to previous messageGo to next message
Thank you for your nice reply.
However, there still is the same error.
!STACK 0
at .....
I noticed in the Rich client tutorial by Ed Burnette a note:
Don't select "Create an OSGi bundle manifest for the plug-in". The notation
is for creating new RCP project.
In my case, I am importing existing project, so have no chance to deselect
that option. And the error message are all about OSGI, do you have any idea
to remove OSGi part from existing project?
Vince
news:d760lv$g8t$1@news.eclipse.org...
>> and choose "Run As"-->"Run...", is it right?
> automatically create a runtime environment for you. You want to launch it
> In about a week I should have an article that details how to create an RCP
> Cheers,
> ~ Chris
Re: Is it possible to export Plug-ins as stand-alone application [message #182775 is a reply to message #182770] Fri, 27 May 2005 12:32 Go to previous messageGo to next message
I updated the example with a new plugin for rcp.
It include a .product file which you can use in 3.1M7 to export a
standalone version of the plugin.
~ Chris
Re: Is it possible to export Plug-ins as stand-alone application [message #182789 is a reply to message #182775] Sat, 28 May 2005 02:02 Go to previous messageGo to next message
Hi, I was able to launch the plugin in Eclipse now! Thank you so much!
Also I was able to export it to "shapes.exe", however, when I run it, an
error occurred.
Here is the content of .\configuration\1117259997182.log
!SESSION 2005-05-28
01:54:25.610 -----------------------------------------------
java.version=1.5.0
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2005-05-28 01:54:26.391
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:362)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:160)
Do you have any idea about it?
Thanks!
Vince
news:d77i9s$5gs$1@news.eclipse.org...
> Cheers,
> ~ Chris
Different results between testing and after exporting [message #182801 is a reply to message #182775] Sat, 28 May 2005 16:00 Go to previous messageGo to next message
What version of Eclipse are you using?
I was able to run the plugin successfuly when I selected "launch an Eclipse
application" in the overview tab of plugin.xml.
I could also run it by selecting "launch the product" in the overview tab of
shapes.product. It works great, thank you!
However, after I exported the plugin using "Eclipse Product export Wizard"
and got shapes.exe, the Palette is disabled when running the program. The
jpg file that grasped the screen is attached. Replace your rcp.jar with mine
which is also attached, you might re-produce the problem. I compared your
rcp.jar and my rcp.jar and found that the sizes are not same. Mine is 49K
and yours is 52K. Is that because of different versions of Eclipses? I am
sing 3.1M7+WinXP.
I am using plugin.xml, build.properties and shapes.product downloaded from
the link
Thanks and Regards,
Vince
> Cheers,
> ~ Chris
Re: Different results between testing and after exporting [message #182871 is a reply to message #182801] Mon, 30 May 2005 02:25 Go to previous messageGo to next message
could u tell me how to export as an .exe file? i have tried the export
wizard, but seems there isn't such option?
Re: Different results between testing and after exporting [message #182926 is a reply to message #182871] Mon, 30 May 2005 13:04 Go to previous messageGo to next message
hi, you need a .product file, an exmaple of which could be found at
"unknown" <iunknown918@hotmail.com> wrote in message
news:6cbb2bb862256f48f2d15088df9df3d8$1@www.eclipse.org...
Re: Different results between testing and after exporting [message #183026 is a reply to message #182926] Mon, 30 May 2005 23:16 Go to previous messageGo to next message
yeah, i have downloaded ur great work and i can lauch it in eclipse . but
i don't know how to convert it to exe file?
Re: Different results between testing and after exporting [message #183172 is a reply to message #183026] Tue, 31 May 2005 15:25 Go to previous messageGo to next message
It's not my work. The link is given by Chirs Aniszczyk.
Sorry for the confusion.
Double click the .product file, follow "Eclipse Product export wizard" in
the overview tab.
Vince
news:6a7c9c63294fa5c24ef3744629baf86a$1@www.eclipse.org...
Re: Different results between testing and after exporting [message #183263 is a reply to message #183172] Tue, 31 May 2005 21:09 Go to previous message
thanks for ur reply, i misunderstood the meaning of exporting to a exe
file,
i thought it should be a single exe file, but acutlly the export wizard
generates many files including the exe file :)
Previous Topic:Word-wrap in Label -> TextFlow?
Next Topic:Need Help: GEF-Application
Current Time: Mon Nov 03 02:36:43 EST 2025
Powered by FUDForum. Page generated in 0.05538 seconds
