Attempt to add cert file to staged changes is ignored [message #1827646] |
Tue, 19 May 2020 18:49  |
Still using nightly build of egit on 2020-03 ( 5.8.0.202005150925).
I now have a new problem in the unstaged changes list.
I had already created a branch and had pushed a couple of commits to remote. I made some new changes and I was attempting to move them to staged changes individually. I had changed a couple of plain text files, and those went over fine.
I have one file that is a certificate file. The change I made was to run "unix2dos" on it, because it had checked out with dos line endings. I verified the new file now works correctly when I run my service locally.
While stepping through moving each file from unstaged changes to staged changes (so I can add an appropriate comment in the overall comment block), when I got to this keyfile, my attempt to move it to staged changes was ignored. I have tried all the ways know of, selecting and clicking "+", either in the popup or the icon above list, or dragging the file over, even clicking the "++" icon and removing the files I don't want staged (just dot files). It won't let me stage the file. I checked the log, and there's nothing new.
Not sure how to move forward here.
Re: Attempt to add cert file to staged changes is ignored [message #1827656 is a reply to message #1827647] |
Wed, 20 May 2020 03:14  |
David, there are still two eol-related fixes pending in review. Possibly your problems are related to them. In any case we cannot analyze such problems without having a git repo with which to reproduce the problem, and detailed steps to reproduce.
For the problem you describe here, it seems entirely possible to put together a small Github repo for reproducing the bug. Could you do so, please? Then tell me where to find that demo repo, and I'll try to find a Windows machine and will try to reproduce.
Otherwise there's nothing we can do.
FUDForum. Page generated in 0.05237 seconds
