Home » Eclipse Projects » Mosquitto » Remote server Pi Mosquitto Problem
Remote server Pi Mosquitto Problem [message #1827635] Tue, 19 May 2020 13:15 Go to next message
Greetings to all,
I have a problem with mosquitto installed on raspberry.
In local network it works correctly but if I try to access it remotely I cannot connect , i have open the port tcp 1883 in my router (nat)
What could be the problem ?
TK
Re: Remote server Pi Mosquitto Problem [message #1827643 is a reply to message #1827635] Tue, 19 May 2020 16:59 Go to previous message
This sounds like a typical networking problem! Are you connecting from a computer on your local network, or is it external to your network? For the first case, you need to make sure the IP address is correct, plus any firewall on the Pi is allowing that port. If you are trying to connect externally, then I would imagine that you need to configure port forwarding from your router to the Pi.
Previous Topic:Trying to add a new user in a fresh install
Next Topic:Duplicate message
Current Time: Mon Jul 21 04:14:50 EDT 2025
Powered by FUDForum. Page generated in 0.08471 seconds
