Home » Eclipse Projects » Oomph » Different version requirements in product versions
Different version requirements in product versions [message #1827607] Tue, 19 May 2020 05:17 Go to next message
I'm running into an issue with Oomph.
I'm writing a product setup with two versions inside :
- Neon
- 2019-06
For each of these versions, I need to specify plugins versions so I use version ranges on requirements like this :
For neon version :
<requirement
    name="org.sonarlint.eclipse.feature.feature.group"
    versionRange="[3.1.0.201705051000,3.1.0.201705051000]"/>
For 2019-06 version :
<requirement
    versionRange="[4.3.0.12432,4.3.0.12432]"/>
In each version, I declare a repository like this :
<repository
   url="<url of eclipse sonar repo, http eclipse sonarlint org>"/>
My problem is the following :
I do the Neon install with a project setup alright.
I then install Eclipse 2019-06 with same project setup and when it starts and perform additional tasks of project setup, it asks me to update plugin to Neon version because requirements apply.
Note that it happens only when I use bundle pools.
I'm looking for some advices here. Am I doing something wrong ?
Julien
Re: Different version requirements in product versions [message #1827663 is a reply to message #1827607] Wed, 20 May 2020 03:37 Go to previous messageGo to next message
You switched from taking about a product setup in the beginning to tasking about a project setup later on. I need more context to understand the issue. Generally a dialog comes up when the current installation's provide does not satisfy the requirements specified in the p2 task. So if you have very restrictive version ranges, it's not clear how it can be possible that the installer installed a different version that exactly the one you required, or how the launched installation doesn't already have exactly the version required while it was created by the installer...
Re: Different version requirements in product versions [message #1827949 is a reply to message #1827663] Wed, 27 May 2020 09:20 Go to previous messageGo to next message
Yes, I have both :
- A product setup where I do specify strict requirements for plugins. I have requirements for Neon and for 2019-06
- A project setup performing essentially preferences tuning, git clone and maven import
When I do a first install of Neon with my product setup and the project setup selected, everything is fine.
Then I do an install of 2019-06 with my product setup and the same project setup, in the end when eclipse starts, it asks me to update to meet requirements of specific versions of neon install.
It only happens when I use a bundle pool.
Hope it is clearer.
Thank you
Julien
Re: Different version requirements in product versions [message #1827978 is a reply to message #1827949] Thu, 28 May 2020 02:17 Go to previous message
Sorry, but without something to reproduce the problem, it's really hard to say anything terribly concrete. You can certainly skip the dialog and inspect the installation profile to see what is installed and you can do Perform Setup Tasks later to see all the requirements of the p2 task. That should help explain what's missing or installed as a different version....
Previous Topic:Eclipse Not visible to other users on Machine
Next Topic:Problem with Launch Task did not find External Tool configuration on first run
Current Time: Tue Jun 03 07:16:41 EDT 2025
Powered by FUDForum. Page generated in 0.28793 seconds
