Home » Language IDEs » PHP Development Tools (PDT) » Autocomplete does not work with backslash(Autocomplete does not work with backslash)
Autocomplete does not work with backslash [message #1827496] Fri, 15 May 2020 16:02 Go to next message
When I define the return type in a function in a specific namespace, when calling this function and putting its result in a variable, the autocomplete does not work ex \ PDOStatement this happens for any object.
index.php/fa/38124/0/
The autocomplete only works if you put "use PDOStatement;"
index.php/fa/38123/0/
Any suggestion?
The problem is only in the autocomplete, as my code is running without errors.
Eclipse IDE for PHP Developers
Version: 2020-03 (4.15.0)
Build id: 20200313-1211
  • Attachment: ok.PNG
    (Size: 25.80KB, Downloaded 914 times)
  • Attachment: error.PNG
    (Size: 22.23KB, Downloaded 1017 times)
Re: Autocomplete does not work with backslash [message #1827506 is a reply to message #1827496] Sat, 16 May 2020 02:39 Go to previous message
Please open a bug here: https://github.com/eclipse/pdt/issues
Previous Topic:Project developing moved to GitHub
Next Topic:Operation lockout after starting multiple operations
Current Time: Mon Jul 21 10:52:16 EDT 2025
Powered by FUDForum. Page generated in 0.05480 seconds
