Manage and describe Requirements [message #1827381] |
Wed, 13 May 2020 19:24  |
is it possible to manage and have a description of requirements imported via Requirement VP, something like Management and Description Tabs in Function Properties or others.
It could be interesting to edit a progress statut of a requirement and to document it.
thank you for your answer
Best regards
david
Re: Manage and describe Requirements [message #1827382 is a reply to message #1827381] |
Wed, 13 May 2020 19:42   |
Hi David,
I am not sure that I got 100% of your question but let's say that what you're looking for is a way to enter additional information regarding the requirements you imported (let say a progress status).
If Requirements were Capella regular objects, one option would be to use the "Progress Monitoring" capabilities of Capella (Right-click on an element and select "Progress Monitoring"), among other possible solutions.
For Requirements, it is a little bit different since these objects are coming with the Requirements Viewpoint. Nevertheless, you can create your own Requirement Types, and add properties to them, these can be string properties for a status description for instance, or en enumeration property for the status itself.
Creating Requirements Types and Attributes is not very well documented, let me know if you're not able to do it, please start by having a look at Help->Requirements ViewPoint Guide -> Users's guide -> Edition of Requirements
I hope this helps.
FUDForum. Page generated in 0.08004 seconds
