Home » Polarsys » M2Doc » Description Tab with M2DOC(How to edit Description Tab with M2DOC)
Description Tab with M2DOC [message #1827253] Mon, 11 May 2020 10:13 Go to next message
I would like to edit Description TAb with M2DOC using:
m:for lc | self.eAllContents (la::LogicalComponent)
m:lc.description
m:endfor
The result is:
<p>JE SUIS LE SYSTEME XXX </p>
<p><a href="file:///C:/DOCUMENTATION DATA BASE/TECHNICAL DOCUMENTS/XXXPlan de déroulement.xlsx">C:/DOCUMENTATION DATA BASE/TECHNICAL DOCUMENTS/Plan de d&eacute;roulement.xlsx</a></p>
<p>&nbsp;</p>
<p>&nbsp;</p>
How to avoid useless Characters <p>, <p>&nbsp;</p>, d&eacute;roulement ...?
Thank you for your answer,
David
Re: Description Tab with M2DOC [message #1827265 is a reply to message #1827253] Mon, 11 May 2020 14:38 Go to previous messageGo to next message
Hi David,
This thread should answer your question: https://www.eclipse.org/forums/index.php/t/1101761/
All the best,
Re: Description Tab with M2DOC [message #1827271 is a reply to message #1827265] Mon, 11 May 2020 18:13 Go to previous messageGo to next message
Hi Stephane,
Obviously, I should have had a look at the latest version of the template!! sorry for this bad question!
I'm looking forward to seeing your next answers ;-)
david
Re: Description Tab with M2DOC [message #1827272 is a reply to message #1827271] Mon, 11 May 2020 18:20 Go to previous message
No worries, it was not that obvious as this is one of the features that was added in the last m2doc version.
Previous Topic:M2Doc: Parameters of the physical architecture in AQL
Next Topic:The 'NewTemplate" wizard is missing
Current Time: Mon Jul 21 12:12:30 EDT 2025
Powered by FUDForum. Page generated in 0.04453 seconds
