I need help with installing Eclipse IDE for Java developers. [message #1827141] |
Thu, 07 May 2020 19:24  |
I have tried installing Eclipse but every time I get the a red text box at the top of my screen that states, "installation failed with an error. Show log." I looked through these forums for the solution to this problem but everything I found didn't work. Majority of the solutions were for you to go into your bundle pool and fix any corrupted Artifacts. However when I try to do that there are no artifacts for me to repair. If anyone can help me that would be highly appreciated. Also, here is the error log that shows up if you click on show log in the error message.
[2020-05-07 18:23:15] Executing bootstrap tasks
[2020-05-07 18:23:15] Java(TM) SE Runtime Environment 14.0.1+7
[2020-05-07 18:23:15] Product org.eclipse.products.epp.package.java.2020-03
[2020-05-07 18:23:15] Bundle org.eclipse.oomph.setup 1.16.0.v20200309-0628, build=4574, branch=1da35020a3c353b5b394468c77f8dc5906f072b7
[2020-05-07 18:23:15] Bundle org.eclipse.oomph.setup.core 1.16.0.v20200219-0856, build=4574, branch=1da35020a3c353b5b394468c77f8dc5906f072b7
[2020-05-07 18:23:15] Bundle org.eclipse.oomph.setup.p2 1.14.0.v20200202-1112, build=4574, branch=1da35020a3c353b5b394468c77f8dc5906f072b7
[2020-05-07 18:23:15] Performing P2 Director (Eclipse IDE for Java Developers (2020-03))
[2020-05-07 18:23:15] Offline = false
[2020-05-07 18:23:15] Mirrors = true
[2020-05-07 18:23:15] Resolving 23 requirements from 3 repositories to C:\Users\bntan\eclipse\eclipse\eclipse\eclipse
[2020-05-07 18:23:15] Requirement epp.package.java [4.15.0,5.0.0)
[2020-05-07 18:23:15] Requirement org.eclipse.platform.feature.group [4.15.0,5.0.0)
[2020-05-07 18:23:15] Requirement org.eclipse.rcp.feature.group [4.15.0,5.0.0)
[2020-05-07 18:23:15] Requirement org.eclipse.buildship.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.eclemma.feature.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.egit.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.egit.mylyn.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.epp.mpc.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.jdt.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.jgit.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.m2e.feature.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.m2e.logback.feature.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.mylyn.bugzilla_feature.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.mylyn.context_feature.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.mylyn.git.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.mylyn.hudson.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.mylyn.ide_feature.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.mylyn.java_feature.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.mylyn.wikitext_feature.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.mylyn_feature.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.tips.feature.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.wst.xml_ui.feature.feature.group
[2020-05-07 18:23:15] Requirement org.eclipse.oomph.setup.feature.group
[2020-05-07 18:23:15] Repository http://download.eclipse.org/technology/epp/packages/2020-03
[2020-05-07 18:23:15] Repository http://download.eclipse.org/releases/2020-03/202003181000
[2020-05-07 18:23:15] Repository http://download.eclipse.org/oomph/updates/milestone/latest
[2020-05-07 18:23:15] ERROR: org.eclipse.equinox.p2.transport.ecf code=1002 Unable to read repository at http://download.eclipse.org/oomph/updates/milestone/latest/content.xml.
java.net.SocketException: Address family not supported by protocol family: connect
at java.base/sun.nio.ch.Net.connect0(Native Method)
at java.base/sun.nio.ch.Net.connect(Net.java:503)
at java.base/sun.nio.ch.Net.connect(Net.java:492)
at java.base/sun.nio.ch.NioSocketImpl.connect(NioSocketImpl.java:588)
at java.base/java.net.SocksSocketImpl.connect(SocksSocketImpl.java:333)
at java.base/java.net.Socket.connect(Socket.java:648)
at org.apache.http.conn.socket.PlainConnectionSocketFactory.connectSocket(PlainConnectionSocketFactory.java:75)
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142)
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:374)
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:393)
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:236)
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:186)
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89)
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110) at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83)
at org.eclipse.ecf.provider.filetransfer.httpclient45.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:246) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Re: I need help with installing Eclipse IDE for Java developers. [message #1829571 is a reply to message #1827344] |
Mon, 06 July 2020 21:01   |
I am also having this problem. i have tried adjusting the java setting to TRUE in command, i have disabled all firewall and proxy settings, i have deleted the .p2 folder. have given the installer full authorization.....
2020-07-06 18:50:07] Executing bootstrap tasks
[2020-07-06 18:50:07] Java(TM) SE Runtime Environment 1.8.0_251-b08
[2020-07-06 18:50:07] Product org.eclipse.products.epp.package.java.2020-06
[2020-07-06 18:50:07] Bundle org.eclipse.oomph.setup 1.17.0.v20200606-0914, build=4683, branch=11a8454bc4da69195dc3e9f065bbd8fe43f77e1e
[2020-07-06 18:50:07] Bundle org.eclipse.oomph.setup.core 1.17.0.v20200531-1047, build=4683, branch=11a8454bc4da69195dc3e9f065bbd8fe43f77e1e
[2020-07-06 18:50:07] Bundle org.eclipse.oomph.setup.p2 1.15.0.v20200531-1047, build=4683, branch=11a8454bc4da69195dc3e9f065bbd8fe43f77e1e
[2020-07-06 18:50:07] Performing P2 Director (Eclipse IDE for Java Developers (2020-06))
[2020-07-06 18:50:07] Offline = false
[2020-07-06 18:50:07] Mirrors = true
[2020-07-06 18:50:07] Resolving 16 requirements from 3 repositories to C:\Users\Poehn\eclipse\java-2020-062\eclipse
[2020-07-06 18:50:07] Requirement org.eclipse.equinox.p2.iu:epp.package.java [4.16.0,5.0.0)
[2020-07-06 18:50:07] Requirement org.eclipse.equinox.p2.iu:org.eclipse.platform.feature.group [4.16.0,5.0.0)
[2020-07-06 18:50:07] Requirement org.eclipse.equinox.p2.iu:org.eclipse.rcp.feature.group [4.16.0,5.0.0)
[2020-07-06 18:50:07] Requirement org.eclipse.equinox.p2.iu:org.eclipse.buildship.feature.group
[2020-07-06 18:50:07] Requirement org.eclipse.equinox.p2.iu:org.eclipse.eclemma.feature.feature.group
[2020-07-06 18:50:07] Requirement org.eclipse.equinox.p2.iu:org.eclipse.egit.feature.group
[2020-07-06 18:50:07] Requirement org.eclipse.equinox.p2.iu:org.eclipse.epp.mpc.feature.group
[2020-07-06 18:50:07] Requirement org.eclipse.equinox.p2.iu:org.eclipse.jdt.feature.group
[2020-07-06 18:50:07] Requirement org.eclipse.equinox.p2.iu:org.eclipse.jgit.feature.group
[2020-07-06 18:50:07] Requirement org.eclipse.equinox.p2.iu:org.eclipse.m2e.feature.feature.group
[2020-07-06 18:50:07] Requirement org.eclipse.equinox.p2.iu:org.eclipse.m2e.lemminx.feature.feature.group
[2020-07-06 18:50:07] Requirement org.eclipse.equinox.p2.iu:org.eclipse.m2e.logback.feature.feature.group
[2020-07-06 18:50:07] Requirement org.eclipse.equinox.p2.iu:org.eclipse.mylyn.wikitext_feature.feature.group
[2020-07-06 18:50:07] Requirement org.eclipse.equinox.p2.iu:org.eclipse.tips.feature.feature.group
[2020-07-06 18:50:07] Requirement org.eclipse.equinox.p2.iu:org.eclipse.wildwebdeveloper.xml.feature.feature.group
[2020-07-06 18:50:07] Requirement org.eclipse.equinox.p2.iu:org.eclipse.oomph.setup.feature.group
[2020-07-06 18:50:07] Repository http://download.eclipse.org/technology/epp/packages/2020-06
[2020-07-06 18:50:07] Repository http://download.eclipse.org/releases/2020-06/202006171000
[2020-07-06 18:50:07] Repository http://download.eclipse.org/oomph/updates/milestone/latest
[2020-07-06 18:50:07] ERROR: org.eclipse.equinox.p2.transport.ecf code=1002 Unable to read repository at http://download.eclipse.org/releases/2020-06/202006171000/content.xml.
at java.net.DualStackPlainSocketImpl.connect0(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
FUDForum. Page generated in 0.13204 seconds
