Home » Eclipse Projects » GEF » EDiagram changes on 10-May-2005
EDiagram changes on 10-May-2005 [message #182685] |
Thu, 26 May 2005 02:18  |
Hi Pratik
You committed a number of updates to EDiagram on 10-May,
which seem to remove previously useful functionality.
The introduction of the ...properties.emf classes and elimination
of the use of the EMF Providers seem to be part of a more
consistent OutlinePage integration and to eliminate the clutter
from derived properties. But, only graphical properties are
now shown so useful properties such as names, or reference
attributes cannot be edited (Editing names by direct editing
is awkward since the direct editor doesn't often activate and
when it does it hits an unpleasant off-by-one bug showing one
too few characters).
Editing reference attributes is not always possible now because
as noted in other threads there must be a router constraint to
avoid a null bendpoints. Examining the properties of a bendpoint-less
reference now gets an NPE. I tracked a similar problem to an initialisation
order issue that crept in with a change to ScrollingGraphicalViewer
in 3.1M6.
What is the intent of these changes?
Ed Willink
Re: EDiagram changes on 10-May-2005 [message #182735 is a reply to message #182701] |
Thu, 26 May 2005 15:52   |
--------------030307030402090302050600
Hi Pratik
I found that it took only a very little change to EDiagramEditor to make the
pre 10-May-2005 code work with M6; mostly just losing the ...properties.emf
variants that seem to have made into GEF core. This holds up under M7.
If I do the Providers, I will want to keep them extensible, so I would seek
to eliminate the PropertySourceFactory so that instanceof polling is replaced
by something like
public Object getAdapter(Class key) {
if (IPropertySource.class == key) {
IRegime regime = Regimen.getRegime(getDiagram().getClass(), getModel().getClass());
return regime.getPropertySource(getModel());
return super.getAdapter(key);
to get the diagram-class-dependent policy for the model-class.
It is then possible to extend by registering another IRegime derivation
with Regimen via an extension point. (Mostly-working example sources attached
demnonstrating how Palette, EditPart, Command and Link/Node creation are
all localised; TreeEditPart still to be done.).
- UmlcDiagram is not intentionally different from EDiagram, just a more
consistent name when needing distinct 'UML' Class/Package/Transformation diagrams
- DiagramElement is a common base for Diagram, Link, Node
Ed Willink
Pratik Shah wrote:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=84910
> We intend to move away from using the EMF providers as property sources.
> That release was the first step towards that. I still need to write the
> property sources for ECore classes. That'll be updated soon. (If you want
> to help out with these, that would be great!) I released the changes w/o
> having completed the new property sources because the code in the repository
> was not compiling against the latest GEF builds. Until all the new code is
> in, you can still use the old properties by checking out the "oldProperties"
> version of the ediagram example. I think the latest milestone build that
> that compiled against was M5.
> "Ed Willink" <ed@willink.me.uk> wrote in message
> news:d73puj$unm$1@news.eclipse.org...
>>Hi Pratik
> initialisation
>>in 3.1M6.
>>Regards
>>Ed Willink
name="Regimen.java"
Content-Disposition: inline;
filename="Regimen.java"
package org.eclipse.gmt.umlx.editor.regime;
import java.lang.reflect.Field;
import java.util.HashMap;
import java.util.Map;
import org.eclipse.core.runtime.IConfigurationElement;
import org.eclipse.core.runtime.IExtension;
import org.eclipse.core.runtime.IExtensionPoint;
import org.eclipse.core.runtime.IExtensionRegistry;
import org.eclipse.core.runtime.Platform;
import org.eclipse.gmt.umlx.UmlxPlugin;
import org.eclipse.gmt.umlx.ediagram.Diagram;
import org.eclipse.gmt.umlx.ediagram.DiagramElement;
public class Regimen<M extends Object> {
private static class DiagramMap extends HashMap<Class<? extends Diagram>, IRegime> {
private static final long serialVersionUID = 1L;
* Return the diagram that is or that contains diagramElement
* @param diagramElement for which diagram required
* @return the diagram
public static Diagram getDiagram(DiagramElement diagramElement) {
while ((diagramElement != null) && !(diagramElement instanceof Diagram))
diagramElement = (DiagramElement) diagramElement.eContainer();
return (Diagram) diagramElement;
private static boolean initialised = false;
public static void init() {
if (initialised)
return;
initialised = true;
IExtensionRegistry pluginRegistry = Platform.getExtensionRegistry();
IExtensionPoint extensionPoint = pluginRegistry.getExtensionPoint(UmlxPlugin.DIAGRAM_CONTENT_ ID);
if (extensionPoint == null) {
UmlxPlugin.logException(UmlxPlugin.newError("No '" + UmlxPlugin.DIAGRAM_CONTENT_ID + "' extension point", null), true);
return;
for (IExtension extension : extensionPoint.getExtensions()) {
for (IConfigurationElement diagramElement : extension.getConfigurationElements()) {
try {
String diagramName = diagramElement.getAttribute("name");
if (diagramName == null)
throw UmlxPlugin.newError("Missing \"name=\" attribute for <diagram> element", null);
String diagramClassName = diagramElement.getAttribute("class");
if (diagramClassName == null)
throw UmlxPlugin.newError("Missing \"class=\" attribute for <diagram> element", null);
Class<?> diagramClass = Class.forName(diagramClassName);
for (IConfigurationElement regimeElement : diagramElement.getChildren("regime")) {
try {
String regimeClassName = regimeElement.getAttribute("class");
if (regimeClassName == null)
throw UmlxPlugin.newError("Missing \"class=\" attribute for <diagram name='" + diagramName + "' <regime>> element", null);
Class<?> regimeClass = Class.forName(regimeClassName);
} catch (Exception e) {
UmlxPlugin.logException(e, true);
private Map<Class<? extends M>, DiagramMap> map = null;
public void addRegime(Class<? extends Diagram> diagramClass, Class<? extends M> objectClass, IRegime regime) {
if (diagramClass != null) {
if (map == null)
createMap();
DiagramMap diagramMap = map.get(objectClass);
if (diagramMap == null) {
diagramMap = new DiagramMap();
map.put(objectClass, diagramMap);
diagramMap.put(diagramClass, regime);
public void createMap() {
if (map == null) {
map = new HashMap<Class<? extends M>, DiagramMap>();
init();
* Return the AbstractCreationFactory appropriate for an instance of modelClass below a parent.
* @param modelClass class of model element that needs creating
* @param objectClass of model element in graphical view
* @return the AbstractCreationFactory
public IRegime getRegime(DiagramElement parent, Class<? extends M> objectClass) {
Diagram diagram = Regimen.getDiagram(parent);
if (diagram == null)
return null;
Class<? extends Diagram> diagramClass = diagram.getClass();
return getRegime(diagramClass, objectClass);
public IRegime getRegime(Class<? extends Diagram> diagramClass, Class<? extends M> objectClass) {
if ((diagramClass == null) || (objectClass == null))
return null;
if (map == null)
createMap();
if (diagramMap == null) { // Initial registration is of an interface, add derivation map entries lazily
for (Class<? extends Object> searchModelClass : map.keySet()) {
if (!searchModelClass.isAssignableFrom(objectClass))
else if (diagramMap != null) {
UmlxPlugin.openError("Multiple Regimen for " + objectClass.getName(), null);
else {
diagramMap = map.get(searchModelClass);
break;
return null;
IRegime regime = diagramMap.get(diagramClass);
if (regime == null) { // Initial registration is of an interface, add derivation map entries lazily
for (Class<? extends Diagram> searchDiagramClass : diagramMap.keySet()) {
if (!searchDiagramClass.isAssignableFrom(diagramClass))
else if (regime != null) {
UmlxPlugin.openError("Multiple AbstractCreationFactory for " + objectClass.getName() + " in " + diagramClass.getName(), null);
else {
regime = diagramMap.get(searchDiagramClass);
break;
return regime;
name="IRegime.java"
filename="IRegime.java"
import org.eclipse.draw2d.geometry.Point;
import org.eclipse.gef.EditPart;
import org.eclipse.gef.commands.Command;
import org.eclipse.gmt.umlx.ediagram.Link;
import org.eclipse.gmt.umlx.ediagram.Node;
import org.eclipse.gmt.umlx.editor.commands.links.CreateLinkCommand ;
public interface IRegime {
public static Regimen<Object> MODEL = new Regimen<Object>();
public static Regimen<DiagramElement> VIEW = new Regimen<DiagramElement>();
public Command completeLinkCommand(CreateLinkCommand command, Node source, DiagramElement view, Node target);
// public Command createCreateCommand(DiagramElement parent);
* Create a command to create model and/or child optionally at loc in a parent.
* @param model object to be created if null and not obtainable via child, used if non-null
* @param view object to be created if null, used if non-null
* @param parent view object that is the parent of the child view object
* @param loc location of child view object if non-null
* @return the creation command
public Command createCreateCommand(Object model, Object view, DiagramElement parent, Point loc);
public EditPart createEditPart(Object modelOrView, DiagramElement parent);
public Object createModelObject(DiagramElement parent);
// public Object getNewModelObject(DiagramElement parent);
public DiagramElement createViewObject(Object newModelObject, DiagramElement parent);
public Command createLinkCommand(CreateLinkCommand command, Node source, DiagramElement view, Node target);
public Command createReconnectSourceCommand(Link link, Node node);
public Command createReconnectTargetCommand(Link link, Node node);
public Object getNewObject();
name="Regime.java"
filename="Regime.java"
import org.eclipse.gef.commands.UnexecutableCommand;
import org.eclipse.gmt.umlx.TypeSafeUtils;
public abstract class Regime<T extends Object, V extends DiagramElement/*, PV extends DiagramElement*/> implements IRegime {
protected final Class<? extends Diagram> diagramClass;
protected final Class<T> modelClass;
protected final Class<V> viewClass;
// protected final Class<PV> parentViewClass;
protected Regime(Class<? extends Diagram> diagramClass, Class<T> modelClass, Class<V> viewClass/*, Class<PV> parentViewClass*/) {
if (diagramClass == null)
throw new NullPointerException("Null diagramClass for " + getClass().getName());
// if (modelClass == null)
// throw new NullPointerException("Null modelClass for " + getClass().getName());
if (viewClass == null)
throw new NullPointerException("Null viewClass for " + getClass().getName());
this.diagramClass = diagramClass;
this.modelClass = modelClass;
this.viewClass = viewClass;
// this.parentViewClass = parentViewClass;
if (modelClass != null)
IRegime.MODEL.addRegime(diagramClass, modelClass, this);
IRegime.VIEW.addRegime(diagramClass, viewClass, this);
* @param child view object to be created if null, used if non-null
* @param parent view object that is the parenmt of the child view object
public final Command completeLinkCommand(CreateLinkCommand command, Node source, DiagramElement view, Node target) {
// T validModel = TypeSafeUtils.castTo(model, modelClass);
V validView = TypeSafeUtils.castTo(view, viewClass);
return completeLinkCommand0(command, source, validView, target);
public Command completeLinkCommand0(CreateLinkCommand command, Node source, V view, Node target) {
* The disallow cursor will be shown IFF you return null. If you return
* UnexecutableCommand.INSTANCE, the disallow cursor will not appear. This is
* because since this is the first step of the Command it doesn't check to
* see if it's executable or not (which it most likely isn't).
return UnexecutableCommand.INSTANCE;
public final Command createCreateCommand(Object model, Object view, DiagramElement parent, Point loc) {
return createCreateCommand0(validModel, validView, parent, loc);
public Command createCreateCommand0(T model, V view, DiagramElement parent, Point loc) {
public EditPart createEditPart(Object modelOrViewObject, DiagramElement parent) {
DiagramElement view = null;
if (modelOrViewObject instanceof DiagramElement)
view = (DiagramElement) modelOrViewObject;
else
view = createViewObject(modelOrViewObject, parent);
return createEditPart0(validView);
public abstract EditPart createEditPart0(V view);
public final Command createLinkCommand(CreateLinkCommand command, Node source, DiagramElement view, Node target) {
return createLinkCommand0(command, source, validView, target);
public Command createLinkCommand0(CreateLinkCommand command, Node source, V view, Node target) {
* Create a new modelObject that does not have a view.
* @param parent TODO
* @return the new model object.
public T createModelObject(DiagramElement parent) { return null; }
public Command createReconnectSourceCommand(Link link, Node node) {
V validLink = TypeSafeUtils.castTo(link, viewClass);
return createReconnectCommand0(node, validLink, (Node) link.getTarget());
public Command createReconnectCommand0(Node newSource, V link, Node newTarget) {
public Command createReconnectTargetCommand(Link link, Node node) {
return createReconnectCommand0((Node) link.getSource(), validLink, node);
* Create a new view object for modelObject if non-null, or for a new model object
* as well
* @param modelObject optional model object to be viewed.
* @return the new view object.
public final V createViewObject(Object model, DiagramElement parent) {
return createViewObject0(validModel, parent);
public abstract V createViewObject0(T modelObject, DiagramElement parent);
name="ClassRegime.java"
filename="ClassRegime.java"
package org.eclipse.gmt.umlx.editor.regimes;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EcoreFactory;
import org.eclipse.gef.palette.CombinedTemplateCreationEntry;
import org.eclipse.gef.palette.PaletteEntry;
import org.eclipse.gmt.umlx.editor.commands.nodes.CreateClassComman d;
import org.eclipse.gmt.umlx.editor.edit.parts.ClassEditPart;
import org.eclipse.gmt.umlx.editor.palette.RegimenCreationFactory;
import org.eclipse.gmt.umlx.editor.palette.UmlxDiagramImages;
import org.eclipse.gmt.umlx.editor.regime.Regime;
import org.eclipse.gmt.umlx.udiagram.ClassView;
import org.eclipse.gmt.umlx.udiagram.UDiagramFactory;
import org.eclipse.gmt.umlx.udiagram.UmlcDiagram;
import org.eclipse.jface.resource.ImageDescriptor;
public class ClassRegime extends Regime<EClass, ClassView> {
private static EClass undefinedClass = null;
public static final ClassRegime INSTANCE = new ClassRegime();
public static PaletteEntry createPaletteEntry() {
RegimenCreationFactory factory = new RegimenCreationFactory(INSTANCE);
ImageDescriptor img = UmlxDiagramImages.getImageDescriptor(UmlxDiagramImages.CLASS );
return new CombinedTemplateCreationEntry("Class",
"Create a new class or interface", factory, factory, img, img);
private ClassRegime() {
super(UmlcDiagram.class, EClass.class, ClassView.class);
public Command createCreateCommand0(EClass model, ClassView child, DiagramElement parent, Point loc) {
if (parent instanceof UmlcDiagram)
return new CreateClassCommand(model, child, (UmlcDiagram)parent, loc);
else
public ClassEditPart createEditPart0(ClassView view) {
return new ClassEditPart(view);
public ClassView createViewObject0(EClass model, DiagramElement parent) {
if (parent instanceof UmlcDiagram) {
if (model == null)
model = EcoreFactory.eINSTANCE.createEClass();
ClassView classView = UDiagramFactory.eINSTANCE.createClassView();
classView.setENamedElement(model);
return classView;
else
return null;
public ClassView getNewObject() {
return UDiagramFactory.eINSTANCE.createClassView();
--------------030307030402090302050600--
Re: EDiagram changes on 10-May-2005 [message #182795 is a reply to message #182735] |
Sat, 28 May 2005 04:04  |
Hi Pratik:
The invocation mechanism is a trivial side-issue. Both forms can co-exist. So,
I'm working on these now.
Ed
Current Time: Mon Jul 21 00:26:50 EDT 2025
Powered by FUDForum. Page generated in 0.05074 seconds
