Home » Newcomers » Newcomers » Problem with creating an HTML file ("Unable to start language server")(I run into a problem while creating an HTML file)
Problem with creating an HTML file ("Unable to start language server") [message #1826734] Wed, 29 April 2020 11:27 Go to next message
Good morning (or good evening, according to your time zone),
I've started using Eclipse a few weeks ago, using EPIC (I'm a Perl programmer trying to build a web application using Eclipse as an IDE).
Everything worked well for some days until today, when I reached the point where I had to create an HTML file.
I created the file in the file system (Linux Ubuntu), went back to Eclipse and made "refresh" on the right directory. The file appeared in the project explorer but when I doubled click on it to open it in the editor I got a lot of errors in the Workspace log saying:
Message:
Unable to start language server: HTML Language Server: ProcessStreamConnectionProvider [commands=[null, /home/max/.p2/pool/plugins/org.eclipse.wildwebdeveloper_0.5.6.202004101621/language-servers/node_modules/vscode-html-languageserver/dist/htmlServerMain.js, --stdio], workingDir=/home/max]
Exception stack trace:
java.io.IOException: Unable to start language server: HTML Language Server: ProcessStreamConnectionProvider [commands=[null, /home/max/.p2/pool/plugins/org.eclipse.wildwebdeveloper_0.5.6.202004101621/language-servers/node_modules/vscode-html-languageserver/dist/htmlServerMain.js, --stdio], workingDir=/home/max]
	at org.eclipse.lsp4e.server.ProcessStreamConnectionProvider.start(ProcessStreamConnectionProvider.java:50)
	at org.eclipse.lsp4e.LanguageServerWrapper.start(LanguageServerWrapper.java:213)
	at org.eclipse.lsp4e.LanguageServerWrapper.getInitializedServer(LanguageServerWrapper.java:654)
	at org.eclipse.lsp4e.LanguageServiceAccessor.lambda$14(LanguageServiceAccessor.java:589)
	at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193)
	at java.util.Iterator.forEachRemaining(Iterator.java:116)
	at java.util.Spliterators$IteratorSpliterator.forEachRemaining(Spliterators.java:1801)
	at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:482)
	at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:472)
	at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:546)
	at java.util.stream.AbstractPipeline.evaluateToArrayNode(AbstractPipeline.java:260)
	at java.util.stream.ReferencePipeline.toArray(ReferencePipeline.java:505)
	at org.eclipse.lsp4e.LanguageServiceAccessor.getLanguageServers(LanguageServiceAccessor.java:602)
	at org.eclipse.lsp4e.operations.highlight.HighlightReconcilingStrategy.collectHighlights(HighlightReconcilingStrategy.java:202)
	at org.eclipse.lsp4e.operations.highlight.HighlightReconcilingStrategy.lambda$0(HighlightReconcilingStrategy.java:125)
	at org.eclipse.core.runtime.jobs.Job$2.run(Job.java:185)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Session data:
eclipse.buildId=4.15.0.I20200305-0155
java.version=1.8.0_252
java.vendor=Private Build
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_GB
Framework arguments:  -product org.eclipse.epp.package.javascript.product
Command-line arguments:  -data file:/home/max/bin/eclipse/javascript-2020-03/eclipse/eclipse-workspace/ -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.javascript.product
I made a search in Google but I only find something related to C/C++ and was solved in a way that doesn't apply to me.
Every time I write anything in this HTML files one or more new error lines are appended to the log above.
Does anybody can help me out of this?
(I don't even know if this is the right forum to put this support request into. If not, I'm sorry, would you please point me to the right place?).
Thanks.
Ciao,
Max
Re: Problem with creating an HTML file ("Unable to start language server") [message #1826739 is a reply to message #1826734] Wed, 29 April 2020 12:30 Go to previous messageGo to next message
I'm not sure the right place either. Perhaps open an issue:
https://github.com/eclipse/wildwebdeveloper/issues
Or use their mailing list:
https://projects.eclipse.org/projects/tools.wildwebdeveloper/contact
Re: Problem with creating an HTML file ("Unable to start language server") [message #1826743 is a reply to message #1826739] Wed, 29 April 2020 14:10 Go to previous messageGo to next message
In my experience, all roads lead to https://github.com/eclipse/wildwebdeveloper/issues (or over to the language server's own issue tracker).
Re: Problem with creating an HTML file ("Unable to start language server") [message #1826749 is a reply to message #1826743] Wed, 29 April 2020 18:13 Go to previous messageGo to next message
Thanks a lot. I'll move my support request there.
Ciao,
Max
Re: Problem with creating an HTML file ("Unable to start language server") [message #1826750 is a reply to message #1826749] Wed, 29 April 2020 18:57 Go to previous message
Did you get a message at some point about editing abilities being limited if node.js wasn't installed? It might not be degrading the experience gracefully in that situation.
Previous Topic:Makefile editor coloring
Next Topic:How to Always Show Scrollbars in Eclipse Oxygen
Current Time: Tue Oct 28 12:46:28 EDT 2025
Powered by FUDForum. Page generated in 0.10581 seconds
