Home » Newcomers » Newcomers » C++ search for methods
C++ search for methods [message #182232] Wed, 29 November 2006 21:15 Go to next message
Originally posted by: pedz.easesoftware.com
I must be doing something terribly wrong.
I took an existing project and moved it into Eclipse running the C++
add on (I think it is call CDT). I downloaded everything maybe a month
ago but never played with it until tonight so I have relatively recent
levels of Eclipse and CDT.
My true objective is to find where the ctor for LockedPort is called.
I searched for LockedPort::LockedPort in all the different ways and
places I can find and it never finds much of anything. I've tried
finding the open method of LockedPort and it can't find it.
It can find the declarations or definitions (I don't know which --
maybe both) but it can not find references.
The project compiles. I've hit "Refresh". I've tried closing the
project and reopening it. Nothing.
Aside from waking up this morning, where did I go wrong?
Perry Smith ( pedz@easesoftware.com )
Ease Software, Inc. ( http://www.easesoftware.com )
Low cost SATA Disk Systems for IBMs p5, pSeries, and RS/6000 AIX systems
Re: C++ search for methods [message #182244 is a reply to message #182232] Wed, 29 November 2006 22:41 Go to previous messageGo to next message
Originally posted by: eric.services.ideoform.org
To do something like that in the JDT (Java Tools) and CDT I do Ctrl +
Shift + T for the Open Type action. Then the Outline View will show you
the constructor (you can customize the order that it shows elements in
that view) or you can press Ctrl + O to see the outline in a tool-tip
like thing (which might be called an "infopop"?).
Open Type can be found in the Navigate menu.
> I took an existing project and moved it into Eclipse running the C++ add
> on (I think it is call CDT). I downloaded everything maybe a month ago
> My true objective is to find where the ctor for LockedPort is called. I
> searched for LockedPort::LockedPort in all the different ways and places
> I can find and it never finds much of anything. I've tried finding the
> It can find the declarations or definitions (I don't know which -- maybe
Re: C++ search for methods [message #182252 is a reply to message #182244] Thu, 30 November 2006 00:21 Go to previous messageGo to next message
That is not what I'm looking for. Thanks. Those two things are pretty
cool though.
I want to find all the places where the ctor is used. Or, if the ctor
is a hard example, find all the places where are particular method is
called from. I don't want to search for just "open" because I have
many classes that have an open method. I want to be able to find just
the places where LockedPort::open is called. (But it is not going to
be written in the C++ text as LockedPort::open. Instead, it is going
to be lp.open(); where lp is of type LockedPort.
I have no idea of CDT has that much C++ understanding but I was hoping it did.
On 2006-11-29 21:41:39 -0600, Eric Woodruff <eric.services@ideoform.org> said:
Re: C++ search for methods [message #182261 is a reply to message #182252] Thu, 30 November 2006 00:32 Go to previous messageGo to next message
Java has the notion of a Call Hierarchy however I'm not sure if the CDT
has this feature.
But a google search seems to suggest it does:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.cdt-cor e/org.eclipse.cdt.refactoring/?cvsroot=Tools_Project
(file) plugin.xml 1.8 3 months mschorn Call Hierarchy: Actions
to open the call hierarchy, navigation of nodes
> cool though.
> called from. I don't want to search for just "open" because I have many
> classes that have an open method. I want to be able to find just the
> places where LockedPort::open is called. (But it is not going to be
> written in the C++ text as LockedPort::open. Instead, it is going to be
> it did.
Re: C++ search for methods [message #182571 is a reply to message #182232] Fri, 01 December 2006 13:23 Go to previous messageGo to next message
I don't use CDT, but in JDT you can right-click on a method name (either
in the code editor or in one of the views that show a structured view of
code) and choose References... from the pop-up menu. That will search in
various scopes for references to that element (method, class, field, etc.)
I would think that CDT works the same or similarly. Have you gone
through the CDT tutorials? They probably demonstrate how to navigate
code easily.
Hope this helps,
Eric
Re: C++ search for methods [message #182661 is a reply to message #182571] Fri, 01 December 2006 17:55 Go to previous messageGo to next message
> (either in the code editor or in one of the views that show a
> structured view of code) and choose References... from the pop-up menu.
> That will search in various scopes for references to that element
> code easily.
> Hope this helps,
> Eric
I tried that too but it does not find anything. I'm wondering if I got
the indexer confused somehow.
Re: C++ search for methods [message #182668 is a reply to message #182261] Fri, 01 December 2006 17:57 Go to previous message
I can't find a similar view in CDT that I can switch to.
On 2006-11-29 23:32:17 -0600, Eric Woodruff <eric.services@ideoform.org> said:
> has this feature.
(file)
>> cool though.
>> it did.
Previous Topic:no swt-pi-gtk-3235
Next Topic:Short cut key
Current Time: Mon May 12 18:06:11 EDT 2025
Powered by FUDForum. Page generated in 0.09439 seconds
