Home » Eclipse Projects » Eclipse Platform » Blurred menu icons on Linux [HiDPI ]
Blurred menu icons on Linux [HiDPI ] [message #1826413] Fri, 24 April 2020 10:39 Go to next message
Working on UHD monitor i'm observing blurred icons in menu on Linux (gtk 3.22.30). This issue appears in Eclipse IDE also. Does anyone know the root cause of this? Is this GTK issue or we need to use some additional configuration? Thanks
Re: Blurred menu icons on Linux [HiDPI ] [message #1826426 is a reply to message #1826413] Fri, 24 April 2020 12:40 Go to previous messageGo to next message
As some of your icons are ok and some are not, please file a bug with Platform UI. Most likely you will get more response than in this forum.
Re: Blurred menu icons on Linux [HiDPI ] [message #1826540 is a reply to message #1826426] Sun, 26 April 2020 15:02 Go to previous messageGo to next message
Bug was reported: https://bugs.eclipse.org/bugs/show_bug.cgi?id=562468
Re: Blurred menu icons on Linux [HiDPI ] [message #1826570 is a reply to message #1826540] Mon, 27 April 2020 05:36 Go to previous message
I created this defect to report an issue with TreeViewer and LabelProvider. The problem with menu is idfferent. I'm not sure is this WAD or bug, that's why I'm trying my luck on the forum first.
Previous Topic:Populating choose list performance: Windows vs. LInux
Next Topic:Unable to set hierarchical project presentation by default
Current Time: Mon Jul 21 07:36:14 EDT 2025
Powered by FUDForum. Page generated in 0.32311 seconds
