Home » Eclipse Projects » GEF » Connection pointing back to the same figure
Connection pointing back to the same figure [message #182525] Wed, 25 May 2005 18:27 Go to next message
Originally posted by: eri_cao_apex.yahoo.com
The situation is that a connection starts from a figure will point back to
the same figure. That means the start point and end point will be on the
same figure. I tried all available connection routers, it seems that they
cannot handle that automatically. Anyone has seen this type of connection
before? If I can make it work by subclassing one of connection router
classes, what would be a good start point? I guess I need to find out how
the connection figure out endpoint.
Thanks a lot,
Eric
Re: Connection pointing back to the same figure [message #182654 is a reply to message #182525] Wed, 25 May 2005 20:17 Go to previous message
Your router can detect this case (when the start and end are the same
location) and introduce some points in the connection if there are none.
"Eric Cao" <eri_cao_apex@yahoo.com> wrote in message
news:d72ub5$5uf$1@news.eclipse.org...
> Thanks a lot,
> Eric
Previous Topic:Adding a new property to a graphical element
Next Topic:Line Routing Problem
Current Time: Sun Aug 31 23:13:40 EDT 2025
Powered by FUDForum. Page generated in 0.05062 seconds
