Home » Newcomers » Newcomers » Send Classpath Notification slowing down Eclipse(Send Classpath Notification slowing down Eclipse)
Send Classpath Notification slowing down Eclipse [message #1824623] Fri, 17 April 2020 08:08 Go to next message
I have been using the below version for sometime on Mac:
Eclipse IDE for Java Developers
Version: 2019-03 (4.11.0)
Build id: 20190314-1200
The past few days, suddenly, I see the tool slow down and spinning the wheel. I see that the "Send Classpath Notification" task running repeatedly consuming a lot of CPUs.
What does "Send Classpath Notification" do? Where is it sending notification to? Can we turn it off / disable it? If so, how to do this?
thanks
Re: Send Classpath Notification slowing down Eclipse [message #1824988 is a reply to message #1824623] Fri, 17 April 2020 08:45 Go to previous messageGo to next message
Do you have any additional plug-ins installed, like STS4?
Re: Send Classpath Notification slowing down Eclipse [message #1826381 is a reply to message #1824988] Fri, 24 April 2020 04:16 Go to previous messageGo to next message
I presume it has been installed by default. I did not install it explicitly.
After looking at this thread : https://marketplace.eclipse.org/content/spring-tools-4-aka-spring-tool-suite-4, I looked to the log file in the workspace and I see this error:
!ENTRY org.springframework.tooling.ls.eclipse.commons 4 0 2020-04-24 03:52:31.765
!MESSAGE
!STACK 0
java.lang.UnsupportedOperationException: No language server has registered to handle command 'sts4.classpath.XcpjnkLj'
at org.springframework.tooling.ls.eclipse.commons.LSP4ECommandExecutor.executeClientCommand(LSP4ECommandExecutor.java:42)
at org.springframework.tooling.jdt.ls.commons.classpath.SendClasspathNotificationsJob.flush(SendClasspathNotificationsJob.java:192)
at org.springframework.tooling.jdt.ls.commons.classpath.SendClasspathNotificationsJob.run(SendClasspathNotificationsJob.java:164)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Re: Send Classpath Notification slowing down Eclipse [message #1826382 is a reply to message #1826381] Fri, 24 April 2020 04:17 Go to previous message
I reloaded Spring related sites under Preferences->Install/Update->Available Software Sites.
I also disabled language servers for Spring.
It seems calm right now. I do not see CPU running high, etc.
[Updated on: Fri, 24 April 2020 04:43] by Moderator
Previous Topic:Oxygen update errors: "No repository found"
Next Topic:Unable to Install Eclipse on MAC
Current Time: Mon Jul 21 10:15:02 EDT 2025
Powered by FUDForum. Page generated in 0.07675 seconds
