Home » Newcomers » Newcomers » Oxygen update errors: "No repository found"(Problems with Oxygen updae)
Oxygen update errors: "No repository found" [message #1768214] Fri, 14 July 2017 13:53 Go to next message
For Eclipse Oxygen 64-bit on Windows 7 64-bit.
Oxygen has been working fine including having been able to cleanly update software at least once before.
But as of yesterday I was unable to complete a software update in response to a notification from Oxygen that updates were available. The update process halts with the following errors:
An error occurred while collecting items to be installed
session context was:(profile=DEclipseOXYGEN_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,com.gradleware.tooling.client,0.19.2.v20170713071601
No repository found containing: osgi.bundle,com.gradleware.tooling.model,0.19.2.v20170713071601
No repository found containing: osgi.bundle,com.gradleware.tooling.utils,0.19.2.v20170713071601
No repository found containing: osgi.bundle,org.eclipse.buildship.branding,2.1.1.v20170713-0942
No repository found containing: osgi.bundle,org.eclipse.buildship.core,2.1.1.v20170713-0942
No repository found containing: osgi.bundle,org.eclipse.buildship.stsmigration,2.1.1.v20170713-0942
No repository found containing: osgi.bundle,org.eclipse.buildship.ui,2.1.1.v20170713-0942
No repository found containing: osgi.bundle,org.gradle.toolingapi,3.5.0.v20170713071601
No repository found containing: org.eclipse.update.feature,org.eclipse.buildship,2.1.1.v20170713-0942**
Any ideas what I can do to get update working again?
Re: Oxygen update errors: "No repository found" [message #1768303 is a reply to message #1768214] Mon, 17 July 2017 04:19 Go to previous messageGo to next message
Unfortunately I've been having the same problem, and previous solutions to update errors (cleaning cache, adding removing http/https or slash at the end of the address etc.) did not work forme.
Re: Oxygen update errors: "No repository found" [message #1768307 is a reply to message #1768214] Mon, 17 July 2017 04:22 Go to previous messageGo to next message
Alright, I solved it.
Firstly, update address for Buildship is different than what default is.
From here: https://github.com/eclipse/buildship/blob/master/docs/user/Installation.md
It says:
http://download.eclipse.org/buildship/updates/e47/snapshots/2.x
However I have:
http://download.eclipse.org/buildship/updates/e47/releases/2.x
I added snapshots to the available update sites, and it's fixed.
Re: Oxygen update errors: "No repository found" [message #1768449 is a reply to message #1768307] Tue, 18 July 2017 16:43 Go to previous messageGo to next message
Tansel ALTINEL wrote on Mon, 17 July 2017 01:22
OK, excellent -- THANKS! for that.
I initially tried to tweak the URL by using Help > Install New Software > Manage. The error remained.
So what I ended up doing was using Help > Install New Software to search for buildship, then in Install New Software completely deleting all references to it. Next I used Eclipse Marketplace to reinstall Gradle from scratch. Even though I don't really need Gradle. That ended up putting the following URL in place:
Which seems to contradict what you provided. Which I in turn interpret as Eclipse update is too often broken. And too often requires one to be willing and able to go spelunking to solve its deficiencies. Regardless, I seem to have gotten it to work -- for now...
Cheers & thanks again...
[Updated on: Tue, 18 July 2017 19:02] by Moderator
Re: Oxygen update errors: "No repository found" [message #1769120 is a reply to message #1768449] Wed, 26 July 2017 14:19 Go to previous messageGo to next message
In my case Oxygen had update URL for Buidship as:
http://download.eclipse.org/buildship/updates/e46/releases/2.x
Note: that e46 is Neon version per https://github.com/eclipse/buildship/blob/master/docs/user/Installation.md
once I updated URL to Oxygen version (e47):
update was successful
Re: Oxygen update errors: "No repository found" [message #1826371 is a reply to message #1768449] Fri, 24 April 2020 03:11 Go to previous message
it works for me too.
1. uninstall buildship
2. install buildship
3. try installing Spring 3 add-on
done.
thanks!
Previous Topic:Installation
Next Topic:Send Classpath Notification slowing down Eclipse
Current Time: Mon Jul 21 07:22:27 EDT 2025
Powered by FUDForum. Page generated in 0.32038 seconds
