Exporting Eclipse to jar (with javafx) not working [message #1826333] |
Thu, 23 April 2020 12:41  |
I have a Java project on eclipse which uses JavaFx for the GUI. Everything works fine in the IDE itself, however when I attempt to export it to something I can share with others (i.e. a jar),my computer refuses to run it.
If I choose to "Package required libraries" I get this error:
Quote:Graphics Device initialization failed for : es2, sw
Error initializing QuantumRenderer: no suitable pipeline found
java.lang.RuntimeException: java.lang.RuntimeException: Error initializing QuantumRenderer: no suitable pipeline found
at com.sun.javafx.tk.quantum.QuantumRenderer.getInstance(QuantumRenderer.java:280)
at com.sun.javafx.tk.quantum.QuantumToolkit.init(QuantumToolkit.java:244)
at com.sun.javafx.tk.Toolkit.getToolkit(Toolkit.java:260)
at com.sun.javafx.application.PlatformImpl.startup(PlatformImpl.java:267)
at com.sun.javafx.application.PlatformImpl.startup(PlatformImpl.java:158)
at com.sun.javafx.application.LauncherImpl.startToolkit(LauncherImpl.java:658)
at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:678)
at com.sun.javafx.application.LauncherImpl.lambda$launchApplication$2(LauncherImpl.java:195)
at java.base/java.lang.Thread.run(Thread.java:830)
Caused by: java.lang.RuntimeException: Error initializing QuantumRenderer: no suitable pipeline found
at com.sun.javafx.tk.quantum.QuantumRenderer$PipelineRunnable.init(QuantumRenderer.java:94)
at com.sun.javafx.tk.quantum.QuantumRenderer$PipelineRunnable.run(QuantumRenderer.java:124)
... 1 more
Exception in thread "main" java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:567)
at org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader.main(JarRsrcLoader.java:61)
Caused by: java.lang.RuntimeException: No toolkit found
at com.sun.javafx.tk.Toolkit.getToolkit(Toolkit.java:272)
If I choose the "Extract" option for libraries instead, I get " Error: JavaFX runtime components are missing, and are required to run this application " on my Terminal.
I am using Eclipse version 2019-12 (4.14.0)
FUDForum. Page generated in 0.03728 seconds
