Home » Eclipse Projects » ACTF » How to get ACTF v1.6.(Please tell me how to get ACTF v1.6.)
How to get ACTF v1.6. [message #1826249] Tue, 21 April 2020 22:18 Go to next message
Hi there.
I am using miChecker on the Eclipse. However, these do not work on JVMs after version 11.0.5. Probably, these JVMs no longer support 32bit Java.
The version of ACTF I am using is 1.5.1. I think that there is a version of ACTF that supports Java of 64bit. It is ACTF 1.6.
https://projects.eclipse.org/projects/technology.actf/releases/1.6.0/plan
However, I couldn't find the visualization SDK or source code for this version.
https://download.eclipse.org/technology/actf/
https://git.eclipse.org/c/actf/org.eclipse.actf.examples.git/
So I have questions.
Is ACTF1.6 released now and is its source code available?
If available, please tell me how to get the visualization SDK and source code.
Regards and Thanks.
Re: How to get ACTF v1.6. [message #1826263 is a reply to message #1826249] Wed, 22 April 2020 08:17 Go to previous messageGo to next message
Thank you for using ACTF.
Due to migration of Eclipse build environment, we have to prepare new build system to provide new SDK. Unfortunately, however, it may take more time.
We made some updates from ACTF 1.5. So, please obtain latest code from our repository and use it in your environment.
Currently, we still use 32 bit Java to keep some legacy functions.
Please try 32bit JDKs, such as AdoptOpenJDK, etc.
https://adoptopenjdk.net/
Re: How to get ACTF v1.6. [message #1826361 is a reply to message #1826263] Thu, 23 April 2020 22:58 Go to previous messageGo to next message
Hi, Mr.Fukuda.
Thank you for your reply.
The ACTF has always helped me. I am looking forward to the 64-bit compatible ACTF.
By the way, under the current schedule, when will this be released?
Another question.
I could use ACTF v1.5.1 with Java v11.0.4. However, it is no longer available in Java v11.0.5.
I thought it was due to Java v11.0.5 no longer full supporting 32bit Java.
Is this correct for your opinion?
Thank you in advance.
Re: How to get ACTF v1.6. [message #1828684 is a reply to message #1826249] Tue, 16 June 2020 10:49 Go to previous message
Hi.
Thank you very much for answering the question the other day.
I have another question.
Please tell me about the license of ACTF module.
The ACTF module doesn't seem to work on OracleJDK 11.0.5 or later.
I needed to run ACTF with OracleJDK version 11.0.5 or later and was looking for a way to do that.
As a result, it seems that it can be achieved by deleting META-INF inside the some jar.
However, this method is an act of modifying the ACTF module.
Could you please tell me if this violates the license of ACTF?
Regards and Thanks.
Previous Topic:Rules WCAG 2.1
Next Topic:Accessibility Features for Eclipse in macOS / voiceover
Current Time: Mon Jul 21 11:52:45 EDT 2025
Powered by FUDForum. Page generated in 0.47249 seconds
