XPlus3 Tutorial not working because of deploying errors [message #1826110] |
Sun, 19 April 2020 14:19  |
Hello everybody,
I am new to 4diac and I just started to use 4 diac. I am trying to follow the tutorials on the eclipse/4diac page. The first tutorial - Use 4diac Locally (Blinking Tutorial) went pretty well. But then I tried to do the general example X+3 and I got a few errors when deploying the application.
So I tried to copy the example provided on the official website.
But when I try to deploy it I've got many errors (UNSUPPORTED TYPE, INVALID STATE, NO SUCH OBJECT and more...) in the deployment console.
I'm using 4diac IDE 1.12.0 and 4diac FORTE 1.12.0 + I also downloaded the FBDK from the HOLOBLOC page.
so I am able to Launch the FBRT with the cmd after writing:
java -jar device.jar FRAME RMT_FRAME BOUNDS "[100,100,250,400]" MGR_ID "localhost:61505"
The only thing not working is the Deployment. I hope u can help me :)
<!-- 127.0.0.1:61499 -->
<Request Action="QUERY" ID="0">
<FB Name="*" Type="*"/>
</Request>
<Response ID="0">
<FBList>
<FB name="CALC" type="EMB_RES"/>
</FBList>
</Response>
<Request Action="KILL" ID="1">
<FB Name="CALC" Type=""/>
</Request>
<Response ID="1"/>
<Request Action="DELETE" ID="2">
</Request>
<Response ID="2"/>
<Request Action="CREATE" ID="3">
<FB Name="CALC" Type="EMB_RES"/>
</Request>
<Response ID="3"/>
<!-- 127.0.0.1:61499: CALC -->
<Request Action="CREATE" ID="4">
<FB Name="INT2INT_1" Type="INT2INT"/>
</Request>
<Response ID="4"/>
<Request Action="CREATE" ID="5">
<FB Name="INT2INT_2" Type="INT2INT"/>
</Request>
<Response ID="5"/>
<Request Action="CREATE" ID="6">
<FB Name="publish4FBDK" Type="PUBLISH_1"/>
</Request>
<Response ID="6"/>
<Request Action="WRITE" ID="7">
<Connection Destination="publish4FBDK.QI" Source="1"/>
</Request>
<Response ID="7">
</Response>
<Request Action="WRITE" ID="8">
<Connection Destination="publish4FBDK.ID" Source="239.192.0.2:61499"/>
</Request>
<Response ID="8">
</Response>
<Request Action="CREATE" ID="9">
<FB Name="subscribeFromFBDK" Type="SUBSCRIBE_1"/>
</Request>
<Response ID="9"/>
<Request Action="WRITE" ID="10">
<Connection Destination="subscribeFromFBDK.QI" Source="1"/>
</Request>
<Response ID="10">
</Response>
<Request Action="WRITE" ID="11">
<Connection Destination="subscribeFromFBDK.ID" Source="239.192.0.2:61500"/>
</Request>
<Response ID="11">
</Response>
<Request Action="CREATE" ID="12">
<FB Name="GENERATED_1" Type="SUBSCRIBE_1"/>
</Request>
<Response ID="12"/>
<Request Action="WRITE" ID="13">
<Connection Destination="GENERATED_1.QI" Source="1"/>
</Request>
<Response ID="13">
</Response>
<Request Action="WRITE" ID="14">
<Connection Destination="GENERATED_1.ID" Source="225.0.0.1:61550"/>
</Request>
<Response ID="14">
</Response>
<Request Action="CREATE" ID="15">
<FB Name="GENERATED_2" Type="PUBLISH_1"/>
</Request>
<Response ID="15"/>
<Request Action="WRITE" ID="16">
<Connection Destination="GENERATED_2.QI" Source="1"/>
</Request>
<Response ID="16">
</Response>
<Request Action="WRITE" ID="17">
<Connection Destination="GENERATED_2.ID" Source="225.0.0.1:61551"/>
</Request>
<Response ID="17">
</Response>
<Request Action="CREATE" ID="18">
<FB Name="F_ADD" Type="F_ADD"/>
</Request>
<Response ID="18"/>
<Request Action="WRITE" ID="19">
<Connection Destination="F_ADD.IN2" Source="INT#3"/>
</Request>
<Response ID="19">
</Response>
<Request Action="CREATE" ID="20">
<Connection Destination="publish4FBDK.REQ" Source="INT2INT_1.CNF"/>
</Request>
<Response ID="20"/>
<Request Action="CREATE" ID="21">
<Connection Destination="publish4FBDK.INIT" Source="subscribeFromFBDK.INITO"/>
</Request>
<Response ID="21"/>
<Request Action="CREATE" ID="22">
<Connection Destination="subscribeFromFBDK.INIT" Source="START.COLD"/>
</Request>
<Response ID="22"/>
<Request Action="CREATE" ID="23">
<Connection Destination="subscribeFromFBDK.INIT" Source="START.WARM"/>
</Request>
<Response ID="23"/>
<Request Action="CREATE" ID="24">
<Connection Destination="INT2INT_2.REQ" Source="subscribeFromFBDK.IND"/>
</Request>
<Response ID="24"/>
<Request Action="CREATE" ID="25">
<Connection Destination="GENERATED_1.INIT" Source="START.COLD"/>
</Request>
<Response ID="25"/>
<Request Action="CREATE" ID="26">
<Connection Destination="GENERATED_1.INIT" Source="START.WARM"/>
</Request>
<Response ID="26"/>
<Request Action="CREATE" ID="27">
<Connection Destination="GENERATED_2.INIT" Source="GENERATED_1.INITO"/>
</Request>
<Response ID="27"/>
<Request Action="CREATE" ID="28">
<Connection Destination="F_ADD.REQ" Source="INT2INT_2.CNF"/>
</Request>
<Response ID="28"/>
<Request Action="CREATE" ID="29">
<Connection Destination="F_ADD.REQ" Source="GENERATED_1.IND"/>
</Request>
<Response ID="29"/>
<Request Action="CREATE" ID="30">
<Connection Destination="INT2INT_1.REQ" Source="F_ADD.CNF"/>
</Request>
<Response ID="30"/>
<Request Action="CREATE" ID="31">
<Connection Destination="GENERATED_2.REQ" Source="F_ADD.CNF"/>
</Request>
<Response ID="31"/>
<Request Action="CREATE" ID="32">
<Connection Destination="publish4FBDK.SD_1" Source="INT2INT_1.OUT"/>
</Request>
<Response ID="32"/>
<Request Action="CREATE" ID="33">
<Connection Destination="INT2INT_2.IN" Source="subscribeFromFBDK.RD_1"/>
</Request>
<Response ID="33"/>
<Request Action="CREATE" ID="34">
<Connection Destination="F_ADD.IN1" Source="INT2INT_2.OUT"/>
</Request>
<Response ID="34"/>
<Request Action="CREATE" ID="35">
<Connection Destination="INT2INT_1.IN" Source="F_ADD.OUT"/>
</Request>
<Response ID="35"/>
<Request Action="START" ID="36"/>
<Response ID="36"/>
<!-- 127.0.0.1:61505 -->
</Request>
<Response ID="0" Reason="INVALID_OPERATION"/>
<Request Action="CREATE" ID="1">
<FB Name="VIS" Type="PANEL_RESOURCE"/>
</Request>
<Response ID="1"/>
<!-- 127.0.0.1:61505: VIS -->
<Request Action="CREATE" ID="2">
<FB Name="INT2INT_0" Type="INT2INT"/>
</Request>
<Response ID="2" Reason="UNSUPPORTED_TYPE"/>
<FB Name="OUT_ANY" Type="OUT_ANY"/>
</Request>
<Response ID="3"/>
<Request Action="WRITE" ID="4">
<Parameter Reference="OUT_ANY.QI" Value="1"/>
</Request>
<Response ID="4"/>
<Request Action="WRITE" ID="5">
<Parameter Reference="OUT_ANY.W" Value="20"/>
</Request>
<Response ID="5"/>
<Request Action="WRITE" ID="6">
<Parameter Reference="OUT_ANY.TYPE" Value="INT"/>
</Request>
<Response ID="6"/>
<Parameter Reference="OUT_ANY.IVAL" Value="0"/>
</Request>
<Response ID="7"/>
<Request Action="CREATE" ID="8">
<FB Name="SUBSCRIBE_1_0" Type="SUBSCRIBE_1"/>
</Request>
<Response ID="8"/>
<Request Action="WRITE" ID="9">
<Parameter Reference="SUBSCRIBE_1_0.QI" Value="1"/>
</Request>
<Response ID="9"/>
<Parameter Reference="SUBSCRIBE_1_0.ID" Value="239.192.0.2:61499"/>
</Request>
<Response ID="10"/>
<Request Action="CREATE" ID="11">
<FB Name="PUBLISH_1_0" Type="PUBLISH_1"/>
</Request>
<Response ID="11"/>
<Request Action="WRITE" ID="12">
<Parameter Reference="PUBLISH_1_0.QI" Value="1"/>
</Request>
<Response ID="12"/>
<Parameter Reference="PUBLISH_1_0.ID" Value="239.192.0.2:61500"/>
</Request>
<Response ID="13"/>
<Request Action="CREATE" ID="14">
<FB Name="GENERATED_0" Type="PUBLISH_1"/>
</Request>
<Response ID="14"/>
<Request Action="WRITE" ID="15">
<Parameter Reference="GENERATED_0.QI" Value="1"/>
</Request>
<Response ID="15"/>
<Parameter Reference="GENERATED_0.ID" Value="225.0.0.1:61550"/>
</Request>
<Response ID="16"/>
<Request Action="CREATE" ID="17">
<FB Name="GENERATED_3" Type="SUBSCRIBE_1"/>
</Request>
<Response ID="17"/>
<Request Action="WRITE" ID="18">
<Parameter Reference="GENERATED_3.QI" Value="1"/>
</Request>
<Response ID="18"/>
<Parameter Reference="GENERATED_3.ID" Value="225.0.0.1:61551"/>
</Request>
<Response ID="19"/>
<FB Name="INT2INT" Type="INT2INT"/>
</Request>
<Response ID="20" Reason="UNSUPPORTED_TYPE"/>
<FB Name="IN_ANY" Type="IN_ANY"/>
</Request>
<Response ID="21"/>
<Request Action="WRITE" ID="22">
<Parameter Reference="IN_ANY.QI" Value="BOOL#1"/>
</Request>
<Response ID="22"/>
<Request Action="WRITE" ID="23">
<Parameter Reference="IN_ANY.W" Value="20"/>
</Request>
<Response ID="23"/>
<Request Action="WRITE" ID="24">
<Parameter Reference="IN_ANY.TYPE" Value="INT"/>
</Request>
<Response ID="24"/>
<Request Action="WRITE" ID="25">
<Parameter Reference="IN_ANY.IVAL" Value="0"/>
</Request>
<Response ID="25"/>
<Connection Destination="SUBSCRIBE_1_0.INIT" Source="PUBLISH_1_0.INITO"/>
</Request>
<Response ID="26"/>
<Connection Destination="OUT_ANY.INIT" Source="SUBSCRIBE_1_0.INITO"/>
</Request>
<Response ID="27"/>
<Connection Destination="PUBLISH_1_0.REQ" Source="INT2INT_0.CNF"/>
</Request>
<Response ID="28" Reason="NO_SUCH_OBJECT"/>
<Connection Destination="GENERATED_0.REQ" Source="INT2INT_0.CNF"/>
</Request>
<Response ID="29" Reason="NO_SUCH_OBJECT"/>
<Connection Destination="GENERATED_0.INIT" Source="START.COLD"/>
</Request>
<Response ID="30"/>
<Connection Destination="GENERATED_0.INIT" Source="START.WARM"/>
</Request>
<Response ID="31"/>
<Connection Destination="GENERATED_3.INIT" Source="GENERATED_0.INITO"/>
</Request>
<Response ID="32"/>
<Connection Destination="OUT_ANY.REQ" Source="INT2INT.CNF"/>
</Request>
<Response ID="33" Reason="NO_SUCH_OBJECT"/>
<Connection Destination="INT2INT.REQ" Source="SUBSCRIBE_1_0.IND"/>
</Request>
<Response ID="34" Reason="NO_SUCH_OBJECT"/>
<Connection Destination="INT2INT.REQ" Source="GENERATED_3.IND"/>
</Request>
<Response ID="35" Reason="NO_SUCH_OBJECT"/>
<Request Action="CREATE" ID="36">
<Connection Destination="INT2INT_0.REQ" Source="IN_ANY.IND"/>
</Request>
<Response ID="36" Reason="NO_SUCH_OBJECT"/>
<Request Action="CREATE" ID="37">
<Connection Destination="PUBLISH_1_0.INIT" Source="IN_ANY.INITO"/>
</Request>
<Response ID="37"/>
<Request Action="CREATE" ID="38">
<Connection Destination="IN_ANY.INIT" Source="START.WARM"/>
</Request>
<Response ID="38"/>
<Request Action="CREATE" ID="39">
<Connection Destination="IN_ANY.INIT" Source="START.COLD"/>
</Request>
<Response ID="39"/>
<Request Action="CREATE" ID="40">
<Connection Destination="PUBLISH_1_0.SD_1" Source="INT2INT_0.OUT"/>
</Request>
<Response ID="40" Reason="NO_SUCH_OBJECT"/>
<Request Action="CREATE" ID="41">
<Connection Destination="GENERATED_0.SD_1" Source="INT2INT_0.OUT"/>
</Request>
<Response ID="41" Reason="NO_SUCH_OBJECT"/>
<Request Action="CREATE" ID="42">
<Connection Destination="OUT_ANY.IN" Source="INT2INT.OUT"/>
</Request>
<Response ID="42" Reason="NO_SUCH_OBJECT"/>
<Request Action="CREATE" ID="43">
<Connection Destination="INT2INT.IN" Source="SUBSCRIBE_1_0.RD_1"/>
</Request>
<Response ID="43" Reason="NO_SUCH_OBJECT"/>
<Request Action="CREATE" ID="44">
<Connection Destination="INT2INT_0.IN" Source="IN_ANY.OUT"/>
</Request>
<Response ID="44" Reason="NO_SUCH_OBJECT"/>
<Request Action="START" ID="45"/>
<Response ID="45">
<FBStatus Status="RUNNING"/>
</Response>
<Request Action="WRITE" ID="46">
<Parameter Reference="BOUNDS" Value="[50,50,250,100]"/>
</Request>
<Response ID="46"/>
<Request Action="WRITE" ID="47">
<Parameter Reference="GRID" Value="[1,1]"/>
</Request>
<Response ID="47"/>
<Request Action="START" ID="48"/>
<Response ID="48">
</Response>
FUDForum. Page generated in 0.11462 seconds
