Home » Eclipse Projects » Eclipse Platform » Our of memory error - How to increase memory usage?
Our of memory error - How to increase memory usage? [message #182450] Tue, 20 January 2004 12:32 Go to next message
Originally posted by: dbshah.hotmail.com
I am using Eclipse 3.0M5 (build : 200311211210). I get either "out of
memory" error (with window suggesting that I exit out of IDE) or Eclipse
gets really slow after a while. I noticed in my TaskManager that Eclipse
memory usage never increases more than 115MB.
I read that eclipse.exe supports same -X parameters that java.exe would
support. I have tried supplying parameters "-Xms128M -Xmx256M" to
eclipse.exe at the startup hoping that max. heap size of memory would go
upto 256M. And this has not helped nor I have seen increase in memory usage.
Any other insights? Is there any other way to increase Eclipse memory usage?
Thanks.
Re: Our of memory error - How to increase memory usage? [message #182472 is a reply to message #182450] Tue, 20 January 2004 13:11 Go to previous messageGo to next message
specify the -X args using -vmargs as an argument for the eclipse executable
Darins
"D Shah" <dbshah@hotmail.com> wrote in message
news:bujokk$798$1@eclipse.org...
usage.
usage?
> Thanks.
Re: Our of memory error - How to increase memory usage? [message #182480 is a reply to message #182450] Tue, 20 January 2004 13:13 Go to previous messageGo to next message
Originally posted by: smesh.openrules.com
Put "-vmargs <java-vm-args>" at the end of your command line
PS. Search "command line" in Eclipse Help for more information.
Sam Mesh - http://openrules.com
It's better to view source code than comments to it.
Re: Our of memory error - How to increase memory usage? [message #182569 is a reply to message #182450] Tue, 20 January 2004 17:02 Go to previous message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
usage.
usage?
| Thanks.
do you feel the memory usage is accurate? hard to believe Eclipse itself
could be using so much memory. It starts a new process for the debugger
and running your program I believe.
You got lots of plugins going?
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFADaVpVbJM14DSCi0RAjADAKDFS2sasZ+tmxEKROjEGPhXelLIEgCg kS/G
SI7dvZVZcf1REWKYmMC4od4=
=Huzf
-----END PGP SIGNATURE-----
Previous Topic:Compiling Eclipse for Irix?
Next Topic:Who has to calculate download and install size for the feature?
Current Time: Fri Jul 25 23:48:15 EDT 2025
Powered by FUDForum. Page generated in 0.28526 seconds
