Home » Eclipse Projects » GEF » Is it possible to export Plug-ins as stand-alone application
| Is it possible to export Plug-ins as stand-alone application [message #182471] |
Wed, 25 May 2005 13:45  |
Hi, all,
I am develping a graphics editor as plug-in, but since running inside
workbench will confuse users of my application, so I expect it running as
standard application. Is it possible to export plug-ins, say Shapes, as
standard application with property and outline viewer as child windows?
Thanks and Regards,
Vince
| Re: Is it possible to export Plug-ins as stand-alone application [message #182717 is a reply to message #182481] |
Thu, 26 May 2005 12:23   |
That seems like what I am looking for. Thank you so much!
However, I got "org.eclipse.ui.part.editoractionbarcontributor cannot be
resolved" error message when I tried to run it.
I am using SDK3.1M7+GEF3.1M7.
Here is how what I did: I copied your file to plugin directory, launched
Eclipse, selected the shape.rcp in plugin view, right clicked it and
followed "Import". I added all libraries that is useful in my thought, but
still cannot reslove the problem. Someone has idea?
Thank you!
Vince
"Chris Aniszczyk" <none@us.ibm.com> wrote in message
news:d72jqi$p9s$1@news.eclipse.org...
> vince wrote:
>> Hi, all,
>> Thanks and Regards,
>> Vince
> I have an RCP-ified version of the shapes example here
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=91472
> You can look at that as a start if you want to use RCP and GEF.
| Re: Is it possible to export Plug-ins as stand-alone application [message #182724 is a reply to message #182717] |
Thu, 26 May 2005 13:47   |
> Thank you!
> Vince
>>vince wrote:
>>>Hi, all,
>>>Thanks and Regards,
>>>Vince
If you import the plugin as a project and launch it via the plugin.xml
you should be all good.
If you can post any verbose logs, let me know.
| Re: Is it possible to export Plug-ins as stand-alone application [message #182751 is a reply to message #182724] |
Thu, 26 May 2005 22:13   |
news:d7529g$gb6$1@news.eclipse.org...
>> but
>> Thank you!
>> Vince
>>>vince wrote:
>>>>Hi, all,
>>>>as
>>>>Thanks and Regards,
>>>>Vince
Hi, I still cannot run it :(
When you were saying import the plugin as a project, you mean File-->
Import-->External plugin and fragments, right?
I did that, but found plugin.xml was not in the project automatically, so I
added it to the project by hand.
What do you mean to launch it via the plugin.xml? I right click the file and
choose "Run As"-->"Run...", is it right?
However, error message occured as:
!SESSION 2005-05-26
22:10:22.450 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.5.0
Framework arguments: -product
org.eclipse.gef.examples.shapes.rcp.product -pdelaunch
Command-line arguments: -product
org.eclipse.gef.examples.shapes.rcp.product -data
U:\eclipse\runtime-workspace -dev
file:U:/eclipse/workspace/.metadata/.plugins/org.eclipse.pde .core/New_configuration/dev.properties -
pdelaunch -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2005-05-26 22:10:25.950
!MESSAGE Error installing bundle:
reference:file:plugins/org.eclipse.core.commands_3.1.0.jar/
!STACK 0
org.osgi.framework.BundleException: Bundle "org.eclipse.core.commands"
version "3.1.0" has already been installed from:
update@plugins/org.eclipse.core.commands_3.1.0.jar
at
org.eclipse.osgi.framework.internal.core.Framework.createAnd VerifyBundle(Framework.java:558)
at
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(Framework.java:823)
at
org.eclipse.osgi.framework.internal.core.Framework$2.run(Fra mework.java:738)
at
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.java:789)
at
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(Framework.java:733)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.i nstallBundle(BundleContextImpl.java:221)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:946)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:538)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:285)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:330 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:274)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
More error message is in the attachment. Do you have any more suggestions?
Vince
Current Time: Mon Nov 03 02:36:47 EST 2025
Powered by FUDForum. Page generated in 0.06267 seconds
