Re: Problem to create node from palette [message #1826185 is a reply to message #1826149] |
Mon, 20 April 2020 13:55   |
I can see the problem. If I had the odesign I could have commented better, but I will attempt to suggest some help:
Verify the type that the createProtection tool is applied to (. It needs to be applied to a specific information element (and if not, then you should at least navigate to a specific information element from from the element it is applied to). I do not see it in your tool (Screenshot2).
Specifically, it looks like you are applying the tool a Main element, from there you navigate to a System element (which hopefully was already created, otherwise navigation won't work). Then, from there you navigate to "infos", which is NOT a specific information element. You need to navigate to a specific information instance.
I would suggest that you:
1. try to change the first "change context" to var: container (so that you'll start from the element you clicked on).
2. Assuming the element you clicked on is typed "system" (i.e., the diagram is a representation of system; if it's a representation of another element let me know), create an information element.
3. After the information element creation, in the same tool, change context to the information element you just created and only then create a protection element.
If this works for you, we can continue.
Re: Problem to create node from palette [message #1831881 is a reply to message #1826185] |
Tue, 01 September 2020 14:01  |
I have a similar problem that I will try to explain usinf this example.
Let's suppose the protection is included in system.. and I want to create a new protection associated to the system by clicking on a key or stream.
In other words, by clicking on the key, a protection associated to the system of the clicked key is created. ( I want to click on a node, but this node is not the container)
I hope It's clear, otherwise I will implement something similar to get a better understanding of the problem.
Thank you
FUDForum. Page generated in 0.06657 seconds
