Home » Newcomers » Newcomers » Eclipse download issue(downloading software)
Eclipse download issue [message #1824296] Mon, 13 April 2020 10:59 Go to next message
I could not install the latest version of Eclipse for Java on my computer, can you help me with that. I have attached the error log thanks.
Re: Eclipse download issue [message #1824310 is a reply to message #1824296] Mon, 13 April 2020 13:13 Go to previous messageGo to next message
I can see it says there is no write access to file:/C:/Users/Jwalit/.p2/pool, but also that you're installing into C:\Users\Jwalit.000. Have you been renaming your user folder? Delete the .eclipse folder and the .p2 folder in your home folder if you've renamed your home folder.
Re: Eclipse download issue [message #1824324 is a reply to message #1824310] Mon, 13 April 2020 16:54 Go to previous messageGo to next message
I have tried to create a new folder but it will not let me install it there because it is 'ready only'. How to get pass that? I have deleted the folders. You can see the image attached.
Re: Eclipse download issue [message #1824332 is a reply to message #1824324] Tue, 14 April 2020 00:40 Go to previous message
You don't have write access to C:\Users nor would I expect you've have such write access. Don't install to a folder for which you don't have write access. Install into your real home folder or to some disk location where you have write access.
Previous Topic:Installing BIRT
Next Topic:JUnit test in Eclipse RCP with maven leads to ClassDefNotFoundError
Current Time: Sun Jul 20 22:54:51 EDT 2025
Powered by FUDForum. Page generated in 0.09896 seconds
