Home » Newcomers » Newcomers » Does SWT applications need special packages to be installed to be run?
Does SWT applications need special packages to be installed to be run? [message #1824166] Wed, 08 April 2020 17:22 Go to next message
If I make a SWT program, does it need special packages installed on computers where it should run? Or does it run everywhere where java is? Thanks in advance.
Re: Does SWT applications need special packages to be installed to be run? [message #1824176 is a reply to message #1824166] Wed, 08 April 2020 23:46 Go to previous message
It will run on any supported 64 bit OS (Windows, a not-too-old MacOS, and a not-too old Linux) that has a 64 bit Java 8 or higher.
Previous Topic:Can't start the eclipse on macOS High Sierra 10.13.6
Next Topic:Help in Setting JavaFX 11 SDK in Eclipse 2019-06
Current Time: Sun Jul 20 22:59:24 EDT 2025
Powered by FUDForum. Page generated in 0.08465 seconds
