How many key-pairs do I need to access core repos? [message #1823923] |
Fri, 03 April 2020 18:21  |
Up until several days ago, I've been able to do installs, with occasional (maybe 1-2 failures per 10 tries), the failures due mostly to timeouts, which have generally worked on first or second retries.
For the last couple of weeks, I've been blocked doing any installs, due to the following 100%-reproduceable git clone failure:
Performing Git Clone ssh://anonymous@git.eclipse.org:29418/platform/eclipse.platform.common (master)
Cloning Git repo ssh://anonymous@git.eclipse.org:29418/platform/eclipse.platform.common to P:\eclipse\SDK\pde-master\git\eclipse.platform.common
java.lang.Exception: org.eclipse.jgit.api.errors.TransportException: ssh://anonymous@git.eclipse.org:29418/platform/eclipse.platform.common: No more authentication methods available
at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.perform(GitCloneTaskImpl.java:907)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3827)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:3770)
Using the cmd-line git, I found that while I have (at least read-only) access to git://git.eclipse.org/gitroot/platform/eclipse.platform.debug, I don't have access to ssh://anonymous@git.eclipse.org:29418/platform/eclipse.platform.common (all accesses via Oomph).
I was under the impression that my personal github key-pair was sufficient to access all egit repos, but the above indicates otherwise. What do I need to do to get access to platform/eclipse.platform.common, and any other repos needed to do a Committers install?
-rjs
FUDForum. Page generated in 0.05264 seconds
