Home » Modeling » TMF (Xtext) » location not found for modeling/tmf/xtext/updates/releases/xpand/(location not found: http://download.eclipse.org/modeling/tmf/xtext/updates/releases/xpand/)
location not found for modeling/tmf/xtext/updates/releases/xpand/ [message #1823722] Tue, 31 March 2020 13:29 Go to next message
I am using the following repo as my Xtext Update Site:
http://download.eclipse.org/modeling/tmf/xtext/updates/composite/releases/
In ths compositeArtifacts, there is a reference to the location: http://download.eclipse.org/modeling/tmf/xtext/updates/releases/xpand/
However, this location is no longer available. is this a bug?
Best regards
Re: location not found for modeling/tmf/xtext/updates/releases/xpand/ [message #1823876 is a reply to message #1823722] Fri, 03 April 2020 08:17 Go to previous messageGo to next message
no its not.
either the composite should have been adapted or xpand should still be there
can you please create an issue at github.com/eclipse/xtext
[Updated on: Fri, 03 April 2020 08:18] by Moderator
Re: location not found for modeling/tmf/xtext/updates/releases/xpand/ [message #1823880 is a reply to message #1823876] Fri, 03 April 2020 08:35 Go to previous messageGo to next message
reopened https://github.com/eclipse/xtext/issues/1708
Re: location not found for modeling/tmf/xtext/updates/releases/xpand/ [message #1823907 is a reply to message #1823880] Fri, 03 April 2020 11:30 Go to previous messageGo to next message
@Jab can you please retest (or tommorrow depending on caching work on eclipse side)
Re: location not found for modeling/tmf/xtext/updates/releases/xpand/ [message #1823917 is a reply to message #1823907] Fri, 03 April 2020 15:14 Go to previous messageGo to next message
@Christian A better hint. You should be subscribed to cross-project-dev on which Ed has plugged the need to use his P2 repo analysis to clean up the numerous bad repos.
Re: location not found for modeling/tmf/xtext/updates/releases/xpand/ [message #1823918 is a reply to message #1823917] Fri, 03 April 2020 15:35 Go to previous message
@ed i am. i also know all kind of eds reports. this one i missed
Previous Topic:Grammar support
Next Topic:Any VSCode Directions Updates?
Current Time: Fri Jul 25 02:04:11 EDT 2025
Powered by FUDForum. Page generated in 0.27687 seconds
