Home » Language IDEs » C / C++ IDE (CDT) » Type GObject could not be resolved(Eclipse resolved all header, but shows all every member as unresolved )
Type GObject could not be resolved [message #1823835] Thu, 02 April 2020 15:31 Go to next message
After I created a Makefile project to play around with glib and GObject I'm having this issue. Eclipse shows that GObject could not be resolved, when the header file
#include <glib-2.0/glib-object.h>
for it is resolved. here is the screenshots
index.php/fa/37733/0/
I also able to go by link and open glib-object.h header file in eclipse, so I assume it resolved,
index.php/fa/37734/0/
as well as I'm able to build the project using eclipse, here is my makefile:
index.php/fa/37735/0/
Could someone point me what I'm doing wrong or how it can be resolved?
Re: Type GObject could not be resolved [message #1823912 is a reply to message #1823835] Fri, 03 April 2020 13:39 Go to previous messageGo to next message
You have to tell two different things where your headers can be found:
  1. the compiler via the makefile
  2. the CDT Indexer
They are independent.
To do (1) Set the include path for each compiler at:
Project --> Properties --> C/C+ Build --> Settings --> Tool Settings tab --> <compiler> --> Includes
This only works when Eclipse is generating the Makefile.
To do (2) Set the include path as a User Entry at:
Project --> Properties --> C/C++ General --> Preprocessor Include Paths, Macros etc. --> Entries tab --> <language>
You can do both with:
Project --> Properties --> C/C++ General --> Paths and Smbols
but you need the CDT Managed Build Settings provider enabled in
Project --> Properties --> C/C++ General --> Preprocessor Include Paths, Macros etc. --> Providers tab
[Updated on: Fri, 03 April 2020 13:45] by Moderator
Re: Type GObject could not be resolved [message #1823914 is a reply to message #1823912] Fri, 03 April 2020 14:51 Go to previous messageGo to next message
I tried to check your suggestion, but at first point I found that my project settings doesn't contain C/C++Build entry, than I compared it with another project in my workspace that doesn't use glib and works fine, and I found that it has C/C++Built entry in project properties. So I checked the project nature and found this
index.php/fa/37741/0/
The reason why is that so it's because I created project using Makefile configuration which is stated as Experimental
index.php/fa/37742/0/
So I recreated the project as C/C++ Managed Build and than mentioned by you properties appeared.
index.php/fa/37743/0/
index.php/fa/37744/0/
But the initial problem still presents. I don't know, maybe I miss something, but to me it looks like all tools is set and includes are in place.
[Updated on: Fri, 03 April 2020 14:54] by Moderator
Re: Type GObject could not be resolved [message #1823928 is a reply to message #1823914] Fri, 03 April 2020 21:59 Go to previous message
I've had similar problems with glib.
Sometimes just rebuilding the index works.
Sometimes it just takes time.
I know. Not much help.
As for Makefile Projects, I import the code instead of starting a new project.
File --> Import --> C/C++ --> Existing Code as Makefile Project
Previous Topic:ESP-IDF Plugin
Next Topic:Make "[ all Configurations ]" default when editing C/C++ properties
Current Time: Sun Jul 20 21:20:33 EDT 2025
Powered by FUDForum. Page generated in 0.26258 seconds
