Home » Eclipse Projects » Oomph » Close Projects after import
Close Projects after import [message #1823736] Wed, 01 April 2020 02:20 Go to next message
is it possible to close specific projects after importing them into the workspace?
Reason is: We have some reactor projects which are needed rarly, however should be in the workspace. If they are open, all launch configs in our projects are shown multiple times in the launch dialog.
I have seen "Close Project" in the commands table, however I don't know how to trigger a command (or if the table is even used for that, might only be for setting key bindings).
thanks in advance
Hannes
Re: Close Projects after import [message #1823741 is a reply to message #1823736] Wed, 01 April 2020 03:49 Go to previous messageGo to next message
No, there is no task to close projects.
Is there some overlap of actual underlying file system folders between the folder structure of these projects you want closed versus the projects that you want opened? I.e., what causes the duplication of launchers?
Re: Close Projects after import [message #1823742 is a reply to message #1823741] Wed, 01 April 2020 03:54 Go to previous messageGo to next message
Yes its a maven structure with different modules:
The workspace looks like this:
test
--- pom.xml
--- test1WithLauncher
test1WithLauncher
--- pom.xml
So the launcher will be found in 2 projects and therefore listed twice. I think the launch dilaog needs a fix and filter duplicated entries with the same duplicated path, but as long as this is not working the solution was, closing the test reactor project and only open it manually if we need to add a new test project.
[Updated on: Wed, 01 April 2020 03:55] by Moderator
Re: Close Projects after import [message #1823746 is a reply to message #1823742] Wed, 01 April 2020 05:04 Go to previous messageGo to next message
I could suggest something that uses a feature most people aren't aware exists. Assuming you have the .project files in an SCM (Git?), you could add a filter to the .project to not show the nested contents (e.g., subprojects) in the workspace tree representation. You can do this via the context menu Properties... on the project and then go to Resource -> Resource Filters. For example, on all the Oomph projects we have an "Exclude all" filter that applies to "Folders" and uses "Project Relative Path" "matches" "target". This ensures that when we run the local Maven/Tycho build that all the "target" folders are not visible in the resource tree; that avoids all kinds of duplicates avoids that search files searches contents you really don't want to see because they're all derived. Looking at this properties dialog, it looks like you could even use this to hide just the *.launch files...
Re: Close Projects after import [message #1823747 is a reply to message #1823746] Wed, 01 April 2020 05:10 Go to previous message
Thanks Ed, that solved the problem.
Previous Topic:Use eclipse.user.password in github project model.
Next Topic:Properties-view cell focus very slow in 4.15
Current Time: Sun Jul 20 20:18:22 EDT 2025
Powered by FUDForum. Page generated in 0.05003 seconds
