Home » Eclipse Projects » GEF » Renaming an EditPart global action
Renaming an EditPart global action [message #182373] Tue, 24 May 2005 13:25 Go to next message
Originally posted by: brett.bock.embarcadero.com
I have code working that allows the user to edit the label figure in an
EditPart via an EditPolicy derived from DirectEditPolicy. Now I would like
to hook this up to a global rename action. The Logic & Flow examples appear
to just hook into key press events and process via an F2 key press.
Shouldn't we be able to hook into the global action registry?
I also noticed there is a DirectEditAction class, but I don't see any
examples where it is used.
Thank you for your help,
Brett
Re: Renaming an EditPart global action [message #182597 is a reply to message #182373] Wed, 25 May 2005 19:24 Go to previous message
Sure, you can. Look at declareGlobalActionKeys() and addGlobalActionKey()
in your ActionBarContributor. The action that you would add to your action
registry would be the same as the DirectEditAction, but with the correct ID.
However, I think that doing this is not a good idea. The Rename action
shows up under the File menu, and can be confusing since it's really only
meant for renaming files. I don't think JDT hooks into that actions when
renaming methods, variables, etc. Only for Java class files. You might
want to follow their example.
"Brett Bock" <brett.bock@embarcadero.com> wrote in message
news:d6vo7h$c2r$1@news.eclipse.org...
> Hello,
like
appear
> Brett
Previous Topic:Property Viewer for Connection
Next Topic:can i set the Alpha value of Figure?
Current Time: Fri Jul 18 12:50:04 EDT 2025
Powered by FUDForum. Page generated in 0.06586 seconds
