Home » Language IDEs » Java Development Tools (JDT) » Eclipse Not Responding Errors
Eclipse Not Responding Errors [message #1823172] Fri, 20 March 2020 16:47 Go to next message
The content assist keeps locking up Eclipse on me. I am getting error:
Problem During Content Assist (Not Responding)
The 'com.github.camel-tooling.eclipse.client.id.1' proposal computer from the 'com.github.camel-tooling.eclipse.client' plugin did not complete normally. The extension took too long to return from the 'computerCompletionProposals()' operation.
To avoid this message, disable the 'com.github.camel-tooling.eclipse.client' plug-in or disable the 'Basic Proposal category on the content-assist preference page. Note that disabling the category will also affect completion proposal from the following plug-ins: org.jboss.tools.ws.jaxrs.ui.
In Workspace Log:
java.util.concurrent.TimeoutException
	at java.util.concurrent.CompletableFuture.timedGet(CompletableFuture.java:1771)
	at java.util.concurrent.CompletableFuture.get(CompletableFuture.java:1915)
	at org.eclipse.lsp4e.operations.rename.LSPRenameHandler.isEnabled(LSPRenameHandler.java:118)
	at org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(HandlerProxy.java:300)
	at org.eclipse.ui.internal.handlers.E4HandlerProxy.canExecute(E4HandlerProxy.java:78)
	at sun.reflect.GeneratedMethodAccessor2.invoke(Unknown Source)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:318)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:252)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:173)
	at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.isEnabled(HandlerServiceHandler.java:62)
	at org.eclipse.core.commands.Command.isEnabled(Command.java:832)
	at org.eclipse.ui.menus.CommandContributionItem.isEnabled(CommandContributionItem.java:917)
	at org.eclipse.ui.menus.CommandContributionItem.updateMenuItem(CommandContributionItem.java:531)
	at org.eclipse.ui.menus.CommandContributionItem.update(CommandContributionItem.java:484)
	at org.eclipse.ui.menus.CommandContributionItem.lambda$2(CommandContributionItem.java:323)
	at org.eclipse.ui.menus.CommandContributionItem.updateCommandProperties(CommandContributionItem.java:327)
	at org.eclipse.ui.menus.CommandContributionItem.lambda$1(CommandContributionItem.java:294)
	at org.eclipse.core.commands.Command$1.run(Command.java:529)
	at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
	at org.eclipse.core.commands.Command.fireCommandChanged(Command.java:522)
	at org.eclipse.core.commands.Command.lambda$0(Command.java:1002)
	at org.eclipse.core.commands.AbstractHandler.fireHandlerChanged(AbstractHandler.java:77)
	at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.fireHandlerChanged(HandlerServiceHandler.java:180)
	at org.eclipse.ui.internal.handlers.E4HandlerProxy.handlerChanged(E4HandlerProxy.java:115)
	at org.eclipse.ui.internal.handlers.HandlerProxy.lambda$0(HandlerProxy.java:248)
	at org.eclipse.ui.internal.services.EvaluationReference.evaluate(EvaluationReference.java:110)
	at org.eclipse.ui.internal.services.EvaluationReference.changed(EvaluationReference.java:94)
	at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:108)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.processScheduled(EclipseContext.java:364)
	at org.eclipse.e4.core.internal.contexts.EclipseContext.set(EclipseContext.java:379)
	at org.eclipse.ui.internal.services.EvaluationService$1.changed(EvaluationService.java:79)
	at org.eclipse.ui.internal.e4.compatibility.SelectionService.updateSelection(SelectionService.java:152)
	at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:213)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$3.run(PartServiceImpl.java:253)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(PartServiceImpl.java:250)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:774)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:683)
	at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:97)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.lambda$0(ContributedPartRenderer.java:63)
	at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4105)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1037)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1046)
	at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1469)
	at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1432)
	at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java:2942)
	at org.eclipse.swt.widgets.Widget.wmSetFocus(Widget.java:2216)
	at org.eclipse.swt.widgets.Control.WM_SETFOCUS(Control.java:5393)
	at org.eclipse.swt.widgets.Canvas.WM_SETFOCUS(Canvas.java:432)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4790)
	at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:335)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4749)
	at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
	at org.eclipse.swt.widgets.Control.forceFocus(Control.java:1100)
	at org.eclipse.swt.widgets.Control.setFocus(Control.java:3427)
	at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:1074)
	at org.eclipse.ui.texteditor.AbstractTextEditor.setFocus(AbstractTextEditor.java:6235)
	at org.eclipse.ui.texteditor.StatusTextEditor.setFocus(StatusTextEditor.java:147)
	at org.eclipse.jdt.internal.ui.javaeditor.JavaEditor.setFocus(JavaEditor.java:2374)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.delegateSetFocus(CompatibilityPart.java:222)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:324)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:246)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:147)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.focusGui(PartRenderingEngine.java:795)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.setFocus(ContributedPartRenderer.java:106)
	at org.eclipse.swt.custom.CTabItem.setFocus(CTabItem.java:379)
	at org.eclipse.swt.custom.CTabFolder.setFocus(CTabFolder.java:2663)
	at org.eclipse.swt.widgets.Control.fixFocus(Control.java:1055)
	at org.eclipse.swt.widgets.Control.setVisible(Control.java:3938)
	at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3216)
	at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3224)
	at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1876)
	at org.eclipse.swt.custom.CTabFolder.lambda$0(CTabFolder.java:330)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3922)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3524)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1160)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1049)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:658)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:557)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:154)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:150)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1447)
I have tried Eclipse 2019-06, 2019-12R, and 2020-03.
I only started to have issues when our IT department wiped my computer for Windows 10 OS Upgrade. But no other issues with other programs.
Any ideas?
Re: Eclipse Not Responding Errors [message #1823453 is a reply to message #1823172] Thu, 26 March 2020 16:40 Go to previous messageGo to next message
Have you tried contacting the developers of that plug-in? Apparently, this is smth that is not developed at eclipse.org. I wouldn't even know where you get this from :)
Re: Eclipse Not Responding Errors [message #1823495 is a reply to message #1823453] Fri, 27 March 2020 08:39 Go to previous messageGo to next message
Does the stack trace show anything? The error message doesn't always pop-up, sometimes it just starts getting very slow, and the above error is the log.
Re: Eclipse Not Responding Errors [message #1823515 is a reply to message #1823495] Fri, 27 March 2020 18:14 Go to previous message
Yes, in addition(!) to asking the developers of com.github.camel-tooling.eclipse.client, you might consider asking the folks developing org.eclipse.lsp4e, see https://projects.eclipse.org/projects/technology.lsp4e
Previous Topic:Connection profile problem
Next Topic:Please take java.util.Objects methods into account for potential NullPointer checks
Current Time: Sat Aug 30 19:38:40 EDT 2025
Powered by FUDForum. Page generated in 0.03647 seconds
