Home » Modeling » TMF (Xtext) » Add EAnnotation in generated Ecore
Add EAnnotation in generated Ecore [message #1823342] Wed, 25 March 2020 05:41 Go to next message
I'm using Xtext 2.20.
I want to add a specific eAnnotation in some of my eClasses in my generated Ecore from my grammar.
I tried to implement IXtext2EcorePostProcessor (through https://www.dietrich-it.de/xtext/2011/07/22/customizing-xtext-metamodel-inference-using-xtend2.html), but it seems no more possible to use it.
Indeed in the following,
public class MyCustomEcoreGenerator extends XtextGenerator {
public MyCustomEcoreGenerator() {
new XtextStandaloneSetup() {
public Injector createInjector() {
return Guice.createInjector(new XtextRuntimeModule() {
public Class<? extends IXtext2EcorePostProcessor> bindIXtext2EcorePostProcessor() {
return MyXtext2EcorePostProcessor.class;
}.createInjectorAndDoEMFRegistration();
@Override annotation must be removed above bindIXtext2EcorePostProcessor
Then, when I try to run MyGenerator.mwe2, I get the following error :
A binding to org.eclipse.xtext.xtext.ecoreInference.IXtext2EcorePostProcessor was already configured at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:57).
at org.eclipse.xtext.XtextRuntimeModule.configureIXtext2EcorePostProcessor(XtextRuntimeModule.java:115)
I also tried to declare MyXtext2EcorePostProcessor through
bindEcorePostProcessor() , but bindEcorePostProcessor() it is not accessible in MyGrammarRuntimeModule.xtend
postprocessor = MyXtext2EcorePostProcessor {} , but it seems not possible to use it anymore in MyGenerator.mwe2
So I'm a little bit confused. How it is possible to add a specific eAnnotation to some of my eClasses in my generated Ecore ?
Any help would be appreciated.
[Updated on: Wed, 25 March 2020 05:43] by Moderator
Re: Add EAnnotation in generated Ecore [message #1823343 is a reply to message #1823342] Wed, 25 March 2020 05:43 Go to previous messageGo to next message
overrding
org.eclipse.xtext.XtextRuntimeModule.configureIXtext2EcorePostProcessor(Binder)
and do a binding there should do the trick
Re: Add EAnnotation in generated Ecore [message #1823348 is a reply to message #1823343] Wed, 25 March 2020 06:47 Go to previous message
Thank you Christian for your prompt answer.
I tried to do this:
return Guice.createInjector(new MyCustomEcoreXtextRuntimeModule());
private class MyCustomEcoreXtextRuntimeModule extends XtextRuntimeModule {
public void configureIXtext2EcorePostProcessor(Binder binder) {
binder.bind(IXtext2EcorePostProcessor.class).to(MyXtext2EcorePostProcessor.class);
class MyXtext2EcorePostProcessor implements IXtext2EcorePostProcessor {
and it does the trick !
[Updated on: Wed, 25 March 2020 06:56] by Moderator
Previous Topic:formatter generatestub problem
Next Topic:Maven dependencies
Current Time: Mon Jul 21 04:25:25 EDT 2025
Powered by FUDForum. Page generated in 4.42012 seconds
