Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Error while Importing(Error-Importing 4diac system from 1.11.x to 1.12.0)
Error while Importing [message #1823320] Tue, 24 March 2020 17:35 Go to next message
While importing a 4diac system(.sys) from 1.11.3 to 1.12.0, it threw exemptions, could not open the application and gave a message as "Failed to create the part's controls"
I could open "System Configuration" and it was all ok!
As an attachment, you can find the log file and a screenshot!
Re: Error while Importing [message #1823321 is a reply to message #1823320] Tue, 24 March 2020 17:55 Go to previous messageGo to next message
The problem seems to be that your types are missing. Therefore connections can not be parsed. If you used the import IEC 61499 system wizard: this wizard is severely broken.
Importing an 4diac IDE project please use the import existing project into workspace option.
Re: Error while Importing [message #1823322 is a reply to message #1823321] Tue, 24 March 2020 18:01 Go to previous message
Thank you! It worked now.
Previous Topic:Problems to compile FORTE+Modbus
Next Topic:Writing CSV File Using CSVWriter
Current Time: Mon Jul 21 10:02:46 EDT 2025
Powered by FUDForum. Page generated in 0.07723 seconds
