Home » Language IDEs » PHP Development Tools (PDT) » mysql_fetch_array()/mysql_fetch_assoc()/mysql_fetch_row()/mysql_num_rows etc... expects parameter 1
mysql_fetch_array()/mysql_fetch_assoc()/mysql_fetch_row()/mysql_num_rows etc... expects parameter 1 [message #1823218] Mon, 23 March 2020 00:01
I am trying to select data from a MySQL table, but I get one of the following error messages:
mysql_fetch_array() expects parameter 1 to be resource, boolean given
or
mysqli_fetch_array() expects parameter 1 to be mysqli_result, boolean given
or
Call to a member function fetch_array() on boolean / non-object
This is my code:
$username = $_POST['username'];
$password = $_POST['password'];
$result = mysql_query('SELECT * FROM Users WHERE UserName LIKE $username');
while($row = mysql_fetch_array($result)) {
echo $row['FirstName'];
The same applies to code like
$result = mysqli_query($mysqli, 'SELECT ...');
// mysqli_fetch_array() expects parameter 1 to be mysqli_result, boolean given
while( $row=mysqli_fetch_array($result) ) {
and
$result = $mysqli->query($mysqli, 'SELECT ...');
// Call to a member function fetch_assoc() on a non-object
while( $row=$result->fetch_assoc($result) ) {
and
$result = $pdo->query('SELECT ...', PDO::FETCH_ASSOC);
// Invalid argument supplied for foreach()
foreach( $result as $row ) {
and
$stmt = $mysqli->prepare('SELECT ...');
// Call to a member function bind_param() on a non-object
$stmt->bind_param(...);
and
$stmt = $pdo->prepare('SELECT ...');
// Call to a member function bindParam() on a non-object
$stmt->bindParam(...);
Previous Topic:ptp-sync folder size
Next Topic:PHP built in Server
Current Time: Mon Jul 21 17:35:36 EDT 2025
Powered by FUDForum. Page generated in 0.27835 seconds
