Home » Language IDEs » Java Development Tools (JDT) » Redundant Null Check and Dead Code
Redundant Null Check and Dead Code [message #1823098] Thu, 19 March 2020 09:30 Go to next message
I have code like this:
  protected void processObject(EObject object)
    if (recordAnyTypeNSDecls && object instanceof AnyType)
      FeatureMap featureMap = ((AnyType)object).getAnyAttribute();
      for (Map.Entry<String, String> entry : helper.getAnyContentPrefixToURIMapping().entrySet())
        Object uri = entry.getValue();
        featureMap.add(extendedMetaData.demandFeature(ExtendedMetaData.XMLNS_URI, entry.getKey(), false), uri == null ? "" : uri);
    if (object != null)
      objects.push(object);
      types.push(OBJECT_TYPE);
      if (extendedMetaData != null)
        EStructuralFeature mixedFeature = extendedMetaData.getMixedFeature(object.eClass());
        if (mixedFeature != null)
          mixedTargets.push((FeatureMap)object.eGet(mixedFeature));
        else
          mixedTargets.push(null);
      else
    else
      types.push(ERROR_TYPE);
It claims that "object != null" is a redundant check. But I don't think it's redundant. As a result it also complains the the final else is dead code.
Is this a regression?
Re: Redundant Null Check and Dead Code [message #1823108 is a reply to message #1823098] Thu, 19 March 2020 10:39 Go to previous messageGo to next message
I'm unable to reproduce due to missing context - I fail to expand the snippet into something compilable :(
Re: Redundant Null Check and Dead Code [message #1823114 is a reply to message #1823108] Thu, 19 March 2020 11:45 Go to previous messageGo to next message
The attached file has the same problem. It was hard to reproduce. This file has no non-JRE dependencies. If I delete a single variable, the problem goes away. Very strange!
  • Attachment: Test.java
    (Size: 2.90KB, Downloaded 95 times)
Re: Redundant Null Check and Dead Code [message #1823121 is a reply to message #1823114] Thu, 19 March 2020 13:31 Go to previous messageGo to next message
The strangeness and intolerance of gratuitous variable pruning in a repro is very reminiscent of [1] which was fixed in 4.15M1.
Ed Willink
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=459397
Re: Redundant Null Check and Dead Code [message #1823131 is a reply to message #1823121] Thu, 19 March 2020 17:32 Go to previous message
Thanks Eds, you hit the nail: 64 variables.
Over to https://bugs.eclipse.org/561280
Previous Topic:New Resource Leak Warnings...
Next Topic:Include QuickAccess text field
Current Time: Mon Jul 21 01:26:09 EDT 2025
Powered by FUDForum. Page generated in 0.28196 seconds
