Home » Language IDEs » C / C++ IDE (CDT) » Where is C99 setting or build settings at all in Eclipse 2019-12 (4.14.0) CDT 9.9.0.201909091956(I cannot find any C build settings in my Eclipse / CDT setup)
Where is C99 setting or build settings at all in Eclipse 2019-12 (4.14.0) CDT 9.9.0.201909091956 [message #1822950] Tue, 17 March 2020 06:00 Go to next message
I have a C project and no matter how much I google and go through different menus I cannot find where I can set indexer to use C99 (I get a report for bool not recognised in the editor though I include stdbool.h).
The code compiles just fine, but to I do compile in Eclipse using GNU Make 3.18 on macOS 0.13.6.
Can't find any other build settings for that matter but this is no big deal as I build from command line anyway.
wbr Kusti
Re: Where is C99 setting or build settings at all in Eclipse 2019-12 (4.14.0) CDT 9.9.0.2019090919 [message #1822960 is a reply to message #1822950] Tue, 17 March 2020 08:02 Go to previous messageGo to next message
The command for the Indexer to get the compiler builtins is in:
Project --> Properties --> C/C++ General --> Preprocessor Include Paths, Macros etc. --> Providers tab --> CDT GCC Builtin Compiler Settings
It defaults to
${COMMAND} ${FLAGS} -E -P -v -dD "${INPUTS}"
Where ${COMMAND} is from the declared tool chain.
You could set the compiler language flag there.
Usually, its value is gcc
Or, since the flag just causes a macro setting, you could add the macro as a User Entry in
Project --> Properties --> C/C++ General --> Preprocessor Include Paths, Macros etc. --> Entries tab --> CDT User Setting Entries
Re: Where is C99 setting or build settings at all in Eclipse 2019-12 (4.14.0) CDT 9.9.0.2019090919 [message #1822961 is a reply to message #1822960] Tue, 17 March 2020 08:10 Go to previous messageGo to next message
Sorry, I must be dence, I cannot find it (Preprocessor Include Paths, Macros etc.)
index.php/fa/37598/0/
index.php/fa/37597/0/
Re: Where is C99 setting or build settings at all in Eclipse 2019-12 (4.14.0) CDT 9.9.0.2019090919 [message #1822963 is a reply to message #1822961] Tue, 17 March 2020 08:27 Go to previous messageGo to next message
Looks like you are using a plugin that's a modified CDT.
This is what the standard CDT looks like:
index.php/fa/37599/0/
Maybe you can set the language macro with C/C++ Include Paths and Symbols
but I can't be sure since I don't have the plugin.
Re: Where is C99 setting or build settings at all in Eclipse 2019-12 (4.14.0) CDT 9.9.0.2019090919 [message #1822964 is a reply to message #1822963] Tue, 17 March 2020 08:30 Go to previous messageGo to next message
I can't edit the image because the horizontal scroll is missing
This is from the help files:
https://help.eclipse.org/photon/topic/org.eclipse.cdt.doc.user/reference/cdt_u_prop_general_sd_providers.htm?cp=13_4_7_0_4_6_1
Re: Where is C99 setting or build settings at all in Eclipse 2019-12 (4.14.0) CDT 9.9.0.2019090919 [message #1822966 is a reply to message #1822964] Tue, 17 March 2020 08:33 Go to previous messageGo to next message
Hmmm, that one was for the photon version.
Here's the one from 2019-12
https://help.eclipse.org/2019-12/index.jsp?topic=%2Forg.eclipse.cdt.doc.user%2Freference%2Fcdt_u_prop_general_sd_providers.htm&cp%3D13_4_7_0_4_6_1
Re: Where is C99 setting or build settings at all in Eclipse 2019-12 (4.14.0) CDT 9.9.0.2019090919 [message #1822967 is a reply to message #1822963] Tue, 17 March 2020 08:36 Go to previous message
Thanks, the pic does not show but I don't think that matters.
The interesting thing is that I today loaded the plugin so I would have expected it to be standard and up to date.
I will investigate my plugins situation.
Thanks once more.
Previous Topic:Print array in Debugger console
Next Topic:Arduino Library Management With Symlinks
Current Time: Mon Jul 21 13:52:46 EDT 2025
Powered by FUDForum. Page generated in 0.28252 seconds
