Home » Eclipse Projects » Remote Application Platform (RAP) » BUild Rap runtime from source (RAP runtime local build )
BUild Rap runtime from source [message #1822943] Tue, 17 March 2020 04:07 Go to next message
I try to build Rap runtime from https://github.com/eclipse/rap.
As of Readme all i need t do is just run `mvn clean verify`
however on mac I get
Computing target platform for MavenProject: org.eclipse.rap:org.eclipse.rap.rwt:3.12.0-SNAPSHOT @ /Users/anuradhagunasekara/development/repository/github/rap/bundles/org.eclipse.rap.rwt/pom.xml
[INFO] Resolving dependencies of MavenProject: org.eclipse.rap:org.eclipse.rap.rwt:3.12.0-SNAPSHOT @ /Users/anuradhagunasekara/development/repository/github/rap/bundles/org.eclipse.rap.rwt/pom.xml
[INFO] {osgi.os=macosx, osgi.ws=cocoa, org.eclipse.update.install.features=true, osgi.arch=x86_64}
[ERROR] Cannot resolve project dependencies:
[ERROR] Software being installed: org.eclipse.rap.rwt 3.12.0.qualifier
[ERROR] Missing requirement: org.eclipse.rap.rwt 3.12.0.qualifier requires 'package javax.servlet [2.3.0,5.0.0)' but it could not be found
[ERROR]
[ERROR] See http://wiki.eclipse.org/Tycho/Dependency_Resolution_Troubleshooting for help.
[ERROR] Cannot resolve dependencies of MavenProject: org.eclipse.rap:org.eclipse.rap.rwt:3.12.0-SNAPSHOT @ /Users/anuradhagunasekara/development/repository/github/rap/bundles/org.eclipse.rap.rwt/pom.xml: See log for details -> [Help 1]
[ERROR]
Re: BUild Rap runtime from source [message #1822945 is a reply to message #1822943] Tue, 17 March 2020 04:56 Go to previous messageGo to next message
Yes, you are right, I can reproduce this behavior with Java 11.
We still use a 1.8 JVM to build RAP as this is our defined target environment. Although it is theoretically possible to use a higher version of the JVM to build than the execution environment later, this makes everything a lot easier.
If you really need to build RAP from the source code, I recommend downgrading your JVM for now.
In the long run, my job is to overhaul the entire build and bring it up to date. Perhaps we have the necessary time for 3.13, but it is already too late for 3.12.
Thanks and regards,
Markus
Re: BUild Rap runtime from source [message #1822949 is a reply to message #1822945] Tue, 17 March 2020 05:54 Go to previous messageGo to next message
thanks for prompt reply
export JAVA_HOME=`/usr/libexec/java_home -v1.8`
$ java -version
now show
java version "1.8.0_141"
Java(TM) SE Runtime Environment (build 1.8.0_141-b15)
Java HotSpot(TM) 64-Bit Server VM (build 25.141-b15, mixed mode
mvn -version
Apache Maven 3.6.1 (d66c9c0b3152b2e69ee9bac180bb8fcc8e6af555; 2019-04-05T00:30:29+05:30)
Maven home: /usr/local/Cellar/maven/3.6.1/libexec
Java version: 1.8.0_141, vendor: Oracle Corporation, runtime: /Library/Java/JavaVirtualMachines/jdk1.8.0_141.jdk/Contents/Home/jre
Default locale: en_US, platform encoding: UTF-8
OS name: "mac os x", version: "10.14.6", arch: "x86_64", family: "mac"
I'm still getting same issue, did I miss anything ?
[Updated on: Tue, 17 March 2020 05:56] by Moderator
Re: BUild Rap runtime from source [message #1822953 is a reply to message #1822949] Tue, 17 March 2020 06:20 Go to previous messageGo to next message
There is one more thing...
My successful test was using one of my older Maven installations on disk:
$ mvn -version
Apache Maven 3.3.9 (bb52d8502b132ec0a5a3f4c09453c07478323dc5; 2015-11-10T17:41:47+01:00)
Maven home: /opt/maven/apache-maven-3.3
Java version: 11.0.6, vendor: Ubuntu
Java home: /usr/lib/jvm/java-11-openjdk-amd64
Default locale: en_GB, platform encoding: UTF-8
OS name: "linux", version: "5.3.0-7642-generic", arch: "amd64", family: "unix"
But when I am using the same version as you did I can reproduce your error
$ mvn -version
Apache Maven 3.6.1
Maven home: /usr/share/maven
Java version: 11.0.6, vendor: Ubuntu, runtime: /usr/lib/jvm/java-11-openjdk-amd64
As I said: Something to fix by an overhaul of the build system.
At the moment I don't think it can cause any problems when someone consumes the binary builds.
Markus
Re: BUild Rap runtime from source [message #1822954 is a reply to message #1822953] Tue, 17 March 2020 06:23 Go to previous messageGo to next message
ah let me try downgrade my maven as workaround.
just backstory
Im trying to fix https://bugs.eclipse.org/bugs/show_bug.cgi?id=561155 and possible provide patch
Re: BUild Rap runtime from source [message #1822957 is a reply to message #1822953] Tue, 17 March 2020 06:49 Go to previous message
Apache Maven 3.3.9 did the trick however I report a bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=561185
[Updated on: Tue, 17 March 2020 06:53] by Moderator
Previous Topic:ClassCastException layout.GridData cannot cast to FillData in RAP 3.11
Next Topic:Chrome does reuse HTTP Connection for F5 -> old session isn't destroyed
Current Time: Tue Sep 16 11:28:41 EDT 2025
Powered by FUDForum. Page generated in 0.03896 seconds
