Home » Modeling » TMF (Xtext) » Understanding lambdas
Understanding lambdas [message #1822841] Sun, 15 March 2020 10:14 Go to next message
I have been trying to make this code read a text file line by line by calling 'lineIterator.next()' . Is that how it should be used ? I see that it stops after the first line.
val lineReader = new LineReader(r);
val AbstractIterator<String> lineIterator = [|
val result = lineReader.readLine
if (result==null)
self.endOfData
return result
The file is
Text
Red
Blue
Text
Red
Blue
and the call is like this.
do {
line = lineIterator.next()
println('File contents [' + line + ']')
}while( line != null )
It prints
File contents [Text]
File contents [null]
I may be missing something here. I can use plain Java but I think this Guava library should work too. Right ?
Mohan
Re: Understanding lambdas [message #1822842 is a reply to message #1822841] Sun, 15 March 2020 10:20 Go to previous messageGo to next message
Hi, i cannot reproduce this. can you please provide a complete example.
package x
import com.google.common.collect.AbstractIterator
import com.google.common.io.LineReader
import java.io.InputStreamReader
import java.io.ByteArrayInputStream
import java.nio.charset.StandardCharsets
class Y {
	def static void main(String[] args) {
		val lineReader = new LineReader(new InputStreamReader(
			new ByteArrayInputStream('''
				Text
				Red
				Blue
				Text
				Red
				Blue
			'''.toString.getBytes(StandardCharsets.UTF_8))
			if (result == null)
				self.endOfData
			return result
		var line = ""
		do {
		} while (line != null)
Re: Understanding lambdas [message #1822843 is a reply to message #1822842] Sun, 15 March 2020 10:39 Go to previous messageGo to next message
Hello Mohan!
You can get some inpiration from the Xtend Movies example:
https://www.eclipse.org/xtend/documentation/102_moviesexample.html#parsing-the-data
Hope that helps: Tamás
Re: Understanding lambdas [message #1822845 is a reply to message #1822843] Sun, 15 March 2020 11:05 Go to previous message
Thanks.
Test code took shape like this because I thought a simple fluent API could help.
This could have a lurking bug though.
package com.test.generator
import java.io.FileReader
import java.util.ArrayList
import java.util.List
import java.util.Optional
import java.util.regex.Pattern
class DefinitionBuilderTest {
  IteratorBuilderTest builder = null
  static String line = null
  def DefinitionBuilderTest buildFileIterator(){
  	//try(
  	    val reader = new FileReader('D:/eclipse-jee-2019-12-M1-win32-x86_64/text.txt')//){
        val lineReader = new LineReader(reader)
			if (result == null)
				self.endOfData
			return result
  	     builder = new IteratorBuilderTest(Optional.of(lineIterator));
  	    return this
  def String next(){
  		return builder.next();
		val definitionBuilder = new DefinitionBuilderTest
		val dataIterator = definitionBuilder.buildFileIterator()
		do {
			line = dataIterator.next()
   class IteratorBuilderTest{
   var AbstractIterator<String> lineIterator = null;
  	new ( Optional<AbstractIterator<String>> fileIterator ){
  		this.lineIterator = fileIterator.get();
  	 def String next(){
  	 	if( lineIterator.hasNext()){
	  	   return lineIterator.next()
Previous Topic:Token Splitting via custom lexer?
Next Topic:Get textual representation from model
Current Time: Mon Jul 21 04:20:57 EDT 2025
Powered by FUDForum. Page generated in 0.07964 seconds
