Home » Eclipse Projects » Sirius » Specifying the default model object to create in new model creation
Specifying the default model object to create in new model creation [message #1822535] Mon, 09 March 2020 10:35 Go to next message
Is there a way to set the default model object to be created when creating a new Sirius-based domain-specific model?
Is there a way to limit the possible selection?
Currently, when creating a new model (based on a metamodel) the default is blank and all of my metamodel classes are available. I got negative feedback from users regarding this.
Thank you,
Avi
Re: Specifying the default model object to create in new model creation [message #1822538 is a reply to message #1822535] Mon, 09 March 2020 11:05 Go to previous messageGo to next message
Hi Avi,
You have several way to do this.
The first one is a simple customization of the code generated by EMF for your domain : open the yourDomainModelWizard class from your .editor plugin. See yourDomainModelWizardInitialObjectCreationPage.getInitialObjectNames() method. You can also configure the model initialization in createInitialModel().
You could also provide a custom project creation wizard to create the project, the domain model and do additional steps, as done by EcoreTools see https://github.com/eclipse/ecoretools/blob/master/org.eclipse.emf.ecoretools.design.ui/src/org/eclipse/emf/ecoretools/design/ui/wizard/EcoreModelerWizard.java
Re: Specifying the default model object to create in new model creation [message #1822691 is a reply to message #1822538] Wed, 11 March 2020 09:53 Go to previous message
Great. Thanks!
I do think it could be nice to have a Sirius feature to handle this, as well as adding viewpoints to the created model automatically.
I understand that this is somewhere between ECORE and Sirius, but, in the end, a good integration could result in a modeling system that is bigger than the sum of its constituents.
Previous Topic:Generating code with Acceleo from Sirius digram model
Next Topic:Generation of ID's
Current Time: Mon Jul 21 00:29:05 EDT 2025
Powered by FUDForum. Page generated in 0.04345 seconds
