Home » Newcomers » Newcomers » Replacement for IPluginDescriptor(Replacement for IPluginDescriptor in new eclipse version 2019-12)
Replacement for IPluginDescriptor [message #1822236] Mon, 02 March 2020 04:23 Go to next message
We have eclipse plugin application build on eclipse version 4.3 which used IPluginDescriptor. Now, we want to build the same application on latest eclipse version i.e. eclipse 2019-12. While doing so we are facing issues with deprecated interface for example IPluginDescriptor.
As found from eclipse forums IPluginDescriptor was only supported by by plug-ins which explicitly require the org.eclipse.core.runtime.compatibility plug-in. But this is not used anymore as eclipse 4.6 removed it.
What is replacement for "org.eclipse.core.runtime.compatibility" or "IPluginDescriptor" in latest eclipse version 2019-12.
Below is the code that we need to modify which requires replacement of IPluginDescriptor :
IPluginDescriptor pluginDescriptor =
getRootElement().getDeclaringExtension().getDeclaringPluginDescriptor();
return pluginDescriptor.getPlugin();
Looking for your response.
Priya
Re: Replacement for IPluginDescriptor [message #1822257 is a reply to message #1822236] Mon, 02 March 2020 11:09 Go to previous messageGo to next message
You'll have to make due with methods like this one to which you can pass the names you see in the configuration elements.
org.eclipse.core.runtime.Platform.getBundle(String)
Re: Replacement for IPluginDescriptor [message #1822292 is a reply to message #1822257] Tue, 03 March 2020 05:23 Go to previous messageGo to next message
Can you suggest way to get Plugin based on extension.
Re: Replacement for IPluginDescriptor [message #1822316 is a reply to message #1822292] Tue, 03 March 2020 15:10 Go to previous messageGo to next message
To do what? Odds are there's a cleaner way to solve whatever problem led you to the Plugin instance or the plug-in descriptor.
Re: Replacement for IPluginDescriptor [message #1822433 is a reply to message #1822316] Fri, 06 March 2020 00:12 Go to previous messageGo to next message
Below is the piece of code :
* Discovers the ProviderLocation extensions and loads the pluginList
* @param registry The plugin registry to search for the extension
private void discoverProviders(IExtensionRegistry registry)
IExtensionPoint myPoint =
registry.getExtensionPoint(PLUGIN_ID, PROVIDER_EXTENSION);
if (myPoint == null)
/* No extensions found for the ProviderLocation, no sweet. We just
* move on.
return;
IExtension[] extensions = myPoint.getExtensions();
for (int i = 0; i < extensions.length; i++)
String pluginName = "";
try
Plugin plugin =
extensions[i].getDeclaringPluginDescriptor().getPlugin();
if (pluginList_.containsKey(plugin))
continue;
IConfigurationElement[] elements =
extensions[i].getConfigurationElements();
pluginName = elements[0].getAttribute(EXTENSION_NAME);
The line highlighted in bold is giving error as getDeclaringPluginDescriptor() has been deprecated.
Could you please suggest what can be used here??
Re: Replacement for IPluginDescriptor [message #1822686 is a reply to message #1822433] Wed, 11 March 2020 07:53 Go to previous messageGo to next message
Any suggestion for above query?
Re: Replacement for IPluginDescriptor [message #1822689 is a reply to message #1822686] Wed, 11 March 2020 09:21 Go to previous messageGo to next message
It would be better to understand what you needed the object for, otherwise it's not clear what the answer should be.
For example, to get the plug-in ID, you can call IExtension#getContributor() and then just ask the IContributor its name. I don't know if that's what you actually needed from the Plugin or descriptor object, though.
Re: Replacement for IPluginDescriptor [message #1823014 is a reply to message #1822689] Wed, 18 March 2020 03:35 Go to previous messageGo to next message
Thanks for the suggestion. Currently it has resolved my one of compilation issue.
Another suggestion which I could need is replacement for getPluginRegistry() in below line of code or way to get appropriate value :
System.setProperty("javax.net.ssl.trustStore", Platform.getPluginRegistry().getPluginDescriptor("com.abc.xyz").find(new Path("wb-server.jks")).getPath());
I tried to use getExtensionRegistry() in place of getPluginRegistry() but could not find appropriate method which will return a String which is required for System.setProperty.
Can you provide a way to handle this?
[Updated on: Wed, 18 March 2020 09:44] by Moderator
Re: Replacement for IPluginDescriptor [message #1823022 is a reply to message #1823014] Wed, 18 March 2020 05:51 Go to previous message
Probably Platform.getBundle(...).getEntry(...).
Previous Topic:Another Eclipse update problem...
Next Topic:How did Eclipse update from 2019-12 to 2020-03 without running the installer?
Current Time: Thu Jul 24 00:02:28 EDT 2025
Powered by FUDForum. Page generated in 0.09817 seconds
