Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Building 4DIAC Forte on macOS with luajit leads to segfault on start
Building 4DIAC Forte on macOS with luajit leads to segfault on start [message #1822450] Fri, 06 March 2020 10:37 Go to next message
I've tried to build 4diac forte on macOS with dynamic type loading feature enabled. I've proceeded according to the tutorial and compilation went fine, but when I started forte, it has halted with a segmentation fault.
In LUAJIT_LIBRARY property, I've tried to specify several luajit lib instances:
* static lib <LUAJIT_REPO>/src/libluajit.a
* dynamic lib <LUAJIT_REPO>/src/libluajit.so
* dynamic lib installed by juajit's make at /usr/local/lib/libluajit-5.1.2.0.5.dyliib
What have I done wrong?
Re: Building 4DIAC Forte on macOS with luajit leads to segfault on start [message #1822567 is a reply to message #1822450] Tue, 10 March 2020 02:55 Go to previous messageGo to next message
Have you tried luajit in other OS? It didn't work correctly(the behavior is not correct) most of the time when executing, (I can only export to C++), how about you?
Re: Building 4DIAC Forte on macOS with luajit leads to segfault on start [message #1822585 is a reply to message #1822567] Tue, 10 March 2020 05:23 Go to previous messageGo to next message
In other OS we used the branch v2.0 of luajit-2.0 repo. Did you try that branch? Have you copied the libraries to the same folder as forte, or you added the library folders to PATH?
Re: Building 4DIAC Forte on macOS with luajit leads to segfault on start [message #1822603 is a reply to message #1822585] Tue, 10 March 2020 08:35 Go to previous messageGo to next message
can you run your 4diac FORTE with gdb so that we can see a backtrace on where the segfault is happening. This can help us trace this down.
Re: Building 4DIAC Forte on macOS with luajit leads to segfault on start [message #1822653 is a reply to message #1822603] Tue, 10 March 2020 16:03 Go to previous messageGo to next message
Thank you for your responses!
No, unfortunately, I have no such options.
Can you elaborate on this? Does this mean I shouldn't rely on dynamic type loading at all?
Yes, I was trying v2.0.5 for the first time and now tried v2.0.0 with the same effect.
Sure! Here what I got:
lldb) target create "forte"
Current executable set to 'forte' (x86_64).
(lldb) b lj_api.c:626
Breakpoint 1: where = libluajit-5.1.2.dylib`lua_pushcclosure + 12 at lj_api.c:626:3, address = 0x00007fff04c5b99c
(lldb) run
Process 95645 launched: '/usr/local/bin/forte' (x86_64)
libluajit-5.1.2.dylib was compiled with optimization - stepping may behave oddly; variables may not be available.
Process 95645 stopped
* thread #1, queue = 'com.apple.main-thread', stop reason = breakpoint 1.1
    frame #0: 0x000000010045d99c libluajit-5.1.2.dylib`lua_pushcclosure(L=0x0000000000000000, f=(libluajit-5.1.2.dylib`luaopen_base at lib_base.c:673), n=0) at lj_api.c:626:3 [opt]
   623 	LUA_API void lua_pushcclosure(lua_State *L, lua_CFunction f, int n)
   624 	{
   625 	  GCfunc *fn;
-> 626 	  lj_gc_check(L);
   627 	  api_checknelems(L, n);
   628 	  fn = lj_func_newC(L, (MSize)n, getcurrenv(L));
   629 	  fn->c.f = f;
Target 0: (forte) stopped.
(lldb) frame info
(lldb) frame variable
(lua_State *) L = 0x0000000000000000
(lua_CFunction) f = 0x00000001004a77e0 (libluajit-5.1.2.dylib`luaopen_base at lib_base.c:673)
(int) n = 0
(GCfunc *) fn = <variable not available>
(lldb) thread backtrace
  * frame #0: 0x000000010045d99c libluajit-5.1.2.dylib`lua_pushcclosure(L=0x0000000000000000, f=(libluajit-5.1.2.dylib`luaopen_base at lib_base.c:673), n=0) at lj_api.c:626:3 [opt]
    frame #1: 0x00000001004b3a12 libluajit-5.1.2.dylib`luaL_openlibs(L=0x0000000000000000) at lib_init.c:41:5 [opt]
    frame #2: 0x0000000100028588 forte`CLuaEngine::CLuaEngine(this=0x00000001007001a0) at luaengine.cpp:47:3
    frame #3: 0x00000001000285a5 forte`CLuaEngine::CLuaEngine(this=0x00000001007001a0) at luaengine.cpp:45:26
    frame #4: 0x00000001000220fa forte`CResource::CResource(this=0x0000000100700630, pa_pstInterfaceSpec=0x00000001000c4968, pa_nInstanceNameId=4294967295, pa_acFBConnData="", pa_acFBVarsData="��
") at resource.cpp:53:19
    frame #5: 0x000000010009ab0b forte`CDevice::CDevice(this=0x0000000100700630, pa_pstInterfaceSpec=0x00000001000c4968, pa_nInstanceNameId=4294967295, pa_acFBConnData="", pa_acFBVarsData="��
") at device.h:49:9
    frame #6: 0x000000010009a9e7 forte`RMT_DEV::RMT_DEV(this=0x0000000100700630) at RMT_DEV.cpp:28:3
    frame #7: 0x000000010009ab75 forte`RMT_DEV::RMT_DEV(this=0x0000000100700630) at RMT_DEV.cpp:29:32
    frame #8: 0x00000001000021a1 forte`createDev(pa_acMGRID="localhost:61499") at main.cpp:65:15
    frame #9: 0x00000001000022bd forte`main(argc=1, arg=0x00007ffeefbff7c8) at main.cpp:91:5
    frame #10: 0x00007fff6911b7fd libdyld.dylib`start + 1
    frame #11: 0x00007fff6911b7fd libdyld.dylib`start + 1
Re: Building 4DIAC Forte on macOS with luajit leads to segfault on start [message #1822655 is a reply to message #1822653] Tue, 10 March 2020 16:34 Go to previous messageGo to next message
Just a guess, shouldn't it be related to this issue. Yet I am not aware of forte build internals, so can't test the proposed solution by myself.
Re: Building 4DIAC Forte on macOS with luajit leads to segfault on start [message #1822656 is a reply to message #1822655] Tue, 10 March 2020 16:48 Go to previous messageGo to next message
It looks like this is the issue. You could specify the two options (-pagezero_size 10000 -image_base 100000000) as linker flags in CMake gui for testing. Tick the advanced option and search for Cmake Linker flags.
Re: Building 4DIAC Forte on macOS with luajit leads to segfault on start [message #1822667 is a reply to message #1822656] Wed, 11 March 2020 04:21 Go to previous messageGo to next message
Unfortunately, specifying these options gain no effect.
Re: Building 4DIAC Forte on macOS with luajit leads to segfault on start [message #1822687 is a reply to message #1822667] Wed, 11 March 2020 07:54 Go to previous messageGo to next message
@Mr. Zoitl,
I tested several examples with luajit with the lastest forte and 4diac IDE, but didn't get the correct behavior, so i don't know if the forte with luajit is still not stable?
Re: Building 4DIAC Forte on macOS with luajit leads to segfault on start [message #1822696 is a reply to message #1822667] Wed, 11 March 2020 11:17 Go to previous messageGo to next message
Radimir Sorokin wrote on Wed, 11 March 2020 08:21
To bad. From your backtrace I can see that the method luaL_newstate(); returns a null pointer. I googled a bit and sofar these linker options seem to be the only right solution. However as I don't have a mac for testing I don't know how to correclty get 4diac FORTE linked with them.
Re: Building 4DIAC Forte on macOS with luajit leads to segfault on start [message #1822697 is a reply to message #1822687] Wed, 11 March 2020 11:18 Go to previous message
joy woo wrote on Wed, 11 March 2020 11:54
@Mr. Zoitl,
As you can see in our Bugzilla [1] there are still several issues open regarding lua. As always any support here is more then welcome.
[1] https://bugs.eclipse.org/bugs/buglist.cgi?bug_status=UNCONFIRMED&bug_status=NEW&bug_status=ASSIGNED&bug_status=REOPENED&list_id=19225902&product=4DIAC&query_format=advanced
Previous Topic:Adapter connect to several FBs
Next Topic:4DIAC TCP client
Current Time: Sun Jul 20 23:38:35 EDT 2025
Powered by FUDForum. Page generated in 0.04848 seconds
