Home » Language IDEs » C / C++ IDE (CDT) » Failed to execute MI command: -exec-run
Failed to execute MI command: -exec-run [message #1822556] Mon, 09 March 2020 15:26 Go to next message
Hello, in the first place thanks in advance...
Today I using eclipse for the first time, compile well an execute well, but when I click on debug the ide launch a message with: Failed to execute MI command: -exec-run
This is my version of ide:
Version: 2019-12 (4.14.0)
Build id: 20191212-1212
Any idea?
index.php/fa/37548/0/
index.php/fa/37549/0/
  • Attachment: error.PNG
    (Size: 24.92KB, Downloaded 10287 times)
  • Attachment: dbgconf.PNG
    (Size: 53.75KB, Downloaded 10309 times)
Re: Failed to execute MI command: -exec-run [message #1822634 is a reply to message #1822556] Tue, 10 March 2020 11:48 Go to previous messageGo to next message
Error code: 0xc0000135 is caused by a missing DLL.
https://answers.microsoft.com/en-us/windows/forum/all/error-code-0xc0000135/2f20f9c4-594e-4464-9862-69926be45218
You can try running Dependency Walker to find out which but it's likely cygwin.dll
http://www.dependencywalker.com/
You might not have everything installed.
or may simply need to adjust the DLL search order
https://docs.microsoft.com/en-us/windows/win32/dlls/dynamic-link-library-search-order
Make sure you read:
https://help.eclipse.org/2019-12/index.jsp?topic=%2Forg.eclipse.cdt.doc.user%2Fconcepts%2Fcdt_c_before_you_begin.htm
[Updated on: Tue, 10 March 2020 13:22] by Moderator
Re: Failed to execute MI command: -exec-run [message #1822652 is a reply to message #1822634] Tue, 10 March 2020 15:37 Go to previous messageGo to next message
Thanks son much, I will check it,
Re: Failed to execute MI command: -exec-run [message #1826556 is a reply to message #1822652] Mon, 27 April 2020 01:46 Go to previous messageGo to next message
were you ever able to resolve?
might be related to what I am encountering too.
Re: Failed to execute MI command: -exec-run [message #1826577 is a reply to message #1826556] Mon, 27 April 2020 07:41 Go to previous messageGo to next message
Look for you have eclipse folder and execute eclipse from there, don,t make direct access.
Be in touch
Re: Failed to execute MI command: -exec-run [message #1828719 is a reply to message #1826577] Wed, 17 June 2020 10:14 Go to previous messageGo to next message
hello, I enconter the same problem with eclipse and GDB. Have you solved it ? Could you be more specific about the fix?
thanks very much.
x cui
Re: Failed to execute MI command: -exec-run [message #1828720 is a reply to message #1826577] Wed, 17 June 2020 10:16 Go to previous messageGo to next message
hi, what do you mean by "don't make direct access"? thanks.
Re: Failed to execute MI command: -exec-run [message #1828729 is a reply to message #1828720] Wed, 17 June 2020 15:10 Go to previous messageGo to next message
Execute eclipse from eclipse folder not
Re: Failed to execute MI command: -exec-run [message #1828730 is a reply to message #1828719] Wed, 17 June 2020 15:11 Go to previous messageGo to next message
You have to execute eclipse from eclipse folder.
Re: Failed to execute MI command: -exec-run [message #1828740 is a reply to message #1828730] Wed, 17 June 2020 19:56 Go to previous messageGo to next message
hi, are you using eclipse on Windows ,and execute the eclipse.exe in the Eclipse folder? This is how to solve the GDB issue?
I am running eclipse on win7, still get the error.
I tried to start GDB on eclipse with 3 diffrent PCs, all attempts failed. I still don't get your hints, is there another way to run eclipse instead of running the eclipse.exe ?
thanks.
[Updated on: Thu, 18 June 2020 01:11] by Moderator
Re: Failed to execute MI command: -exec-run [message #1828771 is a reply to message #1826556] Thu, 18 June 2020 06:54 Go to previous messageGo to next message
hello , have you got around the GDB failure on Eclipse CPP? is it working now?
thanks.
[Updated on: Thu, 18 June 2020 07:17] by Moderator
Re: Failed to execute MI command: -exec-run [message #1828774 is a reply to message #1822634] Thu, 18 June 2020 07:45 Go to previous messageGo to next message
hello David,
I have tried to debug program usning latest
Eclipse CPP on 5 different machines (windows 7 /10installed). On 3 out of 5 computers , this GDB error occurs. So it is not the bad user settings that cause the error. looks like this is a mingw issue?
xiaolei
[Updated on: Thu, 18 June 2020 09:10] by Moderator
Re: Failed to execute MI command: -exec-run [message #1828787 is a reply to message #1828774] Thu, 18 June 2020 10:35 Go to previous messageGo to next message
For me the solution was in execute exclipse from instalation folder, not from the direct access created automatically in the desktop during th installation
Bye
Re: Failed to execute MI command: -exec-run [message #1828853 is a reply to message #1828787] Fri, 19 June 2020 22:03 Go to previous messageGo to next message
hmm, the short-cut created on desktop is a path to the same executable in the Eclipse folder.
Re: Failed to execute MI command: -exec-run [message #1828863 is a reply to message #1828853] Sat, 20 June 2020 04:24 Go to previous messageGo to next message
Yes, i don,t understand but it worked fine for me.
Test it take some seconds only!!
Re: Failed to execute MI command: -exec-run [message #1828864 is a reply to message #1828863] Sat, 20 June 2020 05:25 Go to previous message
unfortunately ,it does not work for me. I had trouble with debugging an exsisting makefile project. for an project built by myself , GDB works well. I guess the bug you come across has been fixed. thanks for the help buddy.
Previous Topic:Bad file number
Next Topic:[macOS] Cannot complete the install because some dependencies are not satisfiable
Current Time: Mon Jul 21 05:07:27 EDT 2025
Powered by FUDForum. Page generated in 0.12245 seconds
