Selecting a node after creation [message #1821415] |
Wed, 12 February 2020 12:50  |
I'm trying to automatically select a node right after it is created. I have other behavior that is triggered in the UI when a node is selected (a node details composite appears).
Here is the code I have in my CreateNewNodeOnClickHandler class (it serves the same roll as the same class found in the MindMap example).
RBDPart rbdPart = (RBDPart)part;
ReliabilityBlockDiagram rbd = rbdPart.getContent();
Point2D mouseInLocal = part.getVisual().sceneToLocal(e.getSceneX(), e.getSceneY());
DiagramObject dObj = null;
switch (palette.getSelectedTool()) {
case RBDPaletteComposite.COMPONENT:
dObj = RBDFactory.eINSTANCE.createComponent();
break;
if(dObj != null) {
dObj.setName(dObj.getDefaultName(rbd));
dObj.setLocation(mouseInLocal.getX(), mouseInLocal.getY());
// GEF provides the CreatePolicy and operations to add a new element
// to the model
IRootPart<? extends Node> root = getHost().getRoot();
// get the policy bound to the IRootPart
CreationPolicy creationPolicy = root.getAdapter(CreationPolicy.class);
// initialize the policy
init(creationPolicy);
// create a IContentPart for our new model.
IContentPart<? extends Node> newNodePart = creationPolicy.create(dObj, rbdPart, HashMultimap.<IContentPart<? extends Node>, String>create());
// execute the creation
commit(creationPolicy);
//Select new part
viewer.getAdapter(SelectionModel.class).setSelection(newNodePart);
As you can see, I added a line after the creation was committed that used the SelectionModel to select the new part. However, this doesn't seem to have any effect. Is there a better way to do what I want?
Re: Selecting a node after creation [message #1822394 is a reply to message #1821419] |
Thu, 05 March 2020 10:54  |
Hi Ken,
the new part should be selected by default (so no need for manually setting the selection):
- CreationPolicy#create(content, parent, anchoreds) delegates to create(content, parent, anchoreds, doFocus=true, doSelect=true).
- A SelectOperation is constructed to perform changing the selection (so that it will be undoable).
You can test that this is the case by observing the state of SelectionModel (i.e. register ListChangeListener on getSelection()). It might seem like the selection is not changed if the selection is cleared shortly after. This could happen, for example, if another handler is executed after the CreateOnClickHandler.
Selection feedback construction works as follows:
- SelectionModel is changed (it is observable)
- SelectionBehavior observes that change
(- Feedback and Handles are destroyed or created, depending on the change)
- DefaultSelectionFeedbackPartFactory is used to create selection feedback parts (by default, only the primary selection will have feedback)
!!! - Selection Feedback Geometry Provider is queried from the part !!! this could be missing for the newly created part -> look into the module and compare part bindings with another part where selection works fine
- SelectionFeedbackPart is created to show the feedback geometry
(- Primary Selection Feedback Color Provider can be used to change the selection color for different parts)
All of these are exchangeable, i.e. you can, for example, subclass DefaultSelectionFeedbackPartFactory and change the binding in your module, in order to adjust selection feedback part creation.
Matthias
[Updated on: Thu, 05 March 2020 10:55] by Moderator
FUDForum. Page generated in 0.32964 seconds
