Home » Eclipse Projects » Sirius » Variable Filter
Variable Filter [message #1822291] Tue, 03 March 2020 05:20 Go to next message
I was trying to define a Variable Filter based on an attribute that in my case is a list of strings. But as you already know, the candidates expression requires a Collection<EObject>, so therefore I used the following code for 'converting' my list of strings to a list of EObjects.
SimpleAnyType wrapper = XMLTypeFactory.eINSTANCE.createSimpleAnyType();
wrapper.setInstanceType(EcorePackage.eINSTANCE.getEString());
wrapper.setValue(myString);
Is there another way in which this situation can be handled?
The inconvenient part of this solution is the way in which the labels are displayed, see the attached picture.
Is there a way in which I can override the LabelProvider for this specific type? More explicitly I would probably need to customize the getText method from the ReflectiveItemProvider class.
I tried to play around with the org.eclipse.emf.edit.itemProviderAdapterFactories extension, but I didn't managed to get it work. I guess I'm doing something wrong, but I'm not sure what exactly.
Thank you!
Kind Regards,
Alexandra
  • Attachment: Capture.PNG
    (Size: 11.48KB, Downloaded 62 times)
Re: Variable Filter [message #1822350 is a reply to message #1822291] Wed, 04 March 2020 10:53 Go to previous message
The Variable Filter allows to filter displayed elements based on a Semantic condition expression. The candidates expression is used by the Select Model Element Variable to display the list of semantic elements that can be filtered. The candidates expression is intended to return a list of semantic elements from your model.
For instance, the Variable Filter semantic condition expression will be aql:MyVariable->includes(self). The Select Model Element Variable will look like:
candidates expression: aql:self.eContents()
Florian
Previous Topic:How to change layout programatically
Next Topic:Diagram Element Selection
Current Time: Mon Jul 21 11:55:21 EDT 2025
Powered by FUDForum. Page generated in 0.28767 seconds
