| Re: Announce OCL 6.10.1 [message #1821871 is a reply to message #1821865] |
Fri, 21 February 2020 08:17   |
Dear Ed,
thank you for getting to this issue so fast and getting the new release out so quickly!
Unfortunately, in Eclipse 2019-12 (v4.14) Modeling Tools, I have trouble installing the new version 6.10.1 for "OCL All-in-One SDK" (or its constituents) due to an existing dependency on an older version. I have not installed the previous version of Eclipse OCL and I can neither uninstall nor update it via Eclipse's interface so I'm assuming this stems from the platform. Do you have any advice on how to install version 6.10.1 of Eclipse OCL?
In particular, the Eclipse update mechanism reports the following:
Cannot complete the install because of a conflicting dependency.
Software being installed: OCL All-In-One SDK 6.10.1.v20200220-1710 (org.eclipse.ocl.master.feature.group 6.10.1.v20200220-1710)
Software currently installed: OCL Classic SDK: Ecore/UML Parsers,Evaluator,Edit 5.10.1.v20191209-1145 (org.eclipse.ocl.all.sdk.feature.group 5.10.1.v20191209-1145)
Only one of the following can be installed at once:
OCL User Interface 1.3.200.v20160613-1518 (org.eclipse.ocl.common.ui 1.3.200.v20160613-1518)
OCL User Interface 1.3.300.v20180611-1119 (org.eclipse.ocl.common.ui 1.3.300.v20180611-1119)
OCL User Interface 1.8.0.v20180916-1223 (org.eclipse.ocl.common.ui 1.8.0.v20180916-1223)
OCL User Interface 1.8.400.v20191209-1145 (org.eclipse.ocl.common.ui 1.8.400.v20191209-1145)
OCL User Interface 1.8.300.v20190603-1146 (org.eclipse.ocl.common.ui 1.8.300.v20190603-1146)
OCL User Interface 1.8.400.v20190910-0937 (org.eclipse.ocl.common.ui 1.8.400.v20190910-0937)
OCL User Interface 1.8.400.v20200220-1710 (org.eclipse.ocl.common.ui 1.8.400.v20200220-1710)
OCL User Interface 1.8.100.v20181210-1441 (org.eclipse.ocl.common.ui 1.8.100.v20181210-1441)
OCL User Interface 1.8.400.v20200217-1722 (org.eclipse.ocl.common.ui 1.8.400.v20200217-1722)
OCL User Interface 1.8.200.v20190311-1843 (org.eclipse.ocl.common.ui 1.8.200.v20190311-1843)
Cannot satisfy dependency:
From: OCL Classic SDK: Ecore/UML Parsers,Evaluator,Edit 5.10.1.v20191209-1145 (org.eclipse.ocl.all.sdk.feature.group 5.10.1.v20191209-1145)
To: org.eclipse.equinox.p2.iu; org.eclipse.ocl.ui.feature.group [2.10.0.v20191209-1145,2.10.0.v20191209-1145]
From: OCL Examples and Editors SDK 6.10.1.v20200220-1710 (org.eclipse.ocl.examples.feature.group 6.10.1.v20200220-1710)
To: org.eclipse.equinox.p2.iu; org.eclipse.ocl.examples.unified.feature.group [4.10.1.v20200220-1710,4.10.1.v20200220-1710]
From: OCL Examples Unified SDK: Parsers,Evaluator,Editors,Tools 4.10.1.v20200220-1710 (org.eclipse.ocl.examples.unified.feature.group 4.10.1.v20200220-1710)
To: org.eclipse.equinox.p2.iu; org.eclipse.ocl.common.ui [1.8.400.v20200220-1710,1.8.400.v20200220-1710]
From: OCL All-In-One SDK 6.10.1.v20200220-1710 (org.eclipse.ocl.master.feature.group 6.10.1.v20200220-1710)
To: org.eclipse.equinox.p2.iu; org.eclipse.ocl.examples.feature.group [6.10.1.v20200220-1710,6.10.1.v20200220-1710]
From: OCL User Interface 2.10.0.v20191209-1145 (org.eclipse.ocl.ui.feature.group 2.10.0.v20191209-1145)
To: org.eclipse.equinox.p2.iu; org.eclipse.ocl.common.ui [1.8.400.v20191209-1145,1.8.400.v20191209-1145]
Any help/insight is greatly appreciated!
Thanks in advance,
Thomas
| Re: Announce OCL 6.10.1 [message #1822112 is a reply to message #1821897] |
Thu, 27 February 2020 08:51   |
Dear Ed,
thanks for your advice! Unfortunately, I was unable to install the new version of Eclipse OCL into my existing Eclipse installation (after successively uninstalling all previously installed plugins). However, when I installed a fresh Eclipse (same package/version as before), then Eclipse OCL as first plugin and, only after that, the same plugins as I had installed before, I could get it to work. While this strikes me as odd, it still solves my problem for the time being!
Thomas
| Re: Announce OCL 6.10.1 [message #1822126 is a reply to message #1822112] |
Thu, 27 February 2020 11:16  |
If you can post your (bad) config.log from Help->About Eclipse SDK->Installation Details->Configuration we may get some insight / a repro for a bad P2 upgrade.
Ed Willink
FUDForum. Page generated in 0.04246 seconds
