Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Trying to theme SWT (CSS?)(Want to create a dark mode look for my SWT application)
Trying to theme SWT (CSS?) [message #1821946] Mon, 24 February 2020 05:46 Go to next message
Hi all,
I have a standalone SWT app that I would like to create a dark theme for, I can see there is some CSS support for GTK (org.eclipse.swt.internal.gtk.css) but I cant see anyway to implement using Windows. I also see that eclipse on Windows appears to support themes so was just wondering if there is anything that anybody can point me to, to help create a windows theme?
Any help/advice welcome. Thank you
Re: Trying to theme SWT (CSS?) [message #1822100 is a reply to message #1821946] Thu, 27 February 2020 04:42 Go to previous messageGo to next message
I also need standalone swt css styling.
I fetched some jars from eclipse plugin directory and tried with CSSSWTEngineImpl class but no luck.
I know that usually this is used with e4 RCP.
But I'd like to use this function with standalone SWT/JFace app.
The following is the code I tried. (usual black label appears)
import java.io.IOException;
import java.io.StringReader;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.IExtensionRegistry;
import org.eclipse.core.runtime.RegistryFactory;
import org.eclipse.core.runtime.spi.IRegistryProvider;
import org.eclipse.e4.ui.css.core.engine.CSSEngine;
import org.eclipse.e4.ui.css.core.engine.CSSErrorHandler;
import org.eclipse.e4.ui.css.swt.engine.CSSSWTEngineImpl;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
public class _CSSTest {
		Display display = new Display();
		Shell shell = new Shell();
		shell.setLayout(new GridLayout());
		try {
			RegistryFactory.setDefaultRegistryProvider(new IRegistryProvider() {
				final IExtensionRegistry r = RegistryFactory.createRegistry(null, null, null);
				public IExtensionRegistry getRegistry() {
					return r;
		} catch (CoreException e2) {
			e2.printStackTrace();
		Label label = new Label(shell, SWT.LEAD);
		label.setText("Hello world!");
		label.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true));
		CSSEngine engine = new CSSSWTEngineImpl(display);
		try {
			engine.parseStyleSheet(new StringReader("Label { color: blue; }"));
		} catch (IOException e1) {
			e1.printStackTrace();
		engine.setErrorHandler(new CSSErrorHandler() {
		  public void error(Exception e) {
		    e.printStackTrace();
		// applying styles to the child nodes means that the engine
		// should recurse downwards, in this example, the engine
		// should style the children of the Shell
		engine.applyStyles(shell, /* applyStylesToChildNodes */ true);
		shell.setSize(400, 300);
		shell.open();
		while (!shell.isDisposed()) {
		  if (!display.readAndDispatch()) {
		    display.sleep();
		display.dispose();
[Updated on: Thu, 27 February 2020 04:42] by Moderator
Re: Trying to theme SWT (CSS?) [message #1822114 is a reply to message #1822100] Thu, 27 February 2020 09:06 Go to previous messageGo to next message
Thanks for your reply,
I think that looking at the SWT code the only way is going to be to set the colour on every composite directly which is real pain but I cant see a way around it.
Re: Trying to theme SWT (CSS?) [message #1822125 is a reply to message #1822114] Thu, 27 February 2020 11:04 Go to previous messageGo to next message
Now it seems working.
I had to manually set ElementProvider and PropertyHandler.
This page might have some information about handlers.
https://github.com/eclipse/eclipse.platform.ui/blob/master/bundles/org.eclipse.e4.ui.css.swt/plugin.xml
The following code only works for background-color property.
Jars I'm using:
SWT
swt-win64.jar
JFace
com.ibm.icu_64.2.0.v20190507-1337.jar
org.eclipse.core.commands_3.9.400.v20190516-1358.jar
org.eclipse.core.jobs_3.10.400.v20190506-1457.jar
org.eclipse.core.runtime_3.15.300.v20190508-0543.jar
org.eclipse.equinox.common_3.10.400.v20190516-1504.jar
org.eclipse.equinox.registry_3.8.400.v20190516-1504.jar
org.eclipse.jface_3.16.0.v20190528-0922.jar
org.eclipse.jface.databinding_1.9.0.v20190519-0933.jar
org.eclipse.jface.text_3.15.200.v20190519-2344.jar
org.eclipse.osgi_3.14.0.v20190517-1309.jar
org.eclipse.text_3.8.200.v20190519-2344.jar
org.eclipse.ui.forms_3.8.0.v20190519-1034.jar
org.eclipse.ui.workbench_3.115.0.v20190521-1602.jar
SWT CSS
org.apache.batik.css_1.11.0.v20190515-0436.jar
org.apache.batik.i18n_1.11.0.v20190515-0436.jar
org.apache.batik.util_1.11.0.v20190515-0436.jar
org.eclipse.e4.ui.css.core_0.12.900.v20191106-1716.jar
org.eclipse.e4.ui.css.swt_0.13.700.v20191113-1031.jar
org.eclipse.e4.ui.css.swt.theme_0.12.500.v20191125-1011.jar
org.w3c.css.sac_1.3.1.v200903091627.jar
import org.eclipse.e4.ui.css.core.dom.properties.css2.ICSSPropertyBackgroundHandler;
import org.eclipse.e4.ui.css.core.dom.properties.providers.CSSPropertyHandlerSimpleProviderImpl;
import org.eclipse.e4.ui.css.swt.dom.SWTElementProvider;
import org.eclipse.e4.ui.css.swt.properties.css2.CSSPropertyBackgroundSWTHandler;
		try {
					return r;
		label.setLayoutData(new GridData(SWT.CENTER, SWT.CENTER, true, true));
		var engine = new CSSSWTEngineImpl(display);
		engine.setElementProvider(new SWTElementProvider());
		engine.registerCSSPropertyHandlerProvider(new CSSPropertyHandlerSimpleProviderImpl());
		engine.registerCSSPropertyHandler(ICSSPropertyBackgroundHandler.class, CSSPropertyBackgroundSWTHandler.INSTANCE);
		try {
			engine.parseStyleSheet(new StringReader("Label { background-color: blue; }"));
		engine.applyStyles(label, /* applyStylesToChildNodes */ true);
		shell.open();
		    display.sleep();
		display.dispose();
Re: Trying to theme SWT (CSS?) [message #1822152 is a reply to message #1822125] Thu, 27 February 2020 22:41 Go to previous messageGo to next message
I struggled a bit, and finally made a working example.
This example downloads plugin.xml from GITHUB, and parse it.
So what you need is just SWT / JFace / e4 CSS Jars in your classpath.
import java.util.function.BiFunction;
import java.util.function.Function;
import java.io.File;
import java.io.FileInputStream;
import java.io.FileNotFoundException;
import java.io.FileOutputStream;
import java.net.URL;
import java.nio.channels.Channels;
import java.nio.channels.ReadableByteChannel;
import org.eclipse.core.internal.registry.ExtensionRegistry;
import org.eclipse.core.runtime.spi.RegistryContributor;
import org.eclipse.e4.ui.css.core.impl.engine.RegistryCSSPropertyHandlerProvider;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Layout;
public class _SWTStandaloneCSS {
		var registry = new ExtensionRegistry(null, null, null);
		var dummyContributor = new RegistryContributor("", "", "", "");
		registry.addExtensionPoint("org.eclipse.e4.ui.css.core.elementProvider", dummyContributor, true, null, null, null);
		registry.addExtensionPoint("org.eclipse.e4.ui.css.core.propertyHandler", dummyContributor, true, null, null, null);
		try {
			registry.addContribution(pluginXMLStream(), dummyContributor, true, null, null, null);
			RegistryFactory.setDefaultRegistryProvider(() -> registry);
		} catch (Exception e) {
		SWTBoilerplate.show(composite -> {
			var engine = new CSSSWTEngineImpl(composite.getDisplay());
			initCSSEngine(engine, registry);
			var content = createContent(composite);
			try {
				engine.parseStyleSheet(new StringReader("Label { color : red; background-color: blue; }"));
			engine.applyStyles(composite.getShell(), /* applyStylesToChildNodes */ true);
			return content;
	static FileInputStream pluginXMLStream() {
		File f = download("https://raw.githubusercontent.com/eclipse/eclipse.platform.ui/master/bundles/org.eclipse.e4.ui.css.swt/plugin.xml", "swt_css_plugin.xml");
		try {
			return new FileInputStream(f);
		} catch (FileNotFoundException e) {
			throw new RuntimeException(e);
	static File download(String url, String destFilePath) {
		var f = new File(destFilePath);
		if( f.exists() ) return f;
		URL website;
		try {
			website = new URL(url);
			ReadableByteChannel rbc = Channels.newChannel(website.openStream());
			FileOutputStream fos = new FileOutputStream(destFilePath);
			fos.getChannel().transferFrom(rbc, 0, Long.MAX_VALUE);
			fos.close();
		return f;
	static void initCSSEngine(CSSSWTEngineImpl engine, ExtensionRegistry registry) {
		engine.registerCSSPropertyHandlerProvider(new RegistryCSSPropertyHandlerProvider(registry));
	static Control createContent(Composite comp) {
		Label label = new Label(comp, SWT.LEAD);
		return label;
class SWTBoilerplate {
	private final Display display;
	private Shell   shell;
	public SWTBoilerplate() {
		if( Display.getCurrent() == null) {
		} else {
			display = Display.getCurrent();
	public static void show(Image image) {
		SWTBoilerplate app = new SWTBoilerplate();
		var com = app.launch();
		Label l = new Label(com, SWT.NONE);
		l.setImage(image);
		app.loop(true);
	public static void show(Function<Composite, Control> creator) {
		creator.apply(com);
		app.loop(true);
	public static void show(BiFunction<Composite, Shell, Control> creator) {
		creator.apply(com, com.getShell());
		app.loop(true);
	public Composite launch() {
		return launch(new FillLayout(), SWT.SHELL_TRIM);
	public Composite launch( Layout layout , int shellStyle) {
		shell = new Shell(display, shellStyle);
		shell.setLayout(new FillLayout());
		shell.setSize(800,600);
		Composite comp = new Composite(shell, SWT.None);
		comp.setLayout( layout );
		return comp;
	public void loop() {
	    loop(false);
	public void loop(boolean pack) {
		if( shell == null ) {
			shell = Display.getCurrent().getShells()[0];
		shell.open();
		if(pack) shell.pack();
		while( !shell.isDisposed() ) {
			if( !display.readAndDispatch() ) {
				display.sleep();
		display.dispose();
	public static void nloop() {
		new SWTBoilerplate().loop();
[Updated on: Thu, 27 February 2020 22:47] by Moderator
Re: Trying to theme SWT (CSS?) [message #1822156 is a reply to message #1822152] Fri, 28 February 2020 02:50 Go to previous messageGo to next message
And you can switch entire theme by fetching css file from web.
Maybe, also you can use "org.eclipse.e4.ui.css.swt.theme" extension point.
But the following is adequate for standalone SWT application in my case.
//engine.parseStyleSheet(new StringReader("Label { color : red; background-color: blue; }"));
File f = download("https://raw.githubusercontent.com/guari/eclipse-ui-theme/master/com.github.eclipseuitheme.themes.plugin/themes/css/moonrise-ui-standalone.css",
						"moonrise-ui-standalone.css");
engine.parseStyleSheet(new FileInputStream(f));
Re: Trying to theme SWT (CSS?) [message #1822158 is a reply to message #1821946] Fri, 28 February 2020 04:23 Go to previous messageGo to next message
Great! thank you so much for the help, really appreciated. I will give these a try today. Thanks again
Re: Trying to theme SWT (CSS?) [message #1822161 is a reply to message #1822158] Fri, 28 February 2020 05:11 Go to previous messageGo to next message
Further, I tested in my SWT app.
But unfortunately some renderers seems to be tied with platform bundle system.
Some advanced Controls such as CTabFolders, produce NPE (because they can't find the bundle).
It seems we need some more tweak to perfectly work with the SWT Standalone Application.
Or we have to try e4 RCP Application instead.
Let me know if you have a better solution.
Thank you.
[Updated on: Fri, 28 February 2020 05:15] by Moderator
Re: Trying to theme SWT (CSS?) [message #1822167 is a reply to message #1822161] Fri, 28 February 2020 06:18 Go to previous messageGo to next message
Missing name Mising name wrote on Fri, 28 February 2020 05:11
Thank you.
Ok thanks - i will let you know if I find anything.
Re: Trying to theme SWT (CSS?) [message #1822178 is a reply to message #1822167] Fri, 28 February 2020 14:53 Go to previous messageGo to next message
Now I could handle with the NPE of CSSPropertyTabRendererSWTHandler.
Just rewrite CSSPropertyTabRendererSWTHandler in your code.
Replace the corresponding class name in plugin.xml and load this instead of downloading from GITHUB at runtime.
I searched in "moonrise-ui-standalone.css" and the only part which uses bundle system was CTabFolderRenderer.
So the live issue was handled.
import java.lang.reflect.Constructor;
import org.eclipse.e4.ui.css.swt.helpers.URI;
import org.eclipse.e4.ui.css.swt.properties.AbstractCSSPropertySWTHandler;
import org.eclipse.swt.custom.CTabFolder;
import org.eclipse.swt.custom.CTabFolderRenderer;
import org.w3c.dom.css.CSSPrimitiveValue;
import org.w3c.dom.css.CSSValue;
public class StandaloneCSSPropertyTabRendererSWTHandler extends AbstractCSSPropertySWTHandler {
	protected void applyCSSProperty(Control control, String property, CSSValue value, String pseudo, CSSEngine engine)
			throws Exception {
		if (!(control instanceof CTabFolder)) {
			return;
		if (value.getCssValueType() == CSSValue.CSS_PRIMITIVE_VALUE) {
			if (((CSSPrimitiveValue) value).getPrimitiveType() == CSSPrimitiveValue.CSS_URI) {
				String rendURL = ((CSSPrimitiveValue) value).getStringValue();
				URI uri = URI.createURI(rendURL);
				if (uri.authority().equals("org.eclipse.e4.ui.workbench.renderers.swt")) {
					Class<?> targetClass = org.eclipse.e4.ui.workbench.renderers.swt.CTabRendering.class;
					// check to see if the folder already has an instance of the same renderer
					CTabFolderRenderer renderer = ((CTabFolder) control).getRenderer();
					if (renderer != null && renderer.getClass() == targetClass) {
						return;
					Constructor<?> constructor = targetClass.getConstructor(CTabFolder.class);
					if (constructor != null) {
						Object rend = constructor.newInstance(control);
						if (rend != null && rend instanceof CTabFolderRenderer) {
							((CTabFolder) control).setRenderer((CTabFolderRenderer) rend);
				} else {
					((CTabFolder) control).setRenderer(null);
	protected String retrieveCSSProperty(Control control, String property, String pseudo, CSSEngine engine)
			throws Exception {
		return null;
[Updated on: Fri, 28 February 2020 21:49] by Moderator
Re: Trying to theme SWT (CSS?) [message #1822180 is a reply to message #1822178] Fri, 28 February 2020 15:31 Go to previous messageGo to next message
You can set classname and id for the widget.
This is very useful.
	public static void setClassName(Widget w, String className) {
		w.setData("org.eclipse.e4.ui.css.CssClassName", className);
	public static void setId(Widget w, String id) {
		w.setData("org.eclipse.e4.ui.css.id", id);
Re: Trying to theme SWT (CSS?) [message #1822184 is a reply to message #1822180] Fri, 28 February 2020 21:48 Go to previous messageGo to next message
It seems I wrote the wrong TabFolder rendering class above.
The following is the correct one. [already edited]
[Updated on: Fri, 28 February 2020 21:50] by Moderator
Re: Trying to theme SWT (CSS?) [message #1822208 is a reply to message #1822184] Sat, 29 February 2020 19:47 Go to previous message
If you extends Composite or Shell, simple class name is used as Element name.
Composite or Shell selectors are not applied.
CustomWidget {
background-color: red;
If you want a custom property, perhaps standard way in RCP is using extension points.
But you can find properties programmatically easily, no need to use extension points and no need to modify plugin.xml one by one.
public static String property(Widget w, String property) {
	var engine = getEngine(w.getDisplay());
	var element = engine.getElement(w);
	var style = engine.getViewCSS().getComputedStyle(element, null);
	if( style == null ) {
		System.out.println("style is null : " + element);
		return null;
	var cssVal = style.getPropertyCSSValue(property);
	return cssVal != null ? cssVal.getCssText() : null;
Previous Topic:Standalone SWT with Central Maven repo
Next Topic:Composite background & dark theme
Current Time: Fri Sep 26 07:08:33 EDT 2025
Powered by FUDForum. Page generated in 0.05546 seconds
