Home » Language IDEs » C / C++ IDE (CDT) » Add java-doc to my java library and eclipse says no java-doc found
Add java-doc to my java library and eclipse says no java-doc found [message #1822089] Thu, 27 February 2020 00:25
Using eclipse IDE I developed a java library.
I also exported it as a jar file.
I also created the java-doc for the project.
I added the doc/ folder to the jar too.
I created a test project and added my java library as external jar. I see that my library code works fine. But the IDE is not showing the documentation for the functions and properties tellgamestop. I want to make the IDE refer to the doc automatically. How to do that. I am gonna publish this library. How to make IDEs refer to the java-doc of my library. Is there any procedure?
 * The Class JavaSMTPMailer.
public class JavaSMTPMailer {
    /** The host. */
    private String host;
    /** The port. */
    private String port;
    /** The username. */
    private String username;
    /** The password. */
    private String password;
    /** The SMTP secure. */
    private String SMTPSecure = "tls";
    /** The use auth. */
    private boolean useAuth = false;
    /** The global sender. */
    private InternetAddress globalSender = null;
    /** The global reply mail. */
    private InternetAddress[] globalReplyMail = null;
    /** The session. */
    private Session session;
    /** The mail. */
    private Mail mail;
     * Instantiates a new java SMTP mailer.
     * @param host the host
     * @param port the port
    public JavaSMTPMailer(String host, String port){
        this.host = host;
        this.port = port;
     * @param username the username
     * @param password the password
    public JavaSMTPMailer(String host, String port,String username, String password){
        this(host, port);
        this.username = username;
        this.password = password;
        this.useAuth = true;
[Updated on: Sat, 29 February 2020 00:42] by Moderator
Previous Topic:How to make a cloned c++/pydev editor tab appear right after the current tab
Next Topic:AVR32 hardware debug
Current Time: Mon Jul 21 06:54:47 EDT 2025
Powered by FUDForum. Page generated in 0.07889 seconds
