Specify the encoding of attached source files [message #1822021] |
Tue, 25 February 2020 17:50  |
Hello everyone,
I am currently using Xtext (2.20.0.v20191202-1256) in Eclipse 2019-12 on macOS and experience issues related to the display of special characters in the attached source code. The default encoding of my workspace is set to UTF-8.
When I open an .xtend source file from the Xtext source packages, Eclipse interprets the encoding incorrectly. Jumping to the declaration of 'GeneratorFragment2', for instance, opens org.eclipse.xtext.xtext.generator.generator.GeneratorFragment2.xtend in an editor, but all the guillemets are shown as question marks (as REPLACEMENT CHARACTER, U+FFFD, to be more specific). Unfortunately, this also prevents Eclipse from parsing the enclosed code accordingly.
Setting the default encoding of the workspace to ISO-8859-1 and reopening the file solves the issue, but is not an option for the project that I am working on.
I have tried to set the encoding of the opened .xtend file to ISO-8859-1 via the Edit > Set Encoding dialog and to set the encoding of the org.eclipse.xtext.xtext.generator.source_2.20.0.v20191202-0915.jar source attachment to ISO-8859-1 (in the Java Build Path dialog). Both of these attempts do not seem to have any effect, though.
Is there anything I can do to let Eclipse know about the encoding of the attached .xtend source files?
Thanks!
[Updated on: Tue, 25 February 2020 17:52] by Moderator
FUDForum. Page generated in 0.08655 seconds
