Home » Modeling » TMF (Xtext) » Xtext Hover Documentation [Duplicate - https://www.eclipse.org/forums/index.php/m/1822037/#msg_18220
Xtext Hover Documentation [Duplicate - https://www.eclipse.org/forums/index.php/m/1822037/#msg_18220 [message #1822039] Wed, 26 February 2020 04:34 Go to next message
Hello, i have the following grammar:
	('data-dictionary' '{'
	attributes+=(Attribute)*
	('entity-catalog' '{'
	entities+=Entity*
Attribute:
	AttributeSimpleType | AttributeEntityType
Entity:
	(documentation=ML_DOC_COMMENT)?
        name=ID funcName=STRING '{'
	features+=(Feature)*
Feature:
	(type=FeatureAttributeType | type=FeatureEntityType)
FeatureAttributeType:
	(type=[AttributeSimpleType|ID]|type=[AttributeSimpleType|GENERAL_FQN])
FeatureEntityType:
	'entity' (attribute=[AttributeEntityType|ID]|attribute=[AttributeEntityType|GENERAL_FQN]);
I have implemented the IEObjectDocumentationProvider and DefaultEObjectHoverProvider, but when i hover over a feature instead of giving me the doc. of the feature it gives me the doc of the attribute which is contained in the data-dictionary. The object that is passed to the getDocumentation method is of type Attribute. I have debugged and noticed in the EObjectAtOffsetHelper inside the resolveCrossReferencedElement method, the type of the object passed is Feature, but there is a check for the object's representation in the model instance. Since the selected Feature is present as an Attribute the returned object is the Attribute. Is there a way to get the doc of the feature instead of the attribute without having to override that method and get rid of the check?
[Updated on: Wed, 26 February 2020 04:53] by Moderator
Re: Xtext Hover Documentation [Duplicate - https://www.eclipse.org/forums/index.php/m/1822037/#msg_1 [message #1822127 is a reply to message #1822039] Thu, 27 February 2020 11:31 Go to previous messageGo to next message
test
Re: Xtext Hover Documentation [Duplicate - https://www.eclipse.org/forums/index.php/m/1822037/#msg_1 [message #1822128 is a reply to message #1822127] Thu, 27 February 2020 11:39 Go to previous messageGo to next message
test2
Re: Xtext Hover Documentation [Duplicate - https://www.eclipse.org/forums/index.php/m/1822037/#msg_1 [message #1822129 is a reply to message #1822128] Thu, 27 February 2020 11:46 Go to previous messageGo to next message
Test
Re: Xtext Hover Documentation [Duplicate - https://www.eclipse.org/forums/index.php/m/1822037/#msg_1 [message #1822133 is a reply to message #1822129] Thu, 27 February 2020 11:54 Go to previous messageGo to next message
Are you testing because you keeping getting a 504 after posting? That's happening to me too, though the post does actually get posted...
Re: Xtext Hover Documentation [Duplicate - https://www.eclipse.org/forums/index.php/m/1822037/#msg_1 [message #1822135 is a reply to message #1822133] Thu, 27 February 2020 12:07 Go to previous message
yes i am testing https://bugs.eclipse.org/bugs/show_bug.cgi?id=560538
Previous Topic:Specify the encoding of attached source files
Next Topic:Code creation for data validation
Current Time: Sat Jul 26 11:02:22 EDT 2025
Powered by FUDForum. Page generated in 0.06941 seconds
