Home » Newcomers » Newcomers » Starting Eclipse 4.14 with Java 11.0.6 on command Line --> Not Working : Need Help(Starting Eclipse 4.14 with Java 11.0.6 through command Line)
Starting Eclipse 4.14 with Java 11.0.6 on command Line --> Not Working : Need Help [message #1821986] Tue, 25 February 2020 03:18 Go to next message
Hi I am trying to start the Eclipse 4.14 version through command line and it is not starting. Please have a look at my "LOG File" and suggest me valuable suggestion to get it working. I am working on Eclipse CDT for C/C++ Developers tool.
//--------------------------- LOG File Starts Here ------------------------------------------------------------
!SESSION 2020-02-25 08:58:34.510 -----------------------------------------------
eclipse.buildId=4.14.0.I20191210-0610
java.version=11.0.6
java.vendor=Debian
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.cpp.product -application org.eclipse.cdt.core.CodeFormatter -verbose -config /media/sf_VirtualBox/eclipse/org.eclipse.cdt.core.prefs /media/sf_VirtualBox/eclipse/eclipse-workspace/TestExample.c
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.cpp.product -consolelog -debug -application org.eclipse.cdt.core.CodeFormatter -verbose -config /media/sf_VirtualBox/eclipse/org.eclipse.cdt.core.prefs /media/sf_VirtualBox/eclipse/eclipse-workspace/TestExample.c
!ENTRY org.eclipse.osgi 4 0 2020-02-25 08:58:36.825
!MESSAGE An error occurred while automatically activating bundle org.eclipse.cdt.core (99).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.cdt.core.CCorePlugin.start() of bundle org.eclipse.cdt.core.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:863)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:791)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1015)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:365)
at org.eclipse.osgi.container.Module.doStart(Module.java:603)
at org.eclipse.osgi.container.Module.start(Module.java:467)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:493)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:117)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:571)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:346)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:398)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:425)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:171)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:620)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:196)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:929)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:246)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:63)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:198)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Caused by: java.lang.IllegalStateException: The instance data location has not been specified yet.
at org.eclipse.core.internal.runtime.DataArea.assertLocationInitialized(DataArea.java:59)
at org.eclipse.core.internal.runtime.DataArea.getStateLocation(DataArea.java:136)
at org.eclipse.core.internal.runtime.InternalPlatform.getStateLocation(InternalPlatform.java:491)
at org.eclipse.core.runtime.Plugin.getStateLocation(Plugin.java:259)
at org.eclipse.cdt.core.CCorePlugin.start(CCorePlugin.java:406)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:842)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:834)
... 33 more
Root exception:
!ENTRY org.eclipse.epp.logging.aeri.ide 2 0 2020-02-25 08:58:36.919
!MESSAGE Could not resolve module: org.eclipse.epp.logging.aeri.ide [212]
Unresolved requirement: Import-Package: org.apache.lucene.document; version="[7.1.0,8.0.0)"
!ENTRY org.eclipse.osgi 4 0 2020-02-25 08:58:36.921
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.cdt.core was unable to load class org.eclipse.cdt.core.formatter.CodeFormatterApplication.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:212)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:198)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.cdt.core (99).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:126)
... 16 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.cdt.core.CCorePlugin.start() of bundle org.eclipse.cdt.core.
... 26 more
... 33 more
Re: Starting Eclipse 4.14 with Java 11.0.6 on command Line --> Not Working : Need Help [message #1822003 is a reply to message #1821986] Tue, 25 February 2020 10:17 Go to previous messageGo to next message
It looks like this application relies on plugins that rely on a workspace being available so you'd need to specify a -data argument followed by a folder that will be used as the "data location area".
Re: Starting Eclipse 4.14 with Java 11.0.6 on command Line --> Not Working : Need Help [message #1822010 is a reply to message #1822003] Tue, 25 February 2020 11:15 Go to previous messageGo to next message
/media/sf_VirtualBox/eclipse/eclipse -consolelog -application org.eclipse.cdt.core.CodeFormatter -help -quiet -config /media/sf_VirtualBox/eclipse/org.eclipse.cdt.core.prefs -data /media/sf_VirtualBox/eclipse/eclipse-workspace/Aspi_Project/src/Aspi_Project.c
Usage: eclipse -application org.eclipse.cdt.core.CodeFormatter [ OPTIONS ] [ -config <configFile> ] <files>
<files> C/C++ source/header files and/or directories to format.
Only source/header file endings (like .c .cpp or .h) will be formatted in the given directory.
-config <configFile> Use the formatting style from the specified properties file.
Refer to the help documentation to find out how to generate this file.
The usage of -data for setting the workspace is not supported yet and should be avoided!
OPTIONS:
-help Display this message.
-quiet Only print error messages.
-verbose Be verbose about the formatting job.
Re: Starting Eclipse 4.14 with Java 11.0.6 on command Line --> Not Working : Need Help [message #1822011 is a reply to message #1822010] Tue, 25 February 2020 11:19 Go to previous messageGo to next message
I have "-data" tag when I am specifying the workspace folder but it does not support the "-data" option in Eclipse 4.14 version as shown in the above reply. Need help and valuable suggestion in this regard. Many Thanks.
Re: Starting Eclipse 4.14 with Java 11.0.6 on command Line --> Not Working : Need Help [message #1822029 is a reply to message #1822011] Wed, 26 February 2020 02:14 Go to previous messageGo to next message
The argument processing is rather complex. Before the application itself is launched, the Eclipse runtime will process arguments as well (and first). That includes all of these:
https://help.eclipse.org/2019-12/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Freference%2Fmisc%2Fruntime-options.html
These arguments are stripped out before the application itself is launched with any remaining command line arguments.
Given the failure you see:
It seems clear that the osgi.instance.area is not specified and this can be done with a -data argument.
So I cannot give you better advice than to try it.
Re: Starting Eclipse 4.14 with Java 11.0.6 on command Line --> Not Working : Need Help [message #1822032 is a reply to message #1822029] Wed, 26 February 2020 03:25 Go to previous messageGo to next message
I have found the solution with regard to this problem:
In eclipse.ini File We have to COMMENT or REMOVE these two lines:
1) -Dosgi.instance.area.default=@user.home/eclipse-workspace
2) -Dosgi.dataAreaRequiresExplicitInit=true
and Eclipse Formatting for CDT C/C++ Works for any file or directory consisting of multiple .h and .cpp/.c files
RESULT I GOT:
user@AMLR-1000:/media/sf_VirtualBox/eclipse$ /media/sf_VirtualBox/eclipse/eclipse -consolelog -application org.eclipse.cdt.core.CodeFormatter -verbose -config /home/user/eclipse-workspace/Aspi_Project/.settings/org.eclipse.cdt.core.prefs /home/user/eclipse-workspace/Aspi_Project/src/Aspi_Project.c
Configuration Name: /home/user/eclipse-workspace/Aspi_Project/.settings/org.eclipse.cdt.core.prefs
Starting format job ...
Formatting: /home/user/eclipse-workspace/Aspi_Project/src/Aspi_Project.c
DONE
Re: Starting Eclipse 4.14 with Java 11.0.6 on command Line --> Not Working : Need Help [message #1822036 is a reply to message #1822032] Wed, 26 February 2020 04:13 Go to previous message
Yes, that makes sense. The default behavior of the Eclipse installation wants to prompt for the workspace, which makes no sense for the application you are trying to run.
Thanks for sharing your solution!
Previous Topic:cc1plus.exe error: failure to convert cp932 to utf-8.
Next Topic:HelloWorld project not successful
Current Time: Sun Jul 20 20:54:23 EDT 2025
Powered by FUDForum. Page generated in 0.09111 seconds
