Home » Eclipse Projects » Eclipse Hawk » ClassCastException when adding Hawk index as Epsilon model
ClassCastException when adding Hawk index as Epsilon model [message #1821989] Tue, 25 February 2020 04:06 Go to next message
Trying to add a new Hawk model to an Epsilon launch configuration through the Models configuration tab produces the following exception, which prevents the model configuration dialog from showing.
java.lang.ClassCastException: class [Ljava.lang.Object; cannot be cast to class [Lorg.hawk.osgiserver.HModel; ([Ljava.lang.Object; is in module java.base of loader 'bootstrap'; [Lorg.hawk.osgiserver.HModel; is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @1f799f4c)
	at org.hawk.ui.emc.dt2.HawkModelConfigurationDialog.populate(HawkModelConfigurationDialog.java:162)
	at org.hawk.ui.emc.dt2.HawkModelConfigurationDialog.createFilesGroup(HawkModelConfigurationDialog.java:143)
	at org.hawk.ui.emc.dt2.HawkModelConfigurationDialog.createGroups(HawkModelConfigurationDialog.java:56)
	at org.eclipse.epsilon.common.dt.launching.dialogs.AbstractModelConfigurationDialog.createDialogArea(AbstractModelConfigurationDialog.java:82)
	at org.eclipse.jface.dialogs.TitleAreaDialog.createContents(TitleAreaDialog.java:158)
	at org.eclipse.jface.window.Window.create(Window.java:426)
	at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1096)
	at org.eclipse.jface.window.Window.open(Window.java:783)
This happens both when I install Hawk from https://download.eclipse.org/hawk/1.2.0/updates/ on one of the Epsilon bundles and when I run it with from source. Any suggestions?
Dimitris
Re: ClassCastException when adding Hawk index as Epsilon model [message #1821991 is a reply to message #1821989] Tue, 25 February 2020 04:26 Go to previous messageGo to next message
I *think* I've fixed this in https://git.eclipse.org/c/hawk/hawk.git/commit/?id=98a82ce76deaae364f63399fe782240dd11a992e
Dimitris
Re: ClassCastException when adding Hawk index as Epsilon model [message #1822048 is a reply to message #1821991] Wed, 26 February 2020 05:14 Go to previous message
Thank you for the fix! For some reason, this bug has been in Hawk since at least 2016, but we didn't run into it until now. Odd!
Previous Topic:Trouble resolving Ivy dependencies
Next Topic:Hawk 2.0 Release
Current Time: Mon Jul 21 00:03:18 EDT 2025
Powered by FUDForum. Page generated in 0.04893 seconds
